Discuss
Kenmore elite he3, heats even in air fluff
 in
Dryer Repair
My Kenmore elite dryer will run hot even when itís on air fluff. All 4 fuses have been changed, with
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore elite he3, heats even in air fluff
  #1 (permalink)
Old 02-20-2018, 01:05 PM
Junior Member
Tjacques84 is on a distinguished road
Default Kenmore elite he3, heats even in air fluff
Model Number: 11087872603   Brand: Kenmore   Age: 5 - 10 years
My Kenmore elite dryer will run hot even when itís on air fluff. All 4 fuses have been changed, with same result. I had a technician come out and look at it, he said it was the control panel motherboard. I took the motherboard out and looked at it but it looks to be in perfect shape. There is also no error code when the diagnostic test his run. Do I put out the $200 for the motherboard and chance it that this is the real problem?
Related Models
Kenmore 11087872603 RESIDENTIAL DRYER
Kenmore 11087872700 DRYER
Kenmore 11087872800 DRYER
Kenmore 11087873100 DRYER
Kenmore 11087873300 DRYER
Kenmore 11087873600 DRYER
Kenmore 11087873700 DRYER
Kenmore 11087873800 DRYER
Kenmore 11087874100 DRYER
Kenmore 11087874300 DRYER
Kenmore 11087874600 DRYER
Kenmore 11087874700 DRYER
Kenmore 11087874800 DRYER
Kenmore 11087878100 DRYER
Kenmore 11087878300 DRYER
Kenmore 11087878600 DRYER
Kenmore 11087878700 DRYER
Kenmore 11087878800 DRYER
Kenmore 11087879100 DRYER
Kenmore 11087879300 DRYER
Kenmore 11087879600 DRYER
Kenmore 11087879700 DRYER
Kenmore 11087879800 DRYER
Kenmore 11087880100 DRYER
Kenmore 11087880300 DRYER
Kenmore 11087880600 DRYER
Kenmore 11087880700 DRYER
Kenmore 11087880800 DRYER
Kenmore 11087884300 GAS DRYER
Kenmore 11087884600 GAS DRYER
Kenmore 11087884700 GAS DRYER
Kenmore 11087884800 GAS DRYER
Kenmore 11087892601 DRYER
Kenmore 11087892602 RESIDENTIAL DRYER
Kenmore 11087894100 GAS DRYER
Kenmore 11087894300 GAS DRYER
Kenmore 11087894500 GAS DRYER
Kenmore 11087894700 GAS DRYER
Kenmore 11087894800 GAS DRYER
Kenmore 11087980100 GAS DRYER
Kenmore 11087982100 GAS DRYER
Kenmore 11087982110 KENMORE DISPOSER
Kenmore 11087982300 GAS DRYER
Kenmore 11087982310 DRYER
Kenmore 11087982700 GAS DRYER
Kenmore 11087982710 DRYER
Kenmore 11087982800 GAS DRYER
Kenmore 11087982810 DRYER
Kenmore 11087983100 DRYER
Kenmore 11087983110 GAS DRYER
Kenmore 11087983130 GAS DRYER
Kenmore 11087983300 DRYER
Kenmore 11087983310 GAS DRYER
Kenmore 11087983700 DRYER
Kenmore 11087983710 GAS DRYER
Kenmore 11087983800 DRYER
Kenmore 11087983810 GAS DRYER
Kenmore 11087983830 GAS DRYER
Kenmore 11087984100 GAS DRYER
Kenmore 11087984110 GAS DRYER
Kenmore 11087984120 GAS DRYER
Kenmore 11087984300 GAS DRYER
Kenmore 11087984310 GAS DRYER
Kenmore 11087984700 GAS DRYER
Kenmore 11087984710 GAS DRYER
Kenmore 11087984800 GAS DRYER
Kenmore 11087984810 GAS DRYER
Kenmore 11087984820 GAS DRYER
Kenmore 11087992100 GAS DRYER
Kenmore 11087992300 GAS DRYER
Kenmore 11087992700 GAS DRYER
Kenmore 11087992800 GAS DRYER
Kenmore 11087993100 GAS DRYER
Kenmore 11087993110 GAS DRYER
Kenmore 11087993300 GAS DRYER
Kenmore 11087993310 GAS DRYER
Kenmore 11087993500 GAS DRYER
Kenmore 11087993510 GAS DRYER
Kenmore 11087993700 GAS DRYER
Kenmore 11087993710 GAS DRYER
Kenmore 11087993800 GAS DRYER
Kenmore 11087993810 GAS DRYER
Kenmore 11087994100 DRYER
Kenmore 11087994300 DRYER
Kenmore 11087994500 DRYER
Kenmore 11087994700 DRYER
Kenmore 11087994800 DRYER
Kenmore 11088090100 ELECTRIC DRYER
Kenmore 11088090200 ELECTRIC DRYER
Kenmore 11088090400 ELECTRIC DRYER
Kenmore 11088090600 ELECTRIC DRYER
Kenmore 11088090800 ELECTRIC DRYER
Kenmore 11088182890 ELECTRIC DRYER
Kenmore 11088182891 COMPACT ELECTRIC DRYER
Kenmore 11088184890 ELECTRIC DRYER
Kenmore 11088184891 COMPACT ELECTRIC DRYER
Kenmore 11088390100 ELECTRIC DRYER
Kenmore 11088390110 ELECTRIC DRYER
Kenmore 11088390120 ELECTRIC DRYER
Kenmore 11088390130 ELECTRIC DRYER
Kenmore 11088390200 ELECTRIC DRYER
Kenmore 11088390210 ELECTRIC DRYER
Kenmore 11088390300 ELECTRIC DRYER
Kenmore 11088390310 ELECTRIC DRYER
Kenmore 11088390320 ELECTRIC DRYER
Kenmore 11088390330 ELECTRIC DRYER
Kenmore 11088390400 ELECTRIC DRYER
Kenmore 11088390410 ELECTRIC DRYER
Kenmore 11088390600 ELECTRIC DRYER
Kenmore 11088390610 ELECTRIC DRYER
Kenmore 11088390620 ELECTRIC DRYER
Kenmore 11088390630 ELECTRIC DRYER
Kenmore 11088390700 ELECTRIC DRYER
Kenmore 11088390710 ELECTRIC DRYER
Kenmore 11088390720 ELECTRIC DRYER
Kenmore 11088390730 ELECTRIC DRYER
Kenmore 11088390800 ELECTRIC DRYER
Kenmore 11088390810 ELECTRIC DRYER
Kenmore 11088390820 ELECTRIC DRYER
Kenmore 11088390830 ELECTRIC DRYER
  #2 (permalink)
Old 03-01-2018, 03:25 PM
Senior Member
brobriffin is on a distinguished road
Default
Did you service tech happen to check if the heating element was shorted out against the heating can? If so this to would cause the dryer to have heat in air mode.
If the element is good then it is likely the control board, the heater relay is stuck closed likely.
As for spending the money on the control board, you can purchase right here
Whirlpool WPW10174745 Electronic Control Board - AppliancePartsPros.com
and if it isn't your solution we have a 365 day return policy...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
KENMORE ELITE: Hums and inside heats up when closing the door. vignesh Microwave Repair 1 11-19-2017 04:03 PM
Whirlpool dryer element heats on fluff 1911bud Dryer Repair 2 08-27-2011 12:24 PM
Dryer Heats on Fluff cycle LeeHar Dryer Repair 0 07-25-2010 05:54 PM
Kenmore Elite H3 - Heats up initially but then stops heating. anonymouscuban Dryer Repair 2 01-07-2010 07:52 PM
Kenmore Elite dryer heats then stops toothfxr Dryer Repair 0 09-06-2009 08:12 AM
