Discuss
Dryer Motor clamp / clip installation technique ?
 in
Dryer Repair
Hi, Had to replace my dryer motor with a new motor (W10410996), and having extreme difficulty in putting back the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Motor clamp / clip installation technique ?
  #1 (permalink)
Old 12-09-2017, 01:07 PM
Junior Member
diydude99 is on a distinguished road
Default Dryer Motor clamp / clip installation technique ?
Brand: Maytag   Age: More than 10 years
Had to replace my dryer motor with a new motor (W10410996), and having extreme difficulty in putting back the original motor clamp/clip in front of the pulley.
Can only get one side on, but the other side won't hook in. No matter if I hit it straight down or at an inwards angle. Spent hours already. Something so simple can't take this long...
Maytag Performa Dryer PYE2300AYW
Motor retaining clamp/clip Part WP660658
Should I have ordered a new clamp? It looks exactly like the same as the original. Is there a new design so it hooks it easier for the other side?
Thanks for any suggestions!
  #2 (permalink)
Old 12-09-2017, 05:17 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Make sure the clamp or the motor mount aren't bent. Here is a video. The important part starts at 3:30.
https://www.youtube.com/watch?v=hx5RkCetL8E
  #3 (permalink)
Old 12-13-2017, 02:43 PM
Junior Member
Default
Thanks for the response.
Finally resolved the issue after buying a new clamp, and tried it on. Didn't fit either so looked at the mount closely, and realized there is a little round notch in the middle of mount bracket.
Looked at the rubber gasket of the motor and it has a male round notch that should line up to the round notch on the mount bracket. Once motor was repositioned on the mount with the round notches matching up, the clamp installed onto the other ear with no issue.
So the little notch does make a difference in whether the clamp will hook onto the other ear. Hope this helps the next guy.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Thrust Bearing C-Clip Technique mb129 Washer Repair 2 02-06-2015 03:08 PM
re-installation of motor thurston Washer Repair 1 06-17-2010 05:14 AM
problems with fan motor not working, frig wire orientation in relation to fan clip et ddgiz Refrigerator & Freezer Repair 1 04-30-2010 04:25 AM
Heubsch Motor installation wayne bodle Dryer Repair 0 05-03-2009 04:52 AM
Electric dryer motor clamp replacement help. mackb4 Dryer Repair 2 04-26-2009 05:19 AM
