Discuss
Dryer problem
 in
Dryer Repair
A fin fell off the drum in the dryer. Can it be fixed?
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer problem
  #1 (permalink)
Old 03-27-2018, 01:50 PM
Junior Member
johnh@echoetching.com is on a distinguished road
Question Dryer problem
Brand: -other-   Age: 5 - 10 years
  #2 (permalink)
Old 03-30-2018, 04:34 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Probably. Most are attached with screws. Do you have a model number?
  #3 (permalink)
Old 04-02-2018, 11:59 AM
Senior Member
thorning is on a distinguished road
Default
These can be replaced easily IF the screw holes in the plastic fin are still in decent condition. The original screw may need to be replaced with a slightly longer one. When you reattach it use Loctite on the screw threads. Also check the other fins to see if the screws are tight. If they are a little loose take them out one at a time and use some Loctite on them when you retighten them.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer Problem Hoovdawg3 Dryer Repair 1 06-10-2013 01:26 AM
Dryer Problem Again dee50 Dryer Repair 5 11-15-2011 02:12 PM
Dryer start button problem & dryer shuts off before dry tunesmithtn Dryer Repair 3 10-21-2011 02:33 AM
Dryer problem ccastleberry95@yahoo.com Dryer Repair 0 03-25-2010 01:39 PM
Dryer Problem Dryer Not Drying KQUINTANA06 Dryer Repair 1 10-22-2009 11:29 AM
