Discuss
LG Dryer Igniter Cycles, but rarely flames and I smell Gas
 in
Dryer Repair
Dryer is an LG DLG0332W, SN is 303Kw 00589 if it helps. First symptom was that clothes were only barely
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » LG Dryer Igniter Cycles, but rarely flames and I smell Gas
  #1 (permalink)
Old 12-06-2017, 11:47 AM
Junior Member
afb2r is on a distinguished road
Unhappy LG Dryer Igniter Cycles, but rarely flames and I smell Gas
Model Number: DLG0332W   Brand: -other-   Age: 5 - 10 years
First symptom was that clothes were only barely luke warm after dryings so my first thought was the vent hose. Vent hose was chock full of lint so I cleaned it out and I ran the dryer unattached to get that out of the equation.
First try, after only detaching vent I felt hot air come from unit for about 5-15 seconds then it shut off. I immediately turned dryer off, disassembled and cleaned it thoroughly with shop vac. I also made sure the fuse switch on one of the thermostats wasn't popped, it wasn't.
Second try, dryer seemed to heat a little longer, cycling flame off after about 30-60 seconds, but then flame would not come back on. I also got a distinct smell of gas coming out of machine during the time of what I assume was the subsequent flame cycles. I disassembled again and checked continuity on the ignitor which I read as about 130 Ohms which seems to be okay from the manual.
Third try, I ran the dryer on high heat setting with the front panel plate off, holding a piece of plastic over door to keep an airflow seal. What I observe is as follows:
- Dum begins to spin for about 5-10 seconds
- Igniter lights up for about 10 seconds and then flame occurs
- Flame lasts about 30-60 seconds I would say and then goes out
- After about a minute or so igniter will relight for a short duration (maybe 5 or so seconds) just get to bright orange and then immediately start to go out with no flame
- The igniter will cycle like this throughout the dryer cycle (I've only ever let it go on for about 2-5 cycles). It will catch flame on rare occasion, but usually just cycles on and off with no flame
- I generally tend to get a strong smell of gas when the above occurs, I haven't pinpointed exactly when the gas comes out, but assume it is during the cycle misfires. This is weird to me, because if I smell gas and have a bright orange ignitor where is the flame? Maybe the timing is off?
At this point I have removed the drum to start testing components other than the igniter (which is the only one I could reach with drum on). I am a little unsure how to go about testing because per the manual a lot of the components need to be heated in order to test, and how do I achieve that? Can I run the machine with drum off? Heat Gun?
Any help at this point would be greatly appreciated. I tend to think it may be my gas valve, but I don't want to spend $120 on a part I don't need. Coils for this valve are not made, whole valve needs to be replaced. Could it even be my flame sensor, thermostats or thermistor? I've even read some far fetched posts about it possibly being a control board...
Thank you!
Related Models
 DLG0332W Dryer
 DLG0452G Dryer
 DLG0452W Dryer
 DLG1320W Dryer
Amana DLG231RAW DRYER- GAS
 DLG2522W Dryer
 DLG2524W Dryer
 DLG2525S Dryer
 DLG2526W Dryer
 DLG2532W Dryer
 DLG2602W Dryer
Amana DLG330RAW DRYER- GAS
Amana DLG330RCW DRYER- GAS
 DLG3744D Dryer
 DLG3744S Dryer
 DLG3744U Dryer
 DLG3744W Dryer
 DLG3788W Dryer
 DLG5932S Dryer
 DLG5932W Dryer
 DLG5966G Dryer
 DLG5966W Dryer
 DLG5988B Dryer
 DLG5988S Dryer
 DLG5988SM Dryer
 DLG5988W Dryer
 DLG6952W Dryer
 DLG7188RM Dryer
 DLG7188WM Dryer
 DLG8388NM Dryer
 DLG8388WM Dryer
 DLG9588SM Dryer
 DLG9588WM Dryer
 DLGX0002TM Dryer
 DLGX2802W Dryer
 DLGX3002P Dryer
 DLGX3002R Dryer
 DLGX3002W Dryer
General Electric DLL1550ABL Electric dryer
General Electric DLL1550BAL Gas dryer
General Electric DLL1550BBL Gas dryer
General Electric DLL1550BCL Gas dryer
General Electric DLL1550BDL Gas dryer
General Electric DLL1550BEL Gas dryer
General Electric DLL1550BFL Gas dryer
General Electric DLL1550BGL Gas dryer
General Electric DLL1550BHL Gas dryer
General Electric DLL1550RAL Gas dryer
General Electric DLL1550RBL Gas dryer
General Electric DLL1550RCL Gas dryer
General Electric DLL1550SBLAD Gas dryer
General Electric DLL1550SBLWH Gas dryer
General Electric DLL2450BGL Gas dryer
General Electric DLL2450BHL Gas dryer
General Electric DLL2450RAL Gas dryer
General Electric DLL2450RBL Gas dryer
General Electric DLL2450RCL Gas dryer
General Electric DLL2650ABL Electric dryer
General Electric DLL2650BAL Gas dryer
General Electric DLL2650BBL Gas dryer
General Electric DLL2650BCL Gas dryer
General Electric DLL2650BDL Gas dryer
General Electric DLL2650BEL Gas dryer
General Electric DLL2650BFL Gas dryer
General Electric DLL2650BGL Gas dryer
General Electric DLL2650BHL Gas dryer
General Electric DLL2650BJL Gas dryer
General Electric DLL2650RAL BACKSPLASH DRYER WOW
General Electric DLL2650RALWW Gas dryer
General Electric DLL2650RBL BACKSPLASH DRYER PROGRAM
General Electric DLL2650RBLWW Gas dryer
General Electric DLL2650RCL GAS DRYER
General Electric DLL2650RCLWW Gas dryer
General Electric DLL2650TA Electric dryer
General Electric DLL2654TA Electric dryer
General Electric DLL2750BAL Gas dryer
General Electric DLL2750BBL Gas dryer
General Electric DLL2880ABC Electric dryer
General Electric DLL2880BAC Electric dryer
General Electric DLL2880DAL Gas dryer
General Electric DLL2880DBL Gas dryer
General Electric DLL2880DCL Gas dryer
General Electric DLL2880DGL Gas dryer
General Electric DLL2880DHL Gas dryer
General Electric DLL2880DJL Gas dryer
General Electric DLL2880DKL Gas dryer
General Electric DLL2880DLL Gas dryer
General Electric DLL2880DML Gas dryer
General Electric DLL2880TA Electric dryer
General Electric DLL2884TA Electric dryer
General Electric DLL2884TB Electric dryer
General Electric DLL2900MAL Gas dryer
General Electric DLL2900MBL Gas dryer
General Electric DLL3280SBLWH Gas dryer
General Electric DLL3480SBLAD Gas dryer
General Electric DLL3480SBLWH Gas dryer
General Electric DLL3680SBLAD Gas dryer
General Electric DLL3680SBLWH Gas dryer
General Electric DLL3680SBLWW Gas dryer
General Electric DLL3880SBLAD Gas dryer
General Electric DLL3880SBLWH Gas dryer
General Electric DLL3880SBLWW Gas dryer
General Electric DLL3980SAM Gas dryer
General Electric DLL3980SBM Gas dryer
General Electric DLL6850AAL Electric dryer
General Electric DLL6850ABL Electric dryer
General Electric DLL6850BAL Gas dryer
General Electric DLL6850BBL Gas dryer
General Electric DLL6850BCL Gas dryer
General Electric DLL6850BDL Gas dryer
General Electric DLL6850BEL Gas dryer
General Electric DLL6850BFL Gas dryer
General Electric DLL6850BGL Gas dryer
General Electric DLL6850TA Electric dryer
General Electric DLL7596ABL Electric dryer
General Electric DLLLR23EG0WW ELECTRIC DRYER
General Electric DLLLR23EG1WW ELECTRIC DRYER
  #2 (permalink)
Old 12-06-2017, 01:40 PM
Junior Member
Default
So just ran some resistance checks on all the components and this is what I am getting:
10.52 K-Ohm on Thermistor at around 70 degree temp (looks okay)
1.882 K-Ohm on Valve 1 terminal (looks okay)
1.882 K-Ohm on Valve 2 terminal (looks okay)
130 Ohms on Igniter (looks okay)
Flame Sensor closed (continuity) at room temp, opens with heatgun applied
All Thermostats closed (continuity) at room temp, open with heatgun applied
To me I think all these readings look good, so I am at a loss. I will also test voltage on gas valve assembly. I am starting to get worried this may be a control board issue. Unfortunately the part is not available for purchase.....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven has big flames after installing igniter dmtlarson Oven Repair (including Ranges and Cooktops) 0 06-26-2013 10:40 AM
Removed igniter to identify part, GAS smell. thegodsquirrel Oven Repair (including Ranges and Cooktops) 0 10-10-2011 07:45 AM
Broiler Doesn't Light, New Igniter, Still Smell Gas rankins66 Oven Repair (including Ranges and Cooktops) 0 09-05-2011 08:21 AM
Maytag Neptune Dryer Rarely Stops JCook216 Dryer Repair 3 05-11-2011 06:28 AM
igniter and gas only one 1 or 2 cycles bigmatt Dryer Repair 6 07-30-2010 05:13 AM
