Discuss
gas dryer no heat
 in
Dryer Repair
maytag gas dryer initially was running hot but worked. then began to heat only intermitently and now runs continuously but
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » gas dryer no heat
  #1 (permalink)
Old 11-08-2017, 03:32 PM
Junior Member
tombeird is on a distinguished road
Default gas dryer no heat
Model Number: ldg 7304 aae   Brand: Maytag   Age: More than 10 years
maytag gas dryer initially was running hot but worked. then began to heat only intermitently and now runs continuously but applies no heat at all. drum spins. igniter does not glow and there is no flame. dryer spins and wont shut off. the thermostats, all switches and sensors test out ok. there is no clog in the vent system. cleaned off the motor centrifugal switch contacts. still without change.what can be wrong here?
Related Models
Admiral LDG1000AAE DRYER- GAS
Maytag LDG110 DRYER- GAS
Maytag LDG18CA MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG18CM MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG18CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG18CT MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG19CD MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG19CS MANUAL, PARTS (DRYER GAS)
Maytag LDG19CT MANUAL, PARTS (DRYER GAS)
Maytag LDG210 DRYER- GAS
Maytag LDG212 DRYER- GAS
Maytag LDG21CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG22CS MANUAL, PARTS (DRYER GAS)
Maytag LDG22CT MANUAL, PARTS (DRYER GAS)
Maytag LDG23CD MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG24CA MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG24CM MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG24CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG24CT MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG25CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG26CA MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag LDG26CD MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag LDG26CS MANUAL, PARTS (DRYER GAS)
Maytag LDG26CT MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag LDG27CA MANUAL, PARTS (DRYER GAS)
Maytag LDG27CD MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag LDG27CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG27CT MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG303 DRYER- GAS
Maytag LDG30CMD MANUAL, PARTS (DRYER GAS)
Maytag LDG312 DRYER- GAS
Maytag LDG313 DRYER- GAS
Maytag LDG31CA MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG31CM MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG31CT MAYTAG LAUNDRY (DRYER GAS)
Frigidaire LDG333PEW0 Frg(v0) / Gas Dryer
Maytag LDG33CA MANUAL, PARTS (DRYER GAS)
Maytag LDG33CM MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG34CD MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG34CQ MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG382 DRYER- GAS
Maytag LDG4000 DRYER- GAS
Maytag LDG4000AAL DRYER- GAS
Maytag LDG4000AAW DRYER- GAS
Maytag LDG4000ABL DRYER- GAS
Maytag LDG4000ABW DRYER- GAS
Maytag LDG410 DRYER- GAS
Maytag LDG412 DRYER- GAS
Maytag LDG482 DRYER- GAS
Maytag LDG490 DRYER- GAS
Maytag LDG4910 DRYER- GAS
Maytag LDG4910AAL DRYER- GAS
Maytag LDG4910AAW DRYER- GAS
Maytag LDG4914AAE DRYER- GAS
Maytag LDG4914AAL DRYER- GAS
Maytag LDG4914AAM DRYER- GAS
Maytag LDG4916AAE DRYER- GAS
Maytag LDG4916AAM DRYER- GAS
Maytag LDG5004AAW DRYER- GAS
Maytag LDG5004ABW DRYER- GAS
Maytag LDG5005AAE DRYER- GAS
Maytag LDG5005ABE DRYER- GAS
Maytag LDG510 DRYER- GAS
Maytag LDG512 DRYER- GAS
Maytag LDG590 DRYER- GAS
Maytag LDG5910 DRYER- GAS
Maytag LDG5910AAL DRYER- GAS
Maytag LDG5910AAW DRYER- GAS
Maytag LDG5914AAE DRYER- GAS
Maytag LDG5914AAL DRYER- GAS
Maytag LDG5914AAM DRYER- GAS
Maytag LDG5916AAE DRYER- GAS
Maytag LDG5916AAM DRYER- GAS
Maytag LDG6004AAW DRYER- GAS
Maytag LDG610 DRYER- GAS
Maytag LDG612 DRYER- GAS
Maytag LDG6914AAE DRYER- GAS
Maytag LDG6914AAL DRYER- GAS
Maytag LDG6914AAM DRYER- GAS
Maytag LDG710 DRYER- GAS
Maytag LDG712 DRYER- GAS
Maytag LDG713 DRYER- GAS
Maytag LDG7304AAE DRYER- GAS
Maytag LDG7304AAL DRYER- GAS
Maytag LDG7304AAM DRYER- GAS
Maytag LDG7304ABE DRYER- GAS
Maytag LDG7304ABL DRYER- GAS
Maytag LDG7304ABM DRYER- GAS
Maytag LDG7304AGE DRYER- GAS
Maytag LDG7304AGL DRYER- GAS
Maytag LDG7304AGM DRYER- GAS
Maytag LDG7304EGE DRYER- GAS
Maytag LDG7304EGL DRYER- GAS
Maytag LDG7304EGM DRYER- GAS
Maytag LDG7314AAE DRYER- GAS
Maytag LDG7314AAL DRYER- GAS
Maytag LDG7314AAM DRYER- GAS
Maytag LDG7334AAE DRYER- GAS
Maytag LDG7334AAL DRYER- GAS
Maytag LDG7334AAM DRYER- GAS
Maytag LDG7400 DRYER- GAS
Maytag LDG7400AAL DRYER- GAS
Maytag LDG7400AAW DRYER- GAS
Maytag LDG7400ABL DRYER- GAS
Maytag LDG7400ABW DRYER- GAS
Maytag LDG7480AAL DRYER- GAS
Maytag LDG7480AAW DRYER- GAS
Maytag LDG7480ABL DRYER- GAS
Maytag LDG7480ABW DRYER- GAS
Maytag LDG7500 DRYER- GAS
Maytag LDG7500AAE DRYER- GAS
Maytag LDG7500AAL DRYER- GAS
Maytag LDG7500AAM DRYER- GAS
Maytag LDG7500AAW DRYER- GAS
Maytag LDG7500ABE DRYER- GAS
Maytag LDG7500ABL DRYER- GAS
Maytag LDG7500ABM DRYER- GAS
Maytag LDG7500ABW DRYER- GAS
Maytag LDG7600 DRYER- GAS
Maytag LDG7600AAG DRYER- GAS
  #2 (permalink)
Old 11-08-2017, 05:25 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Do you have 120 VAC at the igniter? If not you need to work back through it to find what is stopping the voltage.
  #3 (permalink)
Old 11-13-2017, 06:01 PM
Junior Member
Default
i do not but thank you for pointing that out
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Admiral Dryer Runs no heat in heat cycles, does not turn on in no heat fluff jennshuey Dryer Repair 3 11-19-2016 12:49 PM
Frigidaire dryer Gallery series wont heat in Dryer Repair. "dryer turns but no heat darien685 Dryer Repair 2 08-24-2016 12:45 PM
Whirpool gas dryer won't heat already replace the coils and flame sensor and no heat Joseph1976 Dryer Repair 0 05-30-2014 09:00 AM
gas dryer only heats on perm press and low heat, but not on high heat? GrandCanyonEngineer Dryer Repair 0 03-02-2011 02:23 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
