Discuss
Maytag Bravos Dryer "no heat"
 in
Dryer Repair
I know its time for help now. I have the above mentioned dryer that will not heat in any setting.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Bravos Dryer "no heat"
  #1 (permalink)
Old 02-08-2018, 09:29 AM
Senior Member
brobriffin is on a distinguished road
Unhappy Maytag Bravos Dryer "no heat"
Model Number: MEDB400VQ0   Brand: Maytag   Age: 5 - 10 years
Things checked and done:
1. All thermostats, thermal fuses and heating element have continuity.
2. Both the inlet and exhaust thermistors ohm correctly both at the control panel and on the thermistors alone, both thermistors reduce resistance when heated as per manufacturer specs.
3. No continuity across heater relay when running.
4. 123v on L1 & L2
5. 123v to both sides of relay when running while connection unplugged (centrifugal switch is sending power thru to red wire)
6. Replaced control board (same results)
7. Diagnostic test with new board stored error code F31 (must be an old result as both L1 and L2 are at 123v)
8. Diagnostic test (running the motor and heater) interestingly the heater works??????? which indicates the control board can close the heater relay.
So now I pose the question, why will the heater work in diagnostic mode but not in any regular cycle?
Related Models
Maytag MEDB400VQ0 27" ELECTRIC DRYER
Maytag MEDB700VQ0 27" ELECTRIC DRYER
Maytag MEDB800VB0 27" ELECTRIC DRYER
Maytag MEDB800VQ0 27" ELECTRIC DRYER
Maytag MEDB800VU0 27" ELECTRIC DRYER
Maytag MEDB850WB0 27" ELECTRIC DRYER
Maytag MEDB850WL0 27" ELECTRIC DRYER
Maytag MEDB850WQ0 27" ELECTRIC DRYER
Maytag MEDB850WR0 27" ELECTRIC DRYER
Maytag MEDC400VW0 29" ELECTRIC DRYER
Maytag MEDC500VW0 29" ELECTRIC DRYER
Maytag MEDC500VW1 29" ELECTRIC DRYER
Maytag MEDC700VJ0 27" ELECTRIC DRYER
Maytag MEDC700VW0 27" ELECTRIC DRYER
Maytag MEDE200XW0 27" ELECTRIC DRYER
Maytag MEDE200XW1 27" ELECTRIC DRYER
Maytag MEDE250XL0 27" ELECTRIC DRYER
Maytag MEDE300VF0 29" ELECTRIC DRYER
Maytag MEDE300VF1 29" ELECTRIC DRYER
Maytag MEDE300VF2 29" ELECTRIC DRYER
Maytag MEDE300VW0 29" ELECTRIC DRYER
Maytag MEDE300VW1 29" ELECTRIC DRYER
Maytag MEDE400XR0 29" ELECTRIC DRYER
Maytag MEDE400XW0 29" ELECTRIC DRYER
Maytag MEDE500VF0 29" ELECTRIC DRYER
Maytag MEDE500VF1 29" ELECTRIC DRYER
Maytag MEDE500VP0 29" ELECTRIC DRYER
Maytag MEDE500VP1 29" ELECTRIC DRYER
Maytag MEDE500VW0 29" ELECTRIC DRYER
Maytag MEDE500VW1 29" ELECTRIC DRYER
Maytag MEDE500WJ0 29" ELECTRIC DRYER
Maytag MEDE500WR0 29" ELECTRIC DRYER
Maytag MEDE900VJ0 29" ELECTRIC DRYER
Maytag MEDE900VJ1 29" ELECTRIC DRYER
Maytag MEDE900VW0 29" ELECTRIC DRYER
Maytag MEDE900VW1 29" ELECTRIC DRYER
Maytag MEDX500XL0 27" ELECTRIC DRYER
Maytag MEDX500XW0 27" ELECTRIC DRYER
Maytag MEDX550XW0 27" ELECTRIC DRYER
Maytag MEDX600XW0 27" ELECTRIC DRYER
Maytag MEDZ400TQ1 27" Electric Dryer
Maytag MEDZ400TQ2 27" Electric Dryer
Maytag MEDZ600TB1 27" Electric Dryer
Maytag MEDZ600TB2 27" ELECTRIC DRYER
Maytag MEDZ600TE2 27" ELECTRIC DRYER
Maytag MEDZ600TK1 27" Electric Dryer
Maytag MEDZ600TK2 27" ELECTRIC DRYER
Maytag MEDZ600TW1 27" Electric Dryer
Maytag MEDZ600TW2 27" ELECTRIC DRYER
Maytag MEDZ600WR0 27" ELECTRIC DRYER
Frigidaire MEF200PBDA Frg(v2) / Electric Range
Frigidaire MEF200PBDB Frg(v1) / Electric Range
Frigidaire MEF200PBWA Frg(v1) / Electric Range
Frigidaire MEF200PBWB Frg(v2) / Electric Range
Frigidaire MEF203PBDA Frg(v4) / Electric Range
Frigidaire MEF203PBDB Frg(v3) / Electric Range
Frigidaire MEF203PBWA Frg(v3) / Electric Range
Frigidaire MEF203PBWB Frg(v4) / Electric Range
Frigidaire MEF300PBDA Frg(v1) / Electric Range
Frigidaire MEF300PBDB Wwh(v1) / Electric Range
Frigidaire MEF300PBDC Wwh(v2) / Electric Range
Frigidaire MEF300PBDD Frg(v1) / Electric Range
Frigidaire MEF300PBDE Frg(v1) / Electric Range
Frigidaire MEF300PBDF Frg(v1) / Electric Range
Frigidaire MEF300PBDG Frg(v1) / Electric Range
Frigidaire MEF300PBDH Frg(v1) / Electric Range
Frigidaire MEF300PBDJ Frg(v1) / Electric Range
Frigidaire MEF300PBDK Frg(v1) / Electric Range
Frigidaire MEF300PBWA Frg(v2) / Electric Range
Frigidaire MEF300PBWB Wwh(v3) / Electric Range
Frigidaire MEF300PBWC Wwh(v4) / Electric Range
Frigidaire MEF300PBWD Kel(v14) / Electric Range
Frigidaire MEF300PBWE Frg(v2) / Electric Range
Frigidaire MEF300PBWF Frg(v2) / Electric Range
Frigidaire MEF300PBWG Frg(v2) / Electric Range
Frigidaire MEF300PBWH Frg(v2) / Electric Range
Frigidaire MEF300PBWJ Frg(v2) / Electric Range
Frigidaire MEF300PBWK Frg(v2) / Electric Range
Frigidaire MEF300PXWA Frg(v0) / Electric Range
Frigidaire MEF300PXWB Frg(v0) / Electric Range
Frigidaire MEF300PXWC Frg(v0) / Electric Range
Frigidaire MEF300PXWD Frg(v0) / Electric Range
Frigidaire MEF300PXWE Frg(v0) / Electric Range
Frigidaire MEF300PXWF Frg(v1) / Electric Range
Frigidaire MEF300PXWG Frg(v2) / Electric Range
Frigidaire MEF300PXWH Frg(v3) / Electric Range
Frigidaire MEF301PBDA Frg(v3) / Electric Range
Frigidaire MEF301PBDB Wwh(v1) / Electric Range
Frigidaire MEF301PBDC Wwh(v2) / Electric Range
Frigidaire MEF301PBDD Kel(v15) / Electric Range
Frigidaire MEF301PBDE Frg(v3) / Electric Range
Frigidaire MEF301PBDF Frg(v1) / Electric Range
Frigidaire MEF301PBDG Frg(v1) / Electric Range
Frigidaire MEF301PBDH Frg(v1) / Electric Range
Frigidaire MEF301PBDJ Frg(v3) / Electric Range
Frigidaire MEF301PBDK Frg(v3) / Electric Range
Frigidaire MEF301PBWA Frg(v4) / Electric Range
Frigidaire MEF301PBWB Wwh(v3) / Electric Range
Frigidaire MEF301PBWC Wwh(v4) / Electric Range
Frigidaire MEF301PBWD Gib(v10) / Electric Range
Frigidaire MEF301PBWE Frg(v4) / Electric Range
Frigidaire MEF301PBWF Frg(v2) / Electric Range
Frigidaire MEF301PBWG Frg(v2) / Electric Range
Frigidaire MEF301PBWH Frg(v2) / Electric Range
Frigidaire MEF301PBWJ Frg(v4) / Electric Range
Frigidaire MEF301PBWK Frg(v4) / Electric Range
Frigidaire MEF302PBDA Frg(v2) / Electric Range
Frigidaire MEF302PBDB Kel(v1) / Electric Range
Frigidaire MEF302PBDC Wwh(v1) / Electric Range
Frigidaire MEF302PBDD Gib(v11) / Electric Range
Frigidaire MEF302PBDE Frg(v5) / Electric Range
Frigidaire MEF302PBDF Frg(v3) / Electric Range
Frigidaire MEF302PBDG Frg(v1) / Electric Range
Frigidaire MEF302PBDH Frg(v1) / Electric Range
Frigidaire MEF302PBDJ Frg(v1) / Electric Range
Frigidaire MEF302PBDK Frg(v1) / Electric Range
Frigidaire MEF302PBWA Frg(v1) / Electric Range
Frigidaire MEF302PBWB Wwh(v2) / Electric Range
Frigidaire MEF302PBWC Wwh(v3) / Electric Range
Frigidaire MEF302PBWD Gib(v12) / Electric Range
  #2 (permalink)
Old 02-08-2018, 05:39 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
I had a weird one once. It had 240 to the back of it, but it wouldn't heat. I checked everything...the element, thermostats, switches, motor switch, and the timer. All tested OK, but no heat.
I finally tested the power coming in when I pushed the start button. 240 push the button dryer is running, 120 volts. One side was loosing voltage somewhere. Stop the dryer and the 120 would slowly go up to 240 again.
Turns out there were bad connections on the one side of the knife switch in the disconnect box. it wasn't able to handle any amperage, but it did show voltage when cool and not under a load.
I also wonder if the control panel could be somehow stuck on air fluff. Mechanically or electronically.
Just throwing a few things out there.
  #3 (permalink)
Old 02-09-2018, 10:29 AM
Senior Member
Default
Update
Thanks ThatGuy
So I checked for 240 again across the red and black leads at the heat relay and I do get 245v
I swapped back to my original control board and wouldn't you know it when i put it in diagnostic mode I get heat but not when in any normal cycle (BTW heat is not controlled by the thermistors during diag mode, as I watched the temp climb to 177 not cycling and the unit shut down)
I double checked for resistance coming in from the inlet and exhaust thermistors and still have correct readings
The only thing that might be it is as you stated ThatGuy the mode is stuck in air fluff but it must be at the UI because two boards with identical issues would be very curious
So my question then would be if the UI can be switched from air fluff to extra low - low - medium and high settings could it be an issue with the UI itself?
  #4 (permalink)
Old 02-09-2018, 02:22 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
I don't know much about this particular dryer. It's very unlikely that you would have two control boards that have the same problem. Unless the "new" one was not new, but one somebody returned.
Its really looking more like a problem with the user interface board. That or the wiring in between.
  #5 (permalink)
Old 04-12-2018, 01:41 PM
Senior Member
Default
update:
so I found some spare funds and bought a used UI from e bay...
finally success we have heat....
thanks for the suggestion thatguy.... every repair is a learning experience
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Bravos XL washer giving FL code on "Deep Water Wash" setting Hokie58 Washer Repair 0 12-03-2017 06:10 AM
Bosch dryer stops, beeps, "Drying" and "End" lights on endyem Dryer Repair 3 12-31-2016 03:08 PM
maytag washer bravos error code "ol" rrubberbandman Washer Repair 4 01-24-2015 10:52 AM
Maytag "Bravos" wont spin after the drain cycle ChuckMc99 Washer Repair 3 11-06-2013 03:13 PM
Maytag Bravos "LF" code Marsie Washer Repair 6 06-14-2013 08:17 PM
