Discuss
Why are dryer sheets bad for moisture-sensing?
 in
Dryer Repair
I've read that it is bad to use "dryer sheets" with dryers that have moisture-sensing. Why is this? Is it
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Why are dryer sheets bad for moisture-sensing?
  #1 (permalink)
Old 02-20-2018, 02:00 PM
Junior Member
rschleicher is on a distinguished road
Default Why are dryer sheets bad for moisture-sensing?
Model Number: DLEX3370W   Brand: -other-   Age: Less than 1 year
I've read that it is bad to use "dryer sheets" with dryers that have moisture-sensing. Why is this? Is it just that it can confuse the moisture-sensing? Or does it cause actual problems with the moisture-sensing sensors?
The advice from the dryer maker (LG) is to use liquid fabric softener in the washer, but I have my own concerns about the long-term effects of doing this (in a front-load washer), related to spider arm corrosion.....
Related Models
 DLG0332W Dryer
 DLG0452G Dryer
 DLG0452W Dryer
 DLG1320W Dryer
Amana DLG231RAW DRYER- GAS
 DLG2522W Dryer
 DLG2524W Dryer
 DLG2525S Dryer
 DLG2526W Dryer
 DLG2532W Dryer
 DLG2602W Dryer
Amana DLG330RAW DRYER- GAS
Amana DLG330RCW DRYER- GAS
 DLG3744D Dryer
 DLG3744S Dryer
 DLG3744U Dryer
 DLG3744W Dryer
 DLG3788W Dryer
 DLG5932S Dryer
 DLG5932W Dryer
 DLG5966G Dryer
 DLG5966W Dryer
 DLG5988B Dryer
 DLG5988S Dryer
 DLG5988SM Dryer
 DLG5988W Dryer
 DLG6952W Dryer
 DLG7188RM Dryer
 DLG7188WM Dryer
 DLG8388NM Dryer
 DLG8388WM Dryer
 DLG9588SM Dryer
 DLG9588WM Dryer
 DLGX0002TM Dryer
 DLGX2802W Dryer
 DLGX3002P Dryer
 DLGX3002R Dryer
 DLGX3002W Dryer
General Electric DLL1550ABL Electric dryer
General Electric DLL1550BAL Gas dryer
General Electric DLL1550BBL Gas dryer
General Electric DLL1550BCL Gas dryer
General Electric DLL1550BDL Gas dryer
General Electric DLL1550BEL Gas dryer
General Electric DLL1550BFL Gas dryer
General Electric DLL1550BGL Gas dryer
General Electric DLL1550BHL Gas dryer
General Electric DLL1550RAL Gas dryer
General Electric DLL1550RBL Gas dryer
General Electric DLL1550RCL Gas dryer
General Electric DLL1550SBLAD Gas dryer
General Electric DLL1550SBLWH Gas dryer
General Electric DLL2450BGL Gas dryer
General Electric DLL2450BHL Gas dryer
General Electric DLL2450RAL Gas dryer
General Electric DLL2450RBL Gas dryer
General Electric DLL2450RCL Gas dryer
General Electric DLL2650ABL Electric dryer
General Electric DLL2650BAL Gas dryer
General Electric DLL2650BBL Gas dryer
General Electric DLL2650BCL Gas dryer
General Electric DLL2650BDL Gas dryer
General Electric DLL2650BEL Gas dryer
General Electric DLL2650BFL Gas dryer
General Electric DLL2650BGL Gas dryer
General Electric DLL2650BHL Gas dryer
General Electric DLL2650BJL Gas dryer
General Electric DLL2650RAL BACKSPLASH DRYER WOW
General Electric DLL2650RALWW Gas dryer
General Electric DLL2650RBL BACKSPLASH DRYER PROGRAM
General Electric DLL2650RBLWW Gas dryer
General Electric DLL2650RCL GAS DRYER
General Electric DLL2650RCLWW Gas dryer
General Electric DLL2650TA Electric dryer
General Electric DLL2654TA Electric dryer
General Electric DLL2750BAL Gas dryer
General Electric DLL2750BBL Gas dryer
General Electric DLL2880ABC Electric dryer
General Electric DLL2880BAC Electric dryer
General Electric DLL2880DAL Gas dryer
General Electric DLL2880DBL Gas dryer
General Electric DLL2880DCL Gas dryer
General Electric DLL2880DGL Gas dryer
General Electric DLL2880DHL Gas dryer
General Electric DLL2880DJL Gas dryer
General Electric DLL2880DKL Gas dryer
General Electric DLL2880DLL Gas dryer
General Electric DLL2880DML Gas dryer
General Electric DLL2880TA Electric dryer
General Electric DLL2884TA Electric dryer
General Electric DLL2884TB Electric dryer
General Electric DLL2900MAL Gas dryer
General Electric DLL2900MBL Gas dryer
General Electric DLL3280SBLWH Gas dryer
General Electric DLL3480SBLAD Gas dryer
General Electric DLL3480SBLWH Gas dryer
General Electric DLL3680SBLAD Gas dryer
General Electric DLL3680SBLWH Gas dryer
General Electric DLL3680SBLWW Gas dryer
General Electric DLL3880SBLAD Gas dryer
General Electric DLL3880SBLWH Gas dryer
General Electric DLL3880SBLWW Gas dryer
General Electric DLL3980SAM Gas dryer
General Electric DLL3980SBM Gas dryer
General Electric DLL6850AAL Electric dryer
General Electric DLL6850ABL Electric dryer
General Electric DLL6850BAL Gas dryer
General Electric DLL6850BBL Gas dryer
General Electric DLL6850BCL Gas dryer
General Electric DLL6850BDL Gas dryer
General Electric DLL6850BEL Gas dryer
General Electric DLL6850BFL Gas dryer
General Electric DLL6850BGL Gas dryer
General Electric DLL6850TA Electric dryer
General Electric DLL7596ABL Electric dryer
General Electric DLLLR23EG0WW ELECTRIC DRYER
General Electric DLLLR23EG1WW ELECTRIC DRYER
  #2 (permalink)
Old 02-21-2018, 11:53 AM
Junior Member
Default
OK, I've answered my own question. Apparently dryer sheets will over time leave a coating on the moisture-sensing metal element, making the dryer think that the load is dryer than it really is. The sheets can also leave a coating on the fine mesh of the lint filter. You can wash the lint filter in soapy water. For the moisture-sensing element, the recommendation is to use a cotton swab or cotton ball dipped in rubbing alcohol.
I have seen some posts on various web sites that indicate that LG doesn't honor their warranty on dryers, if they see that dryer sheets have been used. But this may be something that they USED to do. While LG seems to advise against the use of dryer sheets, I don't see any warnings about voiding the warranty in their owner's manual.
In any case, the moisture-sensor metal strip on my new LG dryer is mounted right onto the inner side of the lint filter housing, and would be easily cleaned. For that matter, a new metal element is a cheap part, and seems easily replaced....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Not sensing moisture content jbw2585 Dryer Repair 0 03-11-2014 09:40 AM
Kenmore gas dryer timer not moving when using auto moisture sensing dding0919 Dryer Repair 0 02-11-2014 10:30 AM
dryer only heats on moisture sensing cycle more dry setting jwilcoxen Dryer Repair 0 02-15-2012 08:51 PM
How do I adjust the Moisture Sensing circuit johnerbes Dryer Repair 1 03-07-2008 04:54 PM
Auto Moisture Sensing Plus not working mschmero Dryer Repair 2 01-06-2008 11:55 AM
