Discuss
Samsung he error code
 in
Dryer Repair
Hello, First off, thank you for the helpful videos on your site. I have been trying to get my Samsung
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Samsung he error code
  #1 (permalink)
Old 12-03-2017, 07:06 AM
Junior Member
Iron is on a distinguished road
Unhappy Samsung he error code
Model Number: DV203AES/XAC   Brand: Samsung   Age: 5 - 10 years
Hello,
I have been trying to get my Samsung Dryer in working condition and it is proving to be more difficult than I initially anticipated.
Original Issue: No heat
The dryer was not heating. No error messages, just no heat and obviously, it was taking forever to dry clothes. I searched online, confirmed my heating element was burnt out, and found a replacement heating element for my Dryer. Mind you, I installed the following model and not the actual samsung oem part : Supco DE0019A Dryer Heater Element (amazon) since it was about half the price of the Samsung oem and all the comments seemed to confirm the part works just as well.
Second problem: He error code
After replacing the heating element, the dryer heats, but after a few minutes (~5), the heater stops and and gives the heating error code "he". It feels like the dryer is overheating. I checked that my new heating element was installed properly, had continuity, was not touching any part of the case, and that my thermostat and thermal fuses all had continuity.
- At this point, my research directed me towards testing the thermistor, wich measured around 12k. This reading seemed good, but since the part is fairly inexpensive, i changed the thermistor as it was my main suspect to correct the he error. The new thermistor arrived and when i measured it, I saw it had the same reading, so I assumed this would not be correcting my issue.
- I put the new thermistor in, and still had the he error after a few minutes.
- I decided to put the dryer on air fluff to cool it down, and at the same time, to see if the heating element would heat on this setting as it should not...after a few minutes the dryer simply stopped with no error code, and refused to start again. At this point, I knew that a thermal fuse had blown.
-I opened the dyer and confirmed this was the case. I am currently waiting for the thermal fuse, but i know that this is not the root cause of my problem. It would seem like the heating element is always on instead of cycling, and also is on even in the air fluff cycle.
I think the next step would be to test the relay on the Main control board, but at the same time, I suspect i may have simply reconnected something incorrectly, causing the problem. Is that possible? I am almost certain i reconnected the relay properly (i had a picture and checked online)... What if I inversed the connector on the thermistor, for example? There should be no direction on the thermistor right? I am grasping at straws here
Can someone confirm how to test if the relay is the issue? I read that i should apply some current and listen for a click, can I use a 9v battery for this? The main board is pretty expensive, so i need to be certain before replacing it.
TLDR
He error code. Seems like overheating/Heating element always on. Thermistor was replaced. Heating element seems to be on in air fluff cycle (actually blew a thermal fuse). Stuck relay? Inversed connection?
Related Models
 DV306LEW DRYER- ELE
 DV306LEW/XAA DRYER- ELE
 DV306LGW DRYER- GAS
 DV306LGW/XAA DRYER- GAS
 DV316BEC DRYER- ELE
 DV316BEC/XAA DRYER- ELE
 DV316BEW DRYER- ELE
 DV316BEW/XAA DRYER- ELE
 DV316BGC DRYER- GAS
 DV316BGC/XAA DRYER- GAS
 DV316BGW DRYER- GAS
 DV316BGW/XAA DRYER- GAS
 DV316LES DRYER- ELE
 DV316LES/XAA DRYER- ELE
 DV316LEW DRYER- ELE
 DV316LEW/XAA DRYER- ELE
 DV3C6BEW DRYER- ELE
 DV3C6BEW/XAA DRYER- ELE
 DV3C6BGW DRYER- GAS
 DV3C6BGW/XAA DRYER- GAS
Dynasty DVH30 HOOD
Dynasty DVH36 HOOD
Dynasty DVH42 HOOD
Dynasty DVH48 HOOD
Dynasty DVH60 HOOD
General Electric DVL223EA0AA Electric dryer
General Electric DVL223EA0WW Electric dryer
General Electric DVL223EA1WW Electric dryer
General Electric DVL223EB0WW Electric dryer
General Electric DVL223EB1WW Electric dryer
General Electric DVL223EB3WW Electric dryer
General Electric DVL223EB4WW Electric dryer
General Electric DVL223EB6WW Electric dryer
General Electric DVL223EY0AA Electric dryer
General Electric DVL223EY0WW Electric dryer
General Electric DVL223GA0AA Gas dryer
General Electric DVL223GA0WW Gas dryer
General Electric DVL223GA1WW Gas dryer
General Electric DVL223GB0WW Gas dryer
General Electric DVL223GB1WW Gas dryer
General Electric DVL223GB4WW Gas dryer
General Electric DVL223GB5WW Gas dryer
General Electric DVL223GB6WW Gas dryer
General Electric DVL223GB8WW Gas dryer
General Electric DVL223GY0AA Gas dryer
General Electric DVL223GY0WW Gas dryer
General Electric DVLR223EE0WW Electric dryer
General Electric DVLR223EE1WW Electric dryer
General Electric DVLR223EE2WW Electric dryer
General Electric DVLR223EG0WW Electric dryer
General Electric DVLR223EG1WW ELECTRIC DRYER
General Electric DVLR223EG2WW ELECTRIC DRYER
General Electric DVLR223EG3WW ELECTRIC DRYER
General Electric DVLR223EG4WW ELECTRIC DRYER
General Electric DVLR223EG5WW ELECTRIC DRYER
General Electric DVLR223EG6WW ELECTRIC DRYER
General Electric DVLR223EG7WW ELECTRIC DRYER
General Electric DVLR223ET0AA Electric dryer
General Electric DVLR223ET0WW Electric dryer
General Electric DVLR223ET1AA Electric dryer
General Electric DVLR223ET1WW Electric dryer
General Electric DVLR223EV0AA Electric dryer
General Electric DVLR223EV0WW Electric dryer
General Electric DVLR223GE0WW Gas dryer
General Electric DVLR223GE1WW Gas dryer
General Electric DVLR223GE2WW Gas dryer
General Electric DVLR223GG0WW Gas dryer
General Electric DVLR223GG1WW GAS DRYER
General Electric DVLR223GG2WW GAS DRYER
General Electric DVLR223GG3WW GAS DRYER
General Electric DVLR223GG4WW GAS DRYER
General Electric DVLR223GG5WW GAS DRYER
General Electric DVLR223GG6WW GAS DRYER
General Electric DVLR223GG7WW GAS DRYER
General Electric DVLR223GG8WW GAS DRYER
General Electric DVLR223GT0AA Gas dryer
General Electric DVLR223GT0WW Gas dryer
General Electric DVLR223GT1AA Gas dryer
General Electric DVLR223GT1WW Gas dryer
General Electric DVLR223GV0AA Gas dryer
General Electric DVLR223GV0WW Gas dryer
General Electric DVLR223PF0WW GAS DRYER
General Electric DVLR223PG0WW GAS DRYER
General Electric DVLR223PG1WW GAS DRYER
General Electric DVLR223PG2WW GAS DRYER
General Electric DVLR223PG3WW GAS DRYER
General Electric DVLR223PG4WW GAS DRYER
General Electric DVLR223PG5WW GAS DRYER
General Electric DVLR223PG6WW GAS DRYER
General Electric DVLR223PG7WW GAS DRYER
General Electric DVM1850DM2BB MICROWAVE
General Electric DVM1850DM2WW MICROWAVE
General Electric DVM1850DM3BB MICROWAVE
General Electric DVM1850DM3WW MICROWAVE
General Electric DVM1850DM4BB MICROWAVE
General Electric DVM1850DM4WW MICROWAVE
General Electric DVM1850DMBB01 Counter top microwave
General Electric DVM1850DMWW01 Counter top microwave
General Electric DVM1850MM2BG MICROWAVE
General Electric DVM1850MM3BG MICROWAVE
General Electric DVM1850MM4BG MICROWAVE
General Electric DVM1850MMBG01 Counter top microwave
General Electric DVM1850SM2SS MICROWAVE
General Electric DVM1850SM3SS MICROWAVE
General Electric DVM1850SM4SS MICROWAVE
General Electric DVM1850SMSS01 Counter top microwave
General Electric DVM1950DR1BB MICROWAVE
General Electric DVM1950DR1WW MICROWAVE
General Electric DVM1950SR1SS MICROWAVE
Whirlpool DVSA0 SLICER/SHREDDER STAND MIXER ATTACHMENT
Frigidaire DW-2200DL2 Frg(v4) / Dishwasher
Frigidaire DW-3300DL2 Frg(v6) / Dishwasher
Frigidaire DW-3350DL2 Frg(v2) / Dishwasher
Frigidaire DW-4400DL2 Frg(v8) / Dishwasher
Frigidaire DW-5500CDL2 Frg(v4) / Dishwasher
Frigidaire DW-5500DL2 Frg(v2) / Dishwasher
Jenn-Air DW1000B DISHWASHER- UNDERCOUNTER
Jenn-Air DW1000W DISHWASHER- UNDERCOUNTER
Frigidaire DW1050LA1 Frg(v3) / Dishwasher
Frigidaire DW1050LA2 Frg(v3) / Dishwasher
  #2 (permalink)
Old 01-04-2018, 05:56 AM
Junior Member
Default
bump
Any ideas? Thanks!
  #3 (permalink)
Old 01-04-2018, 02:44 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
If I had to guess and that is what I'm doing right now, i'd say you have a main power relay stuck on. That means the contacts inside the relay have arced enough that they have welded themselves together. So the relay is always "ON" even when the power is off. Normally a relay will show an "open" reading when in the off state. Meaning there is no continuity across the main terminals of the relay.
I couldn't find you exact model number, but I did find a picture of a relay board that's probably pretty close. On the board the lower left black relay is probably the one for the heating element. If you take one or both wires off it and test for continuity across the terminals, it will probably show continuity or a dead short. That would prove it is bad.
I don't know much about this brand, but I do know quite a bit about electronics. Good luck.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Samsung Error Code lE BobbyDC1 Dishwasher Repair 0 04-03-2017 10:01 AM
Samsung DW Error Code 5E Dlareau Washer Repair 0 12-28-2015 12:07 PM
Samsung nd error code quincanna Washer Repair 0 07-20-2014 06:06 PM
Samsung Error Code 22 E djrayfinkle Refrigerator & Freezer Repair 0 08-09-2013 08:29 AM
F 4 error code Samsung Microwave Rayken Microwave Repair 0 10-25-2010 10:05 AM
