Discuss
LG Dry shuts off after 30 sec
 in
Dryer Repair
Hello I am hoping you can help me out, my LG dryer will start for about 30 seconds and then
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » LG Dry shuts off after 30 sec
  #1 (permalink)
Old 11-12-2017, 03:23 PM
Junior Member
Jwp1016@cox.net is on a distinguished road
Default LG Dry shuts off after 30 sec
Model Number: DLE2240W   Brand: -other-   Age: 1 - 5 years
Hello I am hoping you can help me out, my LG dryer will start for about 30 seconds and then turn off with a burning smell. This happens whether I put it on normal dry or air dry. I looked to see if there was Lint clogged in both the exhaust pipe as well as the bottom below the drum but no significant amount of Lint was touching the heating element plus the dryer doesnít stay on long enough for the heating element to actually heat. While disassembling the dryer I noticed the smell was coming from the control panel and was hoping someone could tell me if this is a common occurrence for this LG model and if the control panel needs to be replaced. I am assuming and this is just a guess that one of the relays on the control panel is supposed to kick in within 30 seconds and is not which is causing the dryer to shut down. If anyone could help it would be much appreciated as it appears that replacing this board is going to be closely if Iím able to find it. Iím hoping someone has another test I can run to see if it something different. Thank you in advance.
Related Models
Amana DLE231RAW DRYER- ELE
 DLE2512W Dryer
 DLE2514W Dryer
 DLE2515S Dryer
 DLE2516W Dryer
 DLE2532W Dryer
Amana DLE330RAW DRYER- ELE
Amana DLE330RCW DRYER- ELE
 DLE3733D Dryer
 DLE3733S Dryer
 DLE3733U Dryer
 DLE3733W Dryer
 DLE3777W Dryer
 DLE5932S Dryer
 DLE5932W Dryer
 DLE5955G Dryer
 DLE5955W Dryer
 DLE5977B Dryer
 DLE5977S Dryer
 DLE5977SM Dryer
 DLE5977W Dryer
 DLE6942W Dryer
 DLE7177RM Dryer
 DLE7177WM Dryer
 DLE8377NM Dryer
 DLE8377WM Dryer
 DLE9577SM Dryer
 DLE9577WM Dryer
 DLEC733W Dryer
 DLEV833W Dryer
 DLEX0001TM Dryer
 DLEX2801L Dryer
 DLEX2801W Dryer
 DLEX3001P Dryer
 DLEX3001R Dryer
 DLEX3001W Dryer
 DLG0332W Dryer
 DLG0452G Dryer
 DLG0452W Dryer
 DLG1320W Dryer
Amana DLG231RAW DRYER- GAS
 DLG2522W Dryer
 DLG2524W Dryer
 DLG2525S Dryer
 DLG2526W Dryer
 DLG2532W Dryer
 DLG2602W Dryer
Amana DLG330RAW DRYER- GAS
Amana DLG330RCW DRYER- GAS
 DLG3744D Dryer
 DLG3744S Dryer
 DLG3744U Dryer
 DLG3744W Dryer
 DLG3788W Dryer
 DLG5932S Dryer
 DLG5932W Dryer
 DLG5966G Dryer
 DLG5966W Dryer
 DLG5988B Dryer
 DLG5988S Dryer
 DLG5988SM Dryer
 DLG5988W Dryer
 DLG6952W Dryer
 DLG7188RM Dryer
 DLG7188WM Dryer
 DLG8388NM Dryer
 DLG8388WM Dryer
 DLG9588SM Dryer
 DLG9588WM Dryer
 DLGX0002TM Dryer
 DLGX2802W Dryer
 DLGX3002P Dryer
 DLGX3002R Dryer
 DLGX3002W Dryer
General Electric DLL1550ABL Electric dryer
General Electric DLL1550BAL Gas dryer
General Electric DLL1550BBL Gas dryer
General Electric DLL1550BCL Gas dryer
General Electric DLL1550BDL Gas dryer
General Electric DLL1550BEL Gas dryer
General Electric DLL1550BFL Gas dryer
General Electric DLL1550BGL Gas dryer
General Electric DLL1550BHL Gas dryer
General Electric DLL1550RAL Gas dryer
General Electric DLL1550RBL Gas dryer
General Electric DLL1550RCL Gas dryer
General Electric DLL1550SBLAD Gas dryer
General Electric DLL1550SBLWH Gas dryer
General Electric DLL2450BGL Gas dryer
General Electric DLL2450BHL Gas dryer
General Electric DLL2450RAL Gas dryer
General Electric DLL2450RBL Gas dryer
General Electric DLL2450RCL Gas dryer
General Electric DLL2650ABL Electric dryer
General Electric DLL2650BAL Gas dryer
General Electric DLL2650BBL Gas dryer
General Electric DLL2650BCL Gas dryer
General Electric DLL2650BDL Gas dryer
General Electric DLL2650BEL Gas dryer
General Electric DLL2650BFL Gas dryer
General Electric DLL2650BGL Gas dryer
General Electric DLL2650BHL Gas dryer
General Electric DLL2650BJL Gas dryer
General Electric DLL2650RAL BACKSPLASH DRYER WOW
General Electric DLL2650RALWW Gas dryer
General Electric DLL2650RBL BACKSPLASH DRYER PROGRAM
General Electric DLL2650RBLWW Gas dryer
General Electric DLL2650RCL GAS DRYER
General Electric DLL2650RCLWW Gas dryer
General Electric DLL2650TA Electric dryer
General Electric DLL2654TA Electric dryer
General Electric DLL2750BAL Gas dryer
General Electric DLL2750BBL Gas dryer
General Electric DLL2880ABC Electric dryer
General Electric DLL2880BAC Electric dryer
  #2 (permalink)
Old 11-14-2017, 05:43 PM
Junior Member
Default
Update!!! It appears that the board works (once powered down and restarted) only issue I can not change the setting once changed via the rotary knob. Any suggestions.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Shuts off on its own Dlw77 Oven Repair (including Ranges and Cooktops) 0 10-09-2015 09:51 AM
Shuts Down DeBar Dryer Repair 0 06-08-2013 11:47 AM
Sometimes Shuts down after 3 sec. mtbike Microwave Repair 0 06-17-2012 07:19 AM
shuts off ash1 Dishwasher Repair 0 04-01-2009 04:14 PM
My Sub Zero shuts down waltgphd Refrigerator & Freezer Repair 4 03-19-2009 05:51 AM
