Discuss
Kenmore Dryer wont stay running
 in
Dryer Repair
I have a Kenmore Elite model 11072932100 Gas Dryer. When I push the start button it starts. When I let
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore Dryer wont stay running
  #1 (permalink)
Old 12-09-2017, 11:54 AM
Junior Member
dsomers6538 is on a distinguished road
Default Kenmore Dryer wont stay running
Model Number: 11072932100   Brand: Kenmore   Age: More than 10 years
I have a Kenmore Elite model 11072932100 Gas Dryer. When I push the start button it starts. When I let it go it shuts off. Any ideas? Not the switch or timer.
Related Models
Kenmore 11072932100 GAS DRYER
Kenmore 11072936100 GAS DRYER
Kenmore 11072940100 AUTOMATIC WASHER
Kenmore 11072940110 AUTOMATIC WASHER
Kenmore 11072942100 DRYER
Kenmore 11072950100 AUTOMATIC WASHER
Kenmore 11072950110 AUTOMATIC WASHER
Kenmore 11072950120 AUTOMATIC WASHER
Kenmore 11072950200 AUTOMATIC WASHER
Kenmore 11072950210 AUTOMATIC WASHER
Kenmore 11072950220 AUTOMATIC WASHER
Kenmore 11072950400 AUTOMATIC WASHER
Kenmore 11072950410 AUTOMATIC WASHER
Kenmore 11072950420 AUTOMATIC WASHER
Kenmore 11072950600 AUTOMATIC WASHER
Kenmore 11072950610 AUTOMATIC WASHER
Kenmore 11072950620 AUTOMATIC WASHER
Kenmore 11072950800 AUTOMATIC WASHER
Kenmore 11072950810 AUTOMATIC WASHER
Kenmore 11072950820 AUTOMATIC WASHER
Kenmore 11072952100 DRYER
Kenmore 11072954100 DRYER
Kenmore 11072955100 AUTOMATIC WASHER
Kenmore 11072955110 AUTOMATIC WASHER
Kenmore 11072955120 AUTOMATIC WASHER
Kenmore 11072955130 ELECTRIC WASHER
Kenmore 11072955200 AUTOMATIC WASHER
Kenmore 11072955210 AUTOMATIC WASHER
Kenmore 11072955220 AUTOMATIC WASHER
Kenmore 11072955230 ELECTRIC WASHER
Kenmore 11072955400 AUTOMATIC WASHER
Kenmore 11072955410 AUTOMATIC WASHER
Kenmore 11072955420 AUTOMATIC WASHER
Kenmore 11072955430 ELECTRIC WASHER
Kenmore 11072955600 AUTOMATIC WASHER
Kenmore 11072955610 AUTOMATIC WASHER
Kenmore 11072955620 AUTOMATIC WASHER
Kenmore 11072955630 ELECTRIC WASHER
Kenmore 11072955800 AUTOMATIC WASHER
Kenmore 11072955810 AUTOMATIC WASHER
Kenmore 11072955820 AUTOMATIC WASHER
Kenmore 11072955830 ELECTRIC WASHER
Kenmore 11072956100 DRYER
Kenmore 11072960100 AUTOMATIC WASHER
Kenmore 11072960110 AUTOMATIC WASHER
Kenmore 11072960200 AUTOMATIC WASHER
Kenmore 11072960210 AUTOMATIC WASHER
Kenmore 11072960400 AUTOMATIC WASHER
Kenmore 11072960410 AUTOMATIC WASHER
Kenmore 11072960600 AUTOMATIC WASHER
Kenmore 11072960610 AUTOMATIC WASHER
Kenmore 11072960800 AUTOMATIC WASHER
Kenmore 11072960810 AUTOMATIC WASHER
Kenmore 11072965100 AUTOMATIC WASHER
Kenmore 11072965110 AUTOMATIC WASHER
Kenmore 11072965130 ELECTRIC WASHER
Kenmore 11072965140 SEARS ELECTRIC WASHER
Kenmore 11072965200 AUTOMATIC WASHER
Kenmore 11072965210 AUTOMATIC WASHER
Kenmore 11072965230 ELECTRIC WASHER
Kenmore 11072965240 SEARS ELECTRIC WASHER
Kenmore 11072965400 AUTOMATIC WASHER
Kenmore 11072965410 AUTOMATIC WASHER
Kenmore 11072965430 ELECTRIC WASHER
Kenmore 11072965440 SEARS ELECTRIC WASHER
Kenmore 11072965600 AUTOMATIC WASHER
Kenmore 11072965610 AUTOMATIC WASHER
Kenmore 11072965630 ELECTRIC WASHER
Kenmore 11072965640 SEARS ELECTRIC WASHER
Kenmore 11072965800 AUTOMATIC WASHER
Kenmore 11072965810 AUTOMATIC WASHER
Kenmore 11072965830 ELECTRIC WASHER
Kenmore 11072965840 SEARS ELECTRIC WASHER
Kenmore 11072966100 AUTOMATIC WASHER
Kenmore 11072966110 AUTOMATIC WASHER
Kenmore 11072966200 AUTOMATIC WASHER
Kenmore 11072966210 AUTOMATIC WASHER
Kenmore 11072966400 AUTOMATIC WASHER
Kenmore 11072966410 AUTOMATIC WASHER
Kenmore 11072966600 AUTOMATIC WASHER
Kenmore 11072966610 AUTOMATIC WASHER
Kenmore 11072966800 AUTOMATIC WASHER
Kenmore 11072966810 AUTOMATIC WASHER
Kenmore 11072967100 AUTOMATIC WASHER
Kenmore 11072967110 AUTOMATIC WASHER
Kenmore 11072967120 SEARS AUTOMATIC WASHER
Kenmore 11072967200 AUTOMATIC WASHER
Kenmore 11072967210 AUTOMATIC WASHER
Kenmore 11072967220 SEARS AUTOMATIC WASHER
Kenmore 11072967400 AUTOMATIC WASHER
Kenmore 11072967410 AUTOMATIC WASHER
Kenmore 11072967420 SEARS AUTOMATIC WASHER
Kenmore 11072967600 AUTOMATIC WASHER
Kenmore 11072967610 AUTOMATIC WASHER
Kenmore 11072967620 SEARS AUTOMATIC WASHER
Kenmore 11072967800 AUTOMATIC WASHER
Kenmore 11072967810 AUTOMATIC WASHER
Kenmore 11072967820 SEARS AUTOMATIC WASHER
Kenmore 11072970100 AUTOMATIC WASHER
Kenmore 11072970110 AUTOMATIC WASHER
Kenmore 11072970200 AUTOMATIC WASHER
Kenmore 11072970210 AUTOMATIC WASHER
Kenmore 11072970400 AUTOMATIC WASHER
Kenmore 11072970410 AUTOMATIC WASHER
Kenmore 11072970600 AUTOMATIC WASHER
Kenmore 11072970610 AUTOMATIC WASHER
Kenmore 11072970800 AUTOMATIC WASHER
Kenmore 11072970810 AUTOMATIC WASHER
Kenmore 11072972101 GAS DRYER
Kenmore 11072972102 GAS DRYER
Kenmore 11072972103 GAS DRYER
Kenmore 11072974100 AUTOMATIC WASHER
Kenmore 11072974101 GAS DRYER
Kenmore 11072974102 GAS DRYER
Kenmore 11072974103 GAS DRYER
Kenmore 11072974110 AUTOMATIC WASHER
Kenmore 11072974120 AUTOMATIC WASHER
Kenmore 11072974200 AUTOMATIC WASHER
Kenmore 11072974210 AUTOMATIC WASHER
Kenmore 11072974220 AUTOMATIC WASHER
  #2 (permalink)
Old 12-16-2017, 06:24 AM
Senior Member
brobriffin is on a distinguished road
Default
What you explain is a symptom of a bad centrifugal switch on the motor.
Pushing the start button sends power to start the motor. When it spins to a certain speed a centrifugal switch closes and thus continues the power to run the motor as well as the heating element. If this switch isn't closing (possibly due to lint build up or other factors) the motor won't continue to run. If the contacts in the switch are bad or broken it won't continue to run.
The motor will need to be replaced.
Here is the part you need.
Whirlpool 279787 Dryer Drive Motor - AppliancePartsPros.com
  #3 (permalink)
Old 12-18-2017, 07:30 AM
Senior Member
thorning is on a distinguished road
Default
Sometimes you can take the switch apart and free up the contacts if they are stuck open, Also you can usually move the centrifugal switch activating ring on the motor shaft by using a small screwdriver inserted from the top of the motor (make sure the unit is disconnected from the power). It should move back and forth against the springs that are part of the mechanism and it will snap open and snap back when you remove the screwdriver.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer wont stay running aintmyprob Dryer Repair 1 06-18-2014 05:05 AM
Dryer Wont stay running stevenkimbell Dryer Repair 0 08-26-2012 10:19 AM
Dryer wont stay running TPost Dryer Repair 1 02-22-2009 03:24 AM
Kenmore gas dryer wont stay running kthomas Dryer Repair 0 02-12-2008 12:57 PM
Kenmore Evenheat wont stay running jlp0360 Dryer Repair 0 01-23-2008 04:22 PM
