My son has a Kenmore dryer that the timer just keeps rotating and will not shut off unless the door is opened. It has heat and performs each cycle fine The timer will rotate through all cycles until it is at the. Top and then all the cycles start again When it does reach the end of a cycle it sounds like there is a very brief shut off of power but then it seems the power is restored The shut off of power is probably less than a fraction of a second Any help is appreciated Sam
