Discuss
Maytag PYE3300AYW keeps blowing thermal fuse
 in
Dryer Repair
My Maytag dryer would not start a couple of days ago so I assumed the vent was clogged and the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag PYE3300AYW keeps blowing thermal fuse
  #1 (permalink)
Old 10-22-2017, 06:46 PM
Junior Member
asand211 is on a distinguished road
Default Maytag PYE3300AYW keeps blowing thermal fuse
Model Number: PYE3300AYW   Brand: Maytag   Age: More than 10 years
My Maytag dryer would not start a couple of days ago so I assumed the vent was clogged and the thermal fuse was blown. I went ahead and ordered the fuse kit. I found the thermal fuse was blown at the heating element. I replaced it and the cycle thermostat and then I completely cleaned the vent and vacuumed out the entire unit. I verified there were no clogs anywhere and when I restarted it I verified there was ample air movement coming from the outside vent. Within 20 minutes it blew the same fuse. I again took the dryer apart and recleaned it although there was nothing left to clean. I replaced the fuse again and the same thing happned. What am I missing? The fan is working, air is moving, there are no obstructions causing a build up of heat, and I replaced the cycle thermostat. Could the cycle thermostat I replaced be faulty causing the heating element to get to hot and continue to blow the thermal fuse?
Related Models
Maytag PYE3300AYW DRYER- ELE
Maytag PYE3300AZW DRYER- ELE
Maytag PYE3360AYW DRYER- ELE
Maytag PYE4500AYQ DRYER- ELE
Maytag PYE4500AYW DRYER- ELE
Maytag PYE4500AZW DRYER- ELE
Maytag PYE4557AYW DRYER- ELE
Maytag PYE4558AYW DRYER- ELE
Maytag PYET244AYW DRYER- ELE
Maytag PYET244AZW DRYER- ELE
Maytag PYET344AYW DRYER- ELE
Maytag PYET344AZW DRYER- ELE
Maytag PYET444AYW DRYER- ELE
Maytag PYET444AZW DRYER- ELE
Maytag PYG1000AWW DRYER- GAS
Maytag PYG2000AWW DRYER- GAS
Maytag PYG2200AWW DRYER- GAS
Admiral PYG2300AGW DRYER- GAS
Maytag PYG2300AWW DRYER- GAS
Maytag PYG3200AWW DRYER- GAS
Maytag PYG3250AWW DRYER- GAS
Maytag PYG3300AWW DRYER- GAS
Maytag PYG3360AWW DRYER- GAS
Maytag PYG4500AWQ DRYER- GAS
Maytag PYG4500AWW DRYER- GAS
Maytag PYG4557AWW DRYER- GAS
Maytag PYG4558AWW DRYER- GAS
Admiral PYGS244AWW DRYER- GAS
Maytag PYGT244AWW DRYER- GAS
Maytag PYGT344AWW DRYER- GAS
Maytag PYGT444AWW DRYER- GAS
Amana QDO-695 RANGE- S/C S/I DDRAFT GAS
Amana QDO-695D RANGE- S/C S/I DDRAFT GAS
Amana QDO-695E RANGE- S/C S/I DDRAFT GAS
Amana QDO-695F RANGE- S/C S/I DDRAFT GAS
Amana QDO-695G RANGE- S/C S/I DDRAFT GAS
Amana QDO-695H RANGE- S/C S/I DDRAFT GAS
Amana QDU-838 RANGE- S/C S/I DDRAFT GAS
Amana QDU-858 RANGE- S/C S/I DDRAFT GAS
Amana QDU-878 RANGE- S/C S/I DDRAFT GAS
Amana QDU-966 RANGE- S/C S/I DDRAFT GAS
Amana QDU-976 RANGE- S/C S/I DDRAFT GAS
Amana QKO-661 RANGE- S/C S/I DDRAFT GAS
Amana QKO-661B RANGE- S/C S/I DDRAFT GAS
Amana QKO-661C RANGE- S/C S/I DDRAFT GAS
Amana QKO-661D RANGE- S/C S/I DDRAFT GAS
Amana QKO-661E RANGE- S/C S/I DDRAFT GAS
Amana QKO-751 RANGE- S/C S/I DDRAFT GAS
Amana QKO-751A RANGE- S/C S/I DDRAFT GAS
Amana QKU-647 RANGE- S/C S/I DDRAFT GAS
Amana QKU-647A RANGE- S/C S/I DDRAFT GAS
Amana QMC811 WALLOVEN- STD MWAVE ELE
Amana QMD-800 MWAVE - FAMILY SIZE (60 HZ)
Amana QMD-800D MWAVE - FAMILY SIZE (60 HZ)
Amana QMD-800E MWAVE - FAMILY SIZE (60 HZ)
Amana QMD-810 MWAVE - FAMILY SIZE (60 HZ)
Amana QMD800 WALLOVEN- STD MWAVE ELE
Amana QMD800D MWAVE - FAMILY SIZE (60 HZ)
Amana QMD810 WALLOVEN- STD MWAVE ELE
Amana R-1 RANGE- S/C S/I DDRAFT GAS
Amana R-1H RANGE- S/C S/I DDRAFT GAS
Amana R-1J RANGE- S/C S/I DDRAFT GAS
Amana R-1J MWAVE - FAMILY SIZE (60 HZ)
Amana R-2 RANGE- S/C S/I DDRAFT GAS
Amana R-3 RANGE- S/C S/I DDRAFT GAS
Amana R-3 MWAVE - FAMILY SIZE (60 HZ)
Amana R0-24-8 MWAVE - FAMILY SIZE (60 HZ)
Amana R0-24-8 MWAVE- MOUNTED OVER RANGE/WO
Whirlpool R101 Air-conditioner/heat pump
Whirlpool R1011 Air-conditioner/heat pump
Whirlpool R1012 Air-conditioner/heat pump
Whirlpool R1013 AIR CONDITIONER
Whirlpool R1014 AIR CONDITIONER
Whirlpool R121 Air-conditioner/heat pump
Whirlpool R1211 Air-conditioner/heat pump
Whirlpool R1212 AIR CONDITIONER
Whirlpool R1213 AIR CONDITIONER
Whirlpool R1231 Air-conditioner/heat pump
 R1404 Air Conditioner
Whirlpool R141A AIR CONDITIONER
Whirlpool R141A1 AIR CONDITIONER
Whirlpool R141F0 AIR CONDITIONER
Whirlpool R141G0 AIR CONDITIONER
Amana R15 MISC / ACCESSORY
Whirlpool R153 Air-conditioner/heat pump
Amana R15A MISC / ACCESSORY
Amana R15L MISC / ACCESSORY
Amana R15LA MISC / ACCESSORY
Whirlpool R183 AIR CONDITIONER
Whirlpool R183A AIR CONDITIONER
Whirlpool R183A1 AIR CONDITIONER
Whirlpool R183A2 AIR CONDITIONER
Whirlpool R183A3 AIR CONDITIONER
Whirlpool R183F0 AIR CONDITIONER
Whirlpool R183G0 AIR CONDITIONER
Whirlpool R183G1 AIR CONDITIONER
Amana R1E MWAVE - FAMILY SIZE (60 HZ)
Jenn-Air R200 SURFACE UNIT- DDRAFT ELE
Frigidaire R2000DL0 Frg(v1) / Electric Range
Frigidaire R2000DW0 Frg(v2) / Electric Range
Frigidaire R2000LL1 Frg(v1) / Electric Range
Frigidaire R2000LW1 Frg(v2) / Electric Range
Jenn-Air R201 SURFACE UNIT- DDRAFT ELE
Jenn-Air R201-C SURFACE UNIT- DDRAFT ELE
Frigidaire R21CL0 Frg(v1) / Free Standing Electric Range
Frigidaire R21CL1 Frg(v1) / Free Standing Electric Range
Frigidaire R21CL2 Frg(v2) / Electric Range
Frigidaire R21CL3 Frg(v4) / Electric Range
Frigidaire R21CL4 Frg(v6) / Electric Range
Frigidaire R21CL5 Frg(v2) / Electric Range
Frigidaire R21CL6 Frg(v4) / Electric Range
Frigidaire R21CW0 Frg(v2) / Free Standing Electric Range
Frigidaire R21CW1 Frg(v2) / Free Standing Electric Range
Frigidaire R21CW2 Frg(v1) / Electric Range
Frigidaire R21CW3 Frg(v3) / Electric Range
Frigidaire R21CW4 Frg(v5) / Electric Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
maytag dryer keeps blowing thermal fuse drewh38 Dryer Repair 1 10-12-2012 04:29 AM
Dryer overheat blowing thermal fuse heater box, not vent fuse try2repairguy Dryer Repair 2 11-10-2011 09:27 AM
Thermal fuse keeps blowing Tony Chapparo Dryer Repair 1 10-05-2011 09:14 AM
maytag dryer blowing thermal fuse chavez107 Dryer Repair 2 04-20-2010 03:10 AM
Maytag keeps blowing thermal fuse jbnsl Dryer Repair 1 03-18-2010 03:31 AM
