Discuss
Dryer runs, no heat. Timer bad?
 in
Dryer Repair
Hey guys! I have an old maytag LDE512 electric dryer that spins but wont heat up. When i initially opened
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer runs, no heat. Timer bad?
  #1 (permalink)
Old 10-26-2017, 12:35 PM
Junior Member
fede2022 is on a distinguished road
Default Dryer runs, no heat. Timer bad?
Model Number: DE512   Brand: Maytag   Age: More than 10 years
Hey guys!
I have an old maytag LDE512 electric dryer that spins but wont heat up. When i initially opened the dryer there was a wire going to the hi-limit thermostat that was completely burnt off, so i cut the burnt portion off and crimped a new connector on. I thought it was a simple fix but still dint heat.
I checked for voltage at the outlet got 249V, checked for continuity on the 2 cycling thermostats and hi limit thermostats which they both have. (this model does not have a thermal fuse)
Checked the centrifugal switch on the motor and it is working properly.
Also checked the heater coil for continuity and to make sure it wast grounded to the housing, all checked out good. Timer does not advance in auto-dry but will advance in timed -dry.
Looking at the wiring diagram, i checked the timer for continuity between BK9 and PU49 when the timer is in auto dry and there was none. It seems as though this is providing L1 voltage to one side of the heater element and so if there is no continuity there, 240V is not getting to the heater. Am i correct in that assumption?
Here's the wiring diagram (sorry its in rough shape its really old)
https://imgur.com/a/y9FMs
https://imgur.com/a/qNwoP
Related Models
Maytag DE512 DRYER- ELE
Frigidaire DE5520RW1 Frg(v1) / 27 " Electric Dryer
Frigidaire DE5520RW2 Frg(v1) / 27 " Electric Dryer
Frigidaire DE5800ADD1 Frg(v2) / 27 " Electric Dryer
Frigidaire DE5800AWW1 Frg(v3) / 27 " Electric Dryer
Frigidaire DE5800RW1 Frg(v1) / 27 " Electric Dryer
Frigidaire DE5800RW2 Frg(v1) / 27 " Electric Dryer
Maytag DE590 DRYER- ELE
Maytag DE590D DRYER- ELE
Maytag DE5910 DRYER- ELE
Frigidaire DE600ADD2 Wwh(v4) / 27 " Electric Dryer
Frigidaire DE600ADD3 Wwh(v2) / 27 " Electric Dryer
Frigidaire DE600ADW2 Wwh(v3) / 27 " Electric Dryer
Frigidaire DE600ADW3 Wwh(v1) / 27 " Electric Dryer
Frigidaire DE600EDD1 Wwh(v1) / Electric Dryer
Frigidaire DE600EDD2 Wwh(v2) / Electric Dryer
Frigidaire DE600EDD4 Wwh(v3) / Electric Dryer
Frigidaire DE600EDD5 Wwh(v4) / Electric Dryer
Frigidaire DE600EDF1 Wwh(v5) / Electric Dryer
Frigidaire DE600EDF2 Wwh(v6) / Electric Dryer
Frigidaire DE600EDF4 Wwh(v7) / Electric Dryer
Frigidaire DE600EDF5 Wwh(v8) / Electric Dryer
Frigidaire DE600EDH1 Wwh(v9) / Electric Dryer
Frigidaire DE600EDH2 Wwh(v10) / Electric Dryer
Frigidaire DE600EDH4 Wwh(v11) / Electric Dryer
Frigidaire DE600EDH5 Wwh(v12) / Electric Dryer
Frigidaire DE600EDV1 Wwh(v13) / Electric Dryer
Frigidaire DE600EDV2 Wwh(v14) / Electric Dryer
Frigidaire DE600EDV4 Wwh(v15) / Electric Dryer
Frigidaire DE600EDV5 Wwh(v16) / Electric Dryer
Frigidaire DE600EDW1 Wwh(v17) / Electric Dryer
Frigidaire DE600EDW2 Wwh(v18) / Electric Dryer
Frigidaire DE600EDW4 Wwh(v19) / Electric Dryer
Frigidaire DE600EDW5 Wwh(v20) / Electric Dryer
Frigidaire DE600JDD1 Wwh(v1) / Electric Dryer
Frigidaire DE600JDF1 Wwh(v2) / Electric Dryer
Frigidaire DE600JDH1 Wwh(v3) / Electric Dryer
Frigidaire DE600JDV1 Wwh(v4) / Electric Dryer
Frigidaire DE600JDW1 Wwh(v5) / Electric Dryer
Frigidaire DE600KDD1 Wwh(v11) / Electric Dryer
Frigidaire DE600KDD2 Wwh(v9) / 27 " Electric Dryer
Frigidaire DE600KDD3 Wwh(v9) / 27 " Electric Dryer
Frigidaire DE600KDD4 Wwh(v9) / 27 " Electric Dryer
Frigidaire DE600KDD5 Wwh(v9) / 27 " Electric Dryer
Frigidaire DE600KDH1 Wwh(v7) / Electric Dryer
Frigidaire DE600KDH2 Wwh(v8) / 27 " Electric Dryer
Frigidaire DE600KDH3 Wwh(v8) / 27 " Electric Dryer
Frigidaire DE600KDH4 Wwh(v8) / 27 " Electric Dryer
Frigidaire DE600KDH5 Wwh(v8) / 27 " Electric Dryer
Frigidaire DE600KDW1 Wwh(v3) / Electric Dryer
Frigidaire DE600KDW2 Wwh(v7) / 27 " Electric Dryer
Frigidaire DE600KDW3 Wwh(v7) / 27 " Electric Dryer
Frigidaire DE600KDW4 Wwh(v7) / 27 " Electric Dryer
Frigidaire DE600KDW5 Wwh(v7) / 27 " Electric Dryer
Amana DE6050 WASHER-TOP LOADING
Amana DE6051 WASHER-TOP LOADING
Maytag DE606 DRYER- ELE
Maytag DE608 DRYER- ELE
Amana DE6080 WASHER-TOP LOADING
Amana DE6081 WASHER-TOP LOADING
Maytag DE610 DRYER- ELE
Maytag DE612 DRYER- ELE
Amana DE6151 WASHER-TOP LOADING
Amana DE6171 WASHER-TOP LOADING
Frigidaire DE620EXD1 Wwh(v1) / Gas and Electric Dryers
Frigidaire DE620EXD2 Wwh(v2) / Gas and Electric Dryers
Frigidaire DE620EXD3 Wwh(v3) / Gas and Electric Dryers
Frigidaire DE620EXW1 Wwh(v4) / Gas and Electric Dryers
Frigidaire DE620EXW2 Wwh(v5) / Gas and Electric Dryers
Frigidaire DE620EXW3 Wwh(v6) / Gas and Electric Dryers
Amana DE6230 WASHER-TOP LOADING
Amana DE6231 WASHER-TOP LOADING
Amana DE6260 WASHER-TOP LOADING
Amana DE6261 WASHER-TOP LOADING
Frigidaire DE640ADD1 Wwh(v2) / 27 " Electric Dryer
Frigidaire DE640ADD2 Wwh(v2) / 27 " Electric Dryer
Frigidaire DE640ADW1 Wwh(v1) / 27 " Electric Dryer
Frigidaire DE640ADW2 Wwh(v1) / 27 " Electric Dryer
Frigidaire DE640JDD1 Wwh(v1) / Electric Dryer
Frigidaire DE640JDF1 Wwh(v2) / Electric Dryer
Frigidaire DE640JDH1 Wwh(v3) / Electric Dryer
Frigidaire DE640JDV1 Wwh(v4) / Electric Dryer
Frigidaire DE640JDW1 Wwh(v5) / Electric Dryer
Frigidaire DE640KDD1 Wwh(v12) / Electric Dryer
Frigidaire DE640KDD2 Wwh(v12) / 27 " Electric Dryer
Frigidaire DE640KDD3 Wwh(v3) / 27 " Electric Dryer
Frigidaire DE640KDD4 Wwh(v3) / 27 " Electric Dryer
Frigidaire DE640KDD5 Wwh(v2) / 27 " Electric Dryer
Frigidaire DE640KDD6 Wwh(v2) / 27 " Electric Dryer
Frigidaire DE640KDH1 Wwh(v8) / Electric Dryer
Frigidaire DE640KDH2 Wwh(v11) / 27 " Electric Dryer
Frigidaire DE640KDH3 Wwh(v2) / 27 " Electric Dryer
Frigidaire DE640KDH4 Wwh(v2) / 27 " Electric Dryer
Frigidaire DE640KDW1 Wwh(v4) / Electric Dryer
Frigidaire DE640KDW2 Wwh(v10) / 27 " Electric Dryer
Frigidaire DE640KDW3 Wwh(v1) / 27 " Electric Dryer
Frigidaire DE640KDW4 Wwh(v1) / 27 " Electric Dryer
Frigidaire DE640KDW5 Wwh(v1) / 27 " Electric Dryer
Frigidaire DE640KDW6 Wwh(v1) / 27 " Electric Dryer
Frigidaire DE6420RW1 Frg(v1) / 27 " Electric Dryer
Frigidaire DE6420RW2 Frg(v1) / 27 " Electric Dryer
Frigidaire DE6420RW3 Frg(v1) / 27 " Electric Dryer
Frigidaire DE6500ADD1 Frg(v0) / 27 " Electric Dryer
Frigidaire DE6500AWW1 Frg(v1) / 27 " Electric Dryer
Frigidaire DE650ADD1 Wwh(v2) / 27 " Electric Dryer
Frigidaire DE650ADD2 Wwh(v2) / 27 " Electric Dryer
Frigidaire DE650ADD3 Wwh(v2) / 27 " Electric Dryer
Frigidaire DE650ADW1 Wwh(v1) / 27 " Electric Dryer
Frigidaire DE650ADW2 Wwh(v1) / 27 " Electric Dryer
Frigidaire DE650ADW3 Wwh(v1) / 27 " Electric Dryer
Frigidaire DE650EDD1 Wwh(v1) / Electric Dryer
Frigidaire DE650EDD4 Wwh(v2) / Electric Dryer
Frigidaire DE650EDD5 Wwh(v3) / Electric Dryer
Frigidaire DE650EDF1 Wwh(v4) / Electric Dryer
Frigidaire DE650EDF4 Wwh(v5) / Electric Dryer
Frigidaire DE650EDF5 Wwh(v6) / Electric Dryer
Frigidaire DE650EDH1 Wwh(v7) / Electric Dryer
Frigidaire DE650EDH4 Wwh(v8) / Electric Dryer
Frigidaire DE650EDH5 Wwh(v9) / Electric Dryer
Frigidaire DE650EDV1 Wwh(v10) / Electric Dryer
  #2 (permalink)
Old 10-26-2017, 01:24 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
With the timer set on any of the heating cycles, you should get continuity between BK9 and PU49. High or low heat. If not the problem is in the timer.
  #3 (permalink)
Old 10-26-2017, 02:04 PM
Junior Member
Default
Quote:
Thanks for your reply! Should i test to see if the heater works if i join the BK9 and PU49 wires together and run the dryer?
  #4 (permalink)
Old 10-26-2017, 07:20 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
I can't recommend doing that.
All I can say is be very careful and insulate any connections so they can't short or fry you.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Timer does not advance dryer runs no heat Rmelc1 Dryer Repair 3 05-22-2014 06:55 PM
Kenmore Electric Dryer - Runs but no heat and timer not running CapN Dryer Repair 6 12-12-2012 04:00 PM
Dryer runs when timer in off position and no heat. cwbigfish Dryer Repair 5 11-09-2012 02:38 PM
dryer runs,no heat,timer doesn't work dcar48 Dryer Repair 2 02-04-2008 12:10 PM
Dryer doesnt heat but runs, timer isnt working either bridget Dryer Repair 0 11-03-2007 11:37 AM
