Discuss
Electric dryer squeaking, squealing, and screaming.
 in
Dryer Repair
Hi! So I have this Kenmore Laundry center (stacked washer dryer unit) which has recently been having some issues. For
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Electric dryer squeaking, squealing, and screaming.
  #1 (permalink)
Old 01-11-2018, 05:26 PM
Junior Member
Kurtzero is on a distinguished road
Default Electric dryer squeaking, squealing, and screaming.
Brand: Kenmore   Age: 5 - 10 years
Hi! So I have this Kenmore Laundry center (stacked washer dryer unit) which has recently been having some issues. For a little while the dryer would struggle to turn at first but then run normally, then, inexplicably that problem went away and was replaced by a loud squeaking which a day later turned into a screeching screaming noise.. I took it apart, cleaned it pretty thoroughly on the inside, replaced the idler pulley/arm and the rollers. I lubed every spinning part I could think of and checked all the seals for anything stuck that could be grinding. Still the issue persists. Wondering if anyone has any advice for some next steps to check out. Iíll provide a link below to a video I made of the sound in action (didnít catch it doing the full piercing screech because that usually takes a knitter to kick in) as well as some pics I took along the way taking it apart. Any help would be supremely appreciated. Thanks!
https://youtu.be/WfL2b56SwLs
https://imgur.com/gallery/gMJUE
https://imgur.com/a/pmHhb
https://imgur.com/gallery/x8yxK
  #2 (permalink)
Old 01-11-2018, 05:31 PM
Junior Member
Default
Found the model number online, seems to be this unit #1101820296
https://www.************************...2/0152000.html
  #3 (permalink)
Old 01-13-2018, 07:11 AM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Did you change the belt? It kinda sounds like the motor bearings.
  #4 (permalink)
Old 01-13-2018, 07:26 AM
Junior Member
Default
Not yet. The one I bought was the wrong size. I ordered a new one along with anew blower fan which someone suggested it could be. If it is the motor bearing does that require replacing the whole motor or is that something repairable?
  #5 (permalink)
Old 01-14-2018, 06:49 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
Unfortunately, the whole motor. No serviceable parts.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer squealing and squeaking loudly upmawmaw Dryer Repair 3 07-29-2012 03:52 PM
Electric dryer squealing kenbreedlove Dryer Repair 2 01-16-2012 05:38 AM
GE electric dryer squealing noise Bella415 Dryer Repair 0 09-22-2011 08:29 AM
squeaking GE electric dryer mrwigman Dryer Repair 1 06-02-2009 05:19 PM
Electric Dryer Squeaking gander Dryer Repair 2 01-31-2009 10:53 AM
