Discuss
Kenmore Electric Dryer
 in
Dryer Repair
I have a Kenmore electric dryer which is not blowing hot air. I have just replaced the heating element, thermostat
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore Electric Dryer
  #1 (permalink)
Old 11-05-2009, 10:42 AM
magico magico is offline
Junior Member
magico is on a distinguished road
Default Kenmore Electric Dryer
Brand: Kenmore   Age: 5 - 10 years
I have a Kenmore electric dryer which is not blowing hot air. I have just replaced the heating element, thermostat and the thermal fuse however these haven't solved my problem. It seems that there isn't an electrical signal being sent to the heating element for it to be told to turn on but I'm not certain in my thought process. I need to know if I need to replace the thermal cutoff or another part. Please let me know your thoughts on what direction I need to go from here. Thanks!
  #2 (permalink)
Old 11-05-2009, 07:48 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
What is the complete model number of the dryer?
You may want to check if there is 240 VAC at the wall outlet for the dryer. The motor will run on 120 VAC while the heating element needs 240 VAC.
__________________
  #3 (permalink)
Old 11-05-2009, 07:58 PM
Junior Member
Default Kenmore Dryer
Hi Gene,
The model # is 110.66712694. The dryer has a 240 line run to it as it has since it was installed over 6 years ago. I've checked the breaker and it has a double 120 line for it. It worked fine until this past Sunday. I've replaced a few parts to it already including the heating element, thermal fuse and the thermostat however the dryer isn't blowing hot air. Could the problem be the thermal cutoff? Let me know your thoughts. Thanks.
  #4 (permalink)
Old 11-05-2009, 08:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
...Could the problem be the thermal cutoff?...
Yes, it can. But I would not replace any parts without testing them for continuity. Looks like you already spend much more $$$ than it's needed. Can you post which parts you already replaced by using the reference numbers from the diagram?
Also, I'm afraid I did not get clear if you checked for proper voltage at the outlet.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore HE4 Electric Dryer thesmithfamily Dryer Repair 1 08-30-2009 02:20 PM
kenmore electric dryer calmor Dryer Repair 1 06-12-2009 11:15 AM
Kenmore Electric Dryer sandbox_91 Dryer Repair 1 03-16-2009 05:40 AM
kenmore electric dryer kadar mathura Dryer Repair 0 03-01-2009 04:02 PM
Kenmore Electric Dryer landon Dryer Repair 4 09-20-2008 10:16 PM
