Discuss
Maytag Dryer Burnt Black Wire to Heating Element
 in
Dryer Repair
I replaced the heating element 2 years ago and dryer has worked fine since. Last week, it stopped drying and
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Dryer Burnt Black Wire to Heating Element
  #1 (permalink)
Old 03-11-2018, 01:18 PM
Junior Member
jvaklh6194 is on a distinguished road
Unhappy Maytag Dryer Burnt Black Wire to Heating Element
Model Number: MDE7400AYW   Brand: Maytag   Age: More than 10 years
I replaced the heating element 2 years ago and dryer has worked fine since. Last week, it stopped drying and when I disassembled, the black wire that comes from the motor and connects to the heating element was melted and severed from the pigtail still attached to the heating element. Thinking possible loose connection, I reattached wire clamping to pigtail tightly. Ran fine for 4 loads and then same thing happened. Obviously the wire is heating to the point of melting apart as the insulation is also melted a bit down from the connection point. Heating element seems fine. Not sure what to test next. Dryer still runs on air fluff just fine. Picture attached.
Related Models
Maytag MDE7400AYW DRYER- ELE
Maytag MDE7400AZQ DRYER- ELE
Maytag MDE7400AZW DRYER- ELE
Maytag MDE7460AYQ DRYER- ELE
Maytag MDE7460AYW DRYER- ELE
Maytag MDE7500AYQ DRYER- ELE
Maytag MDE7500AYW DRYER- ELE
Maytag MDE7500AZQ DRYER- ELE
Maytag MDE7500AZW DRYER- ELE
Admiral MDE7550AGW DRYER- ELE
Maytag MDE7600AUW DRYER- ELE
Maytag MDE7600AYQ DRYER- ELE
Maytag MDE7600AYW DRYER- ELE
Maytag MDE7600AZQ DRYER- ELE
Maytag MDE7600AZW DRYER- ELE
Maytag MDE7657AYQ DRYER- ELE
Maytag MDE7657AYW DRYER- ELE
Maytag MDE7657BYQ DRYER- ELE
Maytag MDE7657BYW DRYER- ELE
Maytag MDE7658AYQ DRYER- ELE
Maytag MDE7658AYW DRYER- ELE
Maytag MDE7658BYQ DRYER- ELE
Maytag MDE7658BYW DRYER- ELE
Maytag MDE7757AYQ DRYER- ELE
Maytag MDE7757AYW DRYER- ELE
Maytag MDE7758AYQ DRYER- ELE
Maytag MDE7758AYW DRYER- ELE
Maytag MDE8000AYQ DRYER- ELE
Maytag MDE8000AYW DRYER- ELE
Maytag MDE8000AZW DRYER- ELE
Maytag MDE8057AYQ DRYER- ELE
Maytag MDE8057AYW DRYER- ELE
Maytag MDE8057AZW DRYER- ELE
Maytag MDE8058AYQ DRYER- ELE
Maytag MDE8058AYW DRYER- ELE
Maytag MDE8400AYQ DRYER- ELE
Maytag MDE8400AYW DRYER- ELE
Maytag MDE8400AZW DRYER- ELE
Maytag MDE8416AYA DRYER- ELE
Maytag MDE8416AYW DRYER- ELE
Admiral MDE8426AAW DRYER- ELE
Admiral MDE8426AGW DRYER- ELE
Maytag MDE8500AYW DRYER- ELE
Maytag MDE8506AYA DRYER- ELE
Maytag MDE8506AYW DRYER- ELE
Maytag MDE8506AZW DRYER- ELE
Admiral MDE8550AGW DRYER- ELE
Admiral MDE8550BGW DRYER- ELE
Maytag MDE8600AYQ DRYER- ELE
Maytag MDE8600AYW DRYER- ELE
Maytag MDE8600AZQ DRYER- ELE
Maytag MDE8600AZW DRYER- ELE
Maytag MDE8757AYQ DRYER- ELE
Maytag MDE8757AYW DRYER- ELE
Maytag MDE9206AYA DRYER- ELE
Maytag MDE9206AYW DRYER- ELE
Maytag MDE9206AZW DRYER- ELE
Maytag MDE9306AUW DRYER- ELE
Maytag MDE9306AYA DRYER- ELE
Maytag MDE9306AYW DRYER- ELE
Maytag MDE9306AZA DRYER- ELE
Maytag MDE9306AZW DRYER- ELE
Maytag MDE9316AYA DRYER- ELE
Maytag MDE9316AYQ DRYER- ELE
Maytag MDE9316AYW DRYER- ELE
Maytag MDE9316AZW DRYER- ELE
Maytag MDE9357AYA DRYER- ELE
Maytag MDE9357AYW DRYER- ELE
Maytag MDE9360AYW DRYER- ELE
Maytag MDE9390AYW DRYER- ELE
Maytag MDE9390AZW DRYER- ELE
Maytag MDE9420AYW DRYER- ELE
Maytag MDE9420AZW DRYER- ELE
Maytag MDE9520AYQ DRYER- ELE
Maytag MDE9520AYW DRYER- ELE
Maytag MDE9520AZW DRYER- ELE
Maytag MDE9557AYA DRYER- ELE
Maytag MDE9557AYQ DRYER- ELE
Maytag MDE9557AYW DRYER- ELE
Maytag MDE9557AZA DRYER- ELE
Maytag MDE9557AZQ DRYER- ELE
Maytag MDE9557AZW DRYER- ELE
Maytag MDE9606AUW DRYER- ELE
Maytag MDE9606AYA DRYER- ELE
Maytag MDE9606AYQ DRYER- ELE
Maytag MDE9606AYW DRYER- ELE
Maytag MDE9606AZA DRYER- ELE
Maytag MDE9606AZQ DRYER- ELE
Maytag MDE9606AZW DRYER- ELE
Maytag MDE9700AYM DRYER- ELE
Maytag MDE9700AYW DRYER- ELE
Maytag MDE9700AZM DRYER- ELE
Maytag MDE9700AZW DRYER- ELE
Maytag MDE9706AYA DRYER- ELE
Maytag MDE9706AYW DRYER- ELE
Maytag MDE9706AZW DRYER- ELE
Maytag MDE9766AYW DRYER- ELE
Maytag MDE9766AZW DRYER- ELE
Maytag MDE9800AYQ DRYER- ELE
Maytag MDE9800AYW DRYER- ELE
Maytag MDE9800AZQ DRYER- ELE
Maytag MDE9800AZW DRYER- ELE
Maytag MDE9806AYA DRYER- ELE
Maytag MDE9806AYW DRYER- ELE
Maytag MDE9806AZW DRYER- ELE
Maytag MDE9876AYW DRYER- ELE
Maytag MDET236AYW DRYER- ELE
Maytag MDET236AZW DRYER- ELE
Maytag MDET336AYW DRYER- ELE
Maytag MDET336AZW DRYER- ELE
Maytag MDET446AYW DRYER- ELE
Maytag MDET446AZW DRYER- ELE
Maytag MDG100PN1 MANUAL, PARTS (DRYER GAS)
Maytag MDG100PN1L MANUAL, PARTS (DRYER GAS)
Maytag MDG100PN1W MANUAL, PARTS (DRYER GAS)
Maytag MDG10CSAAL MANUAL, PARTS (DRYER GAS)
Maytag MDG10CSAAW MANUAL, PARTS (DRYER GAS)
Maytag MDG10CSABL MANUAL, PARTS (DRYER GAS)
Maytag MDG10CSABW MANUAL, PARTS (DRYER GAS)
Maytag MDG10CSAGL MANUAL, PARTS (DRYER GAS)
  #2 (permalink)
Old 04-12-2018, 09:10 AM
Jerry / APP Team's Avatar
Expert
Jerry / APP Team is on a distinguished road
Default
Hello Jvaklh6194,
This indicates a poor electrical connection at the point of the heating element connection Part number: AP6024180
. You will most likely need to replace the heating element to get a new, clean connection point for the wire and the wire Part number: AP3134638
will also require replacement. As a note, you will need to cut off as much wire as possible since the heat can cause deterioration of the conductivity of the wire. Of course, you should also verify good air flow through the home ducting.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Burned black wire to heating element jkantczak Dryer Repair 1 06-10-2014 04:02 AM
Burnt wire while replacing dryer heating element Pretend-repairman Dryer Repair 0 03-06-2014 03:19 PM
Maytag Glass Top Stove Element Wire Burnt off! pmaldrum Oven Repair (including Ranges and Cooktops) 1 10-07-2009 04:52 PM
Black wire to heating element keeps burning off ducky Dryer Repair 1 07-13-2009 01:17 PM
Burnt Wire to Heating Element Trigger2 Dryer Repair 0 05-21-2008 11:10 AM
