Register | FAQ's | New Posts | Today's Posts | Extras |
» Whirlpool LER4634EQ2 dryer will not heat |
![]() Model Number: LER4634EQ2 Brand: Whirlpool Age: More than 10 years
![]() Hey guys, about a week ago my dryer suddenly stopped heating up. It still blows and spins but no heat at all. I've visually checked the heating element while it's running and it's not coming on. I've check continuity with a multi-meter on all the recommended possible problem parts (listed below) and am coming up empty as they all check out. Parts I've checked: Heating element (reads at 0.0 on the multi-meter) Thermal cut-off (reads at 0.0 on the multi-meter) High-limit thermostat (reads at 0.0 on the multi-meter) Thermal fuse (reads at 0.0 on the multi-meter) Dryer Cycling Thermostat (reads at 0.0 on the multi-meter on the large outer terminals, reads at 7.0 on the smaller inner terminals used for low-heat cycle) I've tried turning the breaker for the dryer on and off a few times just in case and I'm at wit's end. Any help would certainly be appreciated. thanks! Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Whirlpool Thin Twin Washer Dryer Combo, Dryer won't heat up | NVChickey | Dryer Repair | 1 | 02-25-2012 11:52 PM |
Whirlpool dryer won't heat | jev | Dryer Repair | 3 | 12-07-2011 07:08 PM |
Whirlpool Dryer, getting Heat on NO heat setting. | gph1 | Dryer Repair | 1 | 09-24-2010 01:09 PM |
Whirlpool gas dryer low heat | SKMP9 | Dryer Repair | 0 | 03-14-2010 10:16 AM |
Estate Dryer by Whirlpool/Dryer running but no heat | tsm11238 | Dryer Repair | 1 | 11-06-2007 10:47 AM |
