Discuss
Older WP/Inglis coin op comm dryer no flame
 in
Dryer Repair
Hello, It has an older style K valve assy. Dryer would fire up then would not reignite after 1st or
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Older WP/Inglis coin op comm dryer no flame
  #1 (permalink)
Old 03-18-2018, 05:48 PM
Junior Member
tvizz15 is on a distinguished road
Unhappy Older WP/Inglis coin op comm dryer no flame
Model Number: WP75000   Brand: Whirlpool   Age: More than 10 years
Hello,
It has an older style K valve assy. Dryer would fire up then would not reignite after 1st or 2nd cycle. I removed the 3 coils and metered the coils and found booster coil was not functioning. I installed a new set of 3, and now burner doesn't ignite at all. New secondary coil measures 700 ohms/ booster coil meas 900/ holding coil meas 1200. I metered the flame sensor/ ignitor/fuse/thermostats and they seem fine. Ignitor glows but no ignition or gas smell. Odd that with old coils I got flame for 1 to 3 cycles, but nothing now. Could I have damaged valve assy installing new coils? Is there something else I could check?
Is valve assy toast?
Thanks!
Terry
Related Models
General Electric WPDH8800J0MG WASHER
General Electric WPDH8800J0MV WASHER
General Electric WPDH8800J0WW WASHER
General Electric WPDH8800J1MG WASHER
General Electric WPDH8800J1MV WASHER
General Electric WPDH8800J1WW WASHER
General Electric WPDH8800J2MG WASHER
General Electric WPDH8800J2MV WASHER
General Electric WPDH8800J2WW WASHER
General Electric WPDH8800J3MG WASHER
General Electric WPDH8800J3MV WASHER
General Electric WPDH8800J3WW WASHER
General Electric WPDH8850J0MG WASHER
General Electric WPDH8850J0MV WASHER
General Electric WPDH8850J0WW WASHER
General Electric WPDH8850J1MG WASHER
General Electric WPDH8850J1MV WASHER
General Electric WPDH8850J1WW WASHER
General Electric WPDH8850J2MG WASHER
General Electric WPDH8850J2MV WASHER
General Electric WPDH8850J2WW WASHER
General Electric WPDH8850J3MG WASHER
General Electric WPDH8850J3MV WASHER
General Electric WPDH8850J3WW WASHER
General Electric WPDH8850J4MG WASHER
General Electric WPDH8850J4MV WASHER
General Electric WPDH8850J4WW WASHER
General Electric WPDH8900J0MG WASHER
General Electric WPDH8900J0MV WASHER
General Electric WPDH8900J0WW WASHER
General Electric WPDH8900J1MG WASHER
General Electric WPDH8900J1MV WASHER
General Electric WPDH8900J1WW WASHER
General Electric WPDH8900J2MG WASHER
General Electric WPDH8900J2MV WASHER
General Electric WPDH8900J2WW WASHER
General Electric WPDH8900J3MG WASHER
General Electric WPDH8900J3MV WASHER
General Electric WPDH8900J3WW WASHER
General Electric WPDH8900J4MG WASHER
General Electric WPDH8900J4MV WASHER
General Electric WPDH8900J4WW WASHER
General Electric WPDH8910K0MG WASHER
General Electric WPDH8910K0MV WASHER
General Electric WPDH8910K0WW WASHER
General Electric WPDH8910K1MG WASHER
General Electric WPDH8910K1MV WASHER
General Electric WPDH8910K1WW WASHER
General Electric WPGT9150H0MG WASHER
General Electric WPGT9150H0WW WASHER
General Electric WPGT9350C0PL Washer
General Electric WPGT9350C0WW Washer
General Electric WPGT9360C0PL Washer
General Electric WPGT9360C0WW Washer
General Electric WPGT9360E0PL Washer
General Electric WPGT9360E0WW Washer
General Electric WPRB8050D0CC Washer
General Electric WPRB8050D0WW Washer
General Electric WPRB8050D1CC Washer
General Electric WPRB8050D1WW Washer
General Electric WPRB8350H0WT WASHER
General Electric WPRB9110D0CC Washer
General Electric WPRB9110D0WW Washer
General Electric WPRB9110D1CC Washer
General Electric WPRB9110D1WW Washer
General Electric WPRB9220C0CC Washer
General Electric WPRB9220C0WW Washer
General Electric WPRB9220C1CC Washer
General Electric WPRB9220C1WW Washer
General Electric WPRB9220D0CC Washer
General Electric WPRB9220D0WW Washer
General Electric WPRB9220D1CC Washer
General Electric WPRB9220D1WW Washer
General Electric WPRB9220DCCC Washer
General Electric WPRB9220DCWW Washer
General Electric WPRB9250C0CC Washer
General Electric WPRB9250C0WW Washer
General Electric WPRB9250D0CC Washer
General Electric WPRB9250D0WW Washer
General Electric WPRB9250D1CC Washer
General Electric WPRB9250D1WW Washer
General Electric WPRE5240D1WW Washer
General Electric WPRE6100G0WT Washer
General Electric WPRE6100G1WT WASHER
General Electric WPRE6100G2WT WASHER
General Electric WPRE6100G3WT WASHER
General Electric WPRE6150H0WT WASHER
General Electric WPRE6150H1WT WASHER
General Electric WPRE6150H2WT WASHER
General Electric WPRE6150K0WT WASHER
General Electric WPRE6150K1WT WASHER
General Electric WPRE6150K2WT WASHER
General Electric WPRE6150K3WT WASHER
General Electric WPRE6280D1WW Washer
General Electric WPRE6280DCWW Washer
General Electric WPRE8100G0WT Washer
General Electric WPRE8100G1WT WASHER
General Electric WPRE8150H0WT WASHER
General Electric WPRE8150H1WT WASHER
General Electric WPRE8150H2WT WASHER
General Electric WPRE8150K0WT WASHER
General Electric WPRE8150K1WT WASHER
General Electric WPRE8150K2WT WASHER
General Electric WPRE8150K3WT WASHER
General Electric WPRE8320H2WT WASHER
General Electric WPRE8320H3WT WASHER
General Electric WPRE8350H0WT WASHER
General Electric WPRE8350H1WT WASHER
General Electric WPRE8350H2WT WASHER
General Electric WPSB8060B0CC Washer
General Electric WPSB8060B0WW Washer
General Electric WPSB8060B1CC Washer
General Electric WPSB8060B1WW Washer
General Electric WPSB8060B9CC Washer
General Electric WPSB8060B9WW Washer
General Electric WPSB9080B0CC Washer
General Electric WPSB9080B0WW Washer
General Electric WPSB9120B0CC Washer
General Electric WPSB9120B0WW Washer
General Electric WPSE3120Y1WW Washer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Admiral gas dryer little flame at spreader, then flame at air mix port only Ocdryer Dryer Repair 3 02-16-2017 11:56 PM
coin op dryer sail4132 Dryer Repair 1 04-17-2016 04:42 PM
Inglis Dryer craziegram Dryer Repair 1 01-20-2015 08:19 PM
inglis dryer mrfixit3 Dryer Repair 4 10-15-2014 03:44 PM
dryer inglis badanjinha Dryer Repair 5 02-12-2012 02:19 AM
