Kenmore Elite Model 110.67032601: Hello, I continue to have dryer SHUTDOWN Error CODE is F 31 [ apparently by overheating ] when dyer shuts down, I use a Temp measuring gun getting 275 degrees at heater outlet inside dryer I have REPLACED the heater coil 3 times [ 2 had broken wires after over heat ] I have REPLACED 8557403 inlet THERMISTOR HIGH LIMIT STAT twice I have REPLACED thermal fuse 8318314 twice I have completely disassembled the dryer CLEANING OUT [ blower fan - dryer vent & hose ] I have BLOWN out the dryer motor with air I have CHECKED ALL above components with Ohm meter [ ALL ARE WHERE THEY SHOULD BE ] Have so much money & time sunk in this, don’t want go for a new one.. ANY help would be appreciated
