Discuss
Kenmore HE3 dryer - no heat
 in
Dryer Repair
Hi, I have a Kenmore HE3 electric dryer model # 110.82822102 and the heat gave out a few weeks ago
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore HE3 dryer - no heat
  #1 (permalink)
Old 10-02-2017, 02:20 PM
Junior Member
tdalton is on a distinguished road
Default Kenmore HE3 dryer - no heat
Model Number: 110.82822102   Brand: Kenmore   Age: More than 10 years
Hi, I have a Kenmore HE3 electric dryer model # 110.82822102 and the heat gave out a few weeks ago but the dryer still functions otherwise. I found that the thermal fuse was bad so I replaced it and I cleaned everything out so no lint or blockage. I tested the thermistor and the heating element and both are good. Someone said it's got to be my control board but that's a $200+ part and which is a lot of money for a 13 year old dryer. Looking to see if there's anything else it could be? Thanks in advance!
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 10-04-2017, 07:42 AM
Senior Member
brobriffin is on a distinguished road
Default
Have you checked the high limit thermostat and the thermal cut off. They are on the heating can that houses the heating element. If either of those two are burnt out that is your issue.
Another remote possibility is the centrifugal switch on the drive motor. If that has burnt contacts or wiring to the second side of the heating element it to can prevent the dryer from heating.
Finally if all else are good the heater relay on the control board is bad or going bad and yes that would require replacing the electronic control board.
  #3 (permalink)
Old 10-04-2017, 08:15 AM
Junior Member
Default
Thanks for responding. The highlimit thermostat gave a reading at room temp but when I heated it up as I read to do it opened up and (no continuity) and never closed again so I am going to replace that part WP3391914. I have found some 3rd party ones on Amazon. Would a 3rd party be alright or would you recommend an OEM? Also do you happen to know the part # for the thermal cut off? Thank you!
  #4 (permalink)
Old 10-04-2017, 11:16 AM
Senior Member
Default
I have never heard of testing the high limit thermostat that way. As a mater of fact if you heat up a high limit thermostat until it no longer show continuity it is basically done. Testing a thermistor that way is correct but a thermostat and high limit cut off are one and done. If you heat up either the high limit thermostat and or the thermal cut off fuse they do not reset and must be replaced.
The high limit thermostat and thermal cut off are numbers 47 and 48 in the picture. These should both be replaced even if only one is bad.
Whirlpool 279973 Thermal Cut Off Kit - AppliancePartsPros.com
The thermistor is part 42 and it is responsible for cycling the heater on and off. It is the one that can be tested by heating it up slightly to see if there is a change in ohms resistance.
Whirlpool WP8577274 Dryer Thermister - AppliancePartsPros.com
The thermal fuse number 59 must be good or the unit wouldn't start at all.
  #5 (permalink)
Old 10-04-2017, 12:43 PM
Junior Member
Default
So I got the high limit thermo/thermal fuse kit and I am back in business with heat. Thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore dryer won't heat kypalak Dryer Repair 6 01-15-2011 05:04 PM
Kenmore Dryer - Timer not moving with No heat and dryer does not shut off poslow Dryer Repair 2 11-21-2010 10:10 PM
Kenmore dryer heats on low heat but not on high heat Mrhollywood334 Dryer Repair 0 09-11-2010 09:33 PM
Kenmore Dryer Doesn't Heat noob_homeowner Dryer Repair 4 10-15-2009 02:27 PM
Kenmore gas dryer don't heat tinatinagirl5 Dryer Repair 0 11-09-2007 07:56 AM
