Discuss
Whirlpool dryer help
 in
Dryer Repair
I have a older whirlpool dryer. This morning I went to us, would have been first time it was used
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool dryer help
  #1 (permalink)
Old 03-30-2018, 01:57 PM
Junior Member
mforesta is on a distinguished road
Default Whirlpool dryer help
Model Number: LE6810XSNO   Brand: Whirlpool   Age: 5 - 10 years
I have a older whirlpool dryer. This morning I went to us, would have been first time it was used today, There was a pop and spark. Seem to be from bottom of dryer. And some light smoke was coming out of it. It immediately turned off. I had to go to work and wasnt yet able to take apart but if somebody had something similar, what would be the most likely cause?
Related Models
Whirlpool LE6810XSW0 Residential Dryer
Whirlpool LE6880XSW0 Residential Dryer
Whirlpool LE6880XSW1 Residential Dryer
Whirlpool LE6880XTW0 Residential Dryer
Whirlpool LE6880XTW1 Residential Dryer
Whirlpool LE7000XMW0 Residential Dryer
Whirlpool LE7000XMW1 Residential Dryer
Whirlpool LE7000XMW2 Residential Dryer
Whirlpool LE7000XPW0 Residential Dryer
Whirlpool LE7000XSW0 Residential Dryer
Whirlpool LE7000XTG0
Whirlpool LE7000XTN0
Whirlpool LE7000XTW0 Residential Dryer
Whirlpool LE7005XPW0 Residential Dryer
Whirlpool LE7010XPW0 Residential Dryer
Whirlpool LE7010XSW0 Residential Dryer
Whirlpool LE7080XSW0 Residential Dryer
Whirlpool LE7080XSW1 Residential Dryer
Whirlpool LE7080XTW0 Residential Dryer
Whirlpool LE7080XTW1 Residential Dryer
Amana LE7101LB DRYER- ELE
Amana LE7101WB DRYER- ELE
Amana LE7111LB DRYER- ELE
Amana LE7111LM DRYER- ELE
Amana LE7111WB DRYER- ELE
Amana LE7111WM DRYER- ELE
Amana LE7121LM DRYER- ELE
Amana LE7121WM DRYER- ELE
Amana LE7153LB DRYER- ELE
Amana LE7153LM DRYER- ELE
Amana LE7153WB DRYER- ELE
Amana LE7153WM DRYER- ELE
Amana LE7163LM DRYER- ELE
Amana LE7163WM DRYER- ELE
Whirlpool LE7680XMW0 Residential Dryer
Whirlpool LE7680XPW0 Residential Dryer
Whirlpool LE7680XSW0 Residential Dryer
Whirlpool LE7680XSW1 Residential Dryer
Whirlpool LE7680XSW2 Residential Dryer
Whirlpool LE7685XPW0 Residential Dryer
Whirlpool LE7685XPW1 Residential Dryer
Whirlpool LE7700XWW0 Residential Dryer
Whirlpool LE7760XWW0 Residential Dryer
Whirlpool LE7800XKW0 Residential Dryer
Whirlpool LE7800XKW1 Residential Dryer
Whirlpool LE7800XMW0 Residential Dryer
Whirlpool LE7800XMW1 Residential Dryer
Whirlpool LE7800XMW2 Residential Dryer
Whirlpool LE7800XPW0 Residential Dryer
Whirlpool LE7800XSN2 ELECTRIC DRYER
Whirlpool LE7800XSW0 Residential Dryer
Whirlpool LE7800XSW1 Residential Dryer
Whirlpool LE7800XSW2 Residential Dryer
Whirlpool LE7800XSW3 Residential Dryer
Whirlpool LE7800XW2 ELECTRIC DRYER
Whirlpool LE7805XPW0 Residential Dryer
Whirlpool LE7810XPW0 Residential Dryer
Amana LE8107L2 WASHER-TOP LOADING
Amana LE8107W2 DRYER- ELE
Amana LE8207L2 WASHER-TOP LOADING
Amana LE8207L3 WASHER-TOP LOADING
Amana LE8207W2 DRYER- ELE
Amana LE8207W2B DRYER- ELE
Amana LE8207W3 DRYER- ELE
Amana LE8217L2 DRYER- ELE
Amana LE8217W2 DRYER- ELE
Amana LE8267L2 WASHER-TOP LOADING
Amana LE8267W2 DRYER- ELE
Amana LE8317L2 DRYER- ELE
Amana LE8317W2 DRYER- ELE
Amana LE8317W2B DRYER- ELE
Amana LE8327W DRYER- ELE
Amana LE8367L2 WASHER-TOP LOADING
Amana LE8367W2 DRYER- ELE
Amana LE8407L2 DRYER- ELE
Amana LE8407W DRYER- ELE
Amana LE8407W2 DRYER- ELE
Amana LE8457L2 DRYER- ELE
Amana LE8457W DRYER- ELE
Amana LE8457W2 DRYER- ELE
Amana LE8467L2 DRYER- ELE
Amana LE8467W2 DRYER- ELE
Amana LE8507W DRYER- ELE
Amana LE8517L2 DRYER- ELE
Amana LE8517W2 DRYER- ELE
Amana LE8517W2B DRYER- ELE
Amana LE8567L2 DRYER- ELE
Amana LE8567W2 DRYER- ELE
Whirlpool LE8600XWW0 Residential Dryer
Amana LE8607L2 DRYER- ELE
Amana LE8607W DRYER- ELE
Amana LE8607W2 DRYER- ELE
Whirlpool LE8650XWW0 Residential Dryer
Whirlpool LE8860XWQ0 Residential Dryer
Amana LE9002 WASHER-TOP LOADING
Amana LE9002 DRYER- ELE
Amana LE9012 WASHER-TOP LOADING
Whirlpool LE9100XTW0 Residential Dryer
Whirlpool LE9100XTW1 Residential Dryer
Amana LE9107W DRYER- ELE
Whirlpool LE9200XWW0 Residential Dryer
Whirlpool LE9200XWW1 Residential Dryer
Amana LE9207L2 DRYER- ELE
Amana LE9207W DRYER- ELE
Amana LE9207W2 DRYER- ELE
Whirlpool LE9300XTW0 Residential Dryer
Whirlpool LE9300XTW1 Residential Dryer
Whirlpool LE9380XTW0 Residential Dryer
Whirlpool LE9480XWW0 Residential Dryer
Whirlpool LE9480XWW1 Residential Dryer
Whirlpool LE9500XTF0 ELECTRIC DRYER
Whirlpool LE9500XTG0 ELECTRIC DRYER
Whirlpool LE9500XTM0 ELECTRIC DRYER
Whirlpool LE9500XTN0 ELECTRIC DRYER
Whirlpool LE9500XTW0 Residential Dryer
Whirlpool LE9500XTW1 Residential Dryer
Whirlpool LE9520XTW0 Residential Dryer
Whirlpool LE9520XTW1 Residential Dryer
Whirlpool LE9680XWW0 Residential Dryer
Whirlpool LE9680XWW1 Residential Dryer
  #2 (permalink)
Old 04-02-2018, 11:53 AM
Senior Member
thorning is on a distinguished road
Default
A likely cause is a burnt off wire at the heating element. You will need to dismantle the dryer at least partially to get at it for repair. Not a good idea to try to use this until it is repaired.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Burned Dryer Plug - Whirlpool Electric Dryer EastCobbSnob Dryer Repair 5 12-09-2013 06:43 PM
Whirlpool Thin Twin Washer Dryer Combo, Dryer won't heat up NVChickey Dryer Repair 1 02-25-2012 11:52 PM
Whirlpool Dryer won't start in dryer mode. hol99 Dryer Repair 4 06-18-2011 06:42 AM
Whirlpool Dryer won't start in dryer mode. hol99 Dryer Repair 7 12-27-2010 03:34 AM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 10:47 AM
