Discuss
Maytag Centennial does not run motor
 in
Dryer Repair
Hey Everyone, I have a Maytag Centennial gas dryer that stopped working a couple days ago. 2 weeks prior the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Centennial does not run motor
  #1 (permalink)
Old 10-01-2017, 07:30 AM
Junior Member
shaneca is on a distinguished road
Default Maytag Centennial does not run motor
Model Number: MGDC300XW1   Brand: Maytag   Age: 1 - 5 years
Hey Everyone,
I have a Maytag Centennial gas dryer that stopped working a couple days ago. 2 weeks prior the door switch went. I replaced that and it was worked fine since. I double checked the new switch and it is working correctly.
I have done some basic troubleshooting so far and this is what I have came up with.
The start switch seems to work fine because I can set the timer and hit the button and I can hear the switch click. If I then open the door I can hear the start switch disengage like it is supposed to. Also if I set the timer and hit the start button and let it go I will hear it stop shortly after so it appears for the most part the timer circuit is working, the start button is working.
Thermal fuse has continuity through it and when plugged in I measure ~120volts on the heater side of it.
The connector to the motor I have measured 24v across the blue and white connection (4M and 5M on diagram) with the door switch open and when I close the door it goes to 38volts. Should I assume that I should be seeing 120v here?
Can someone explain the Start 2-4-3-8 and Main 2-4-3-6 ( I am guessing something about the 2 different windings between the start and main)
Lastly I have not checked everything in the gas burner section like the flame sensor, pilot, burner and all that but since there seems to be no activity on the motor and a weird voltage reading that I cannot conclude is correct or not I am sort of stuck at this point.
Any ideas on other things I could test to try and figure out what the issue is?
Thanks!
Shane
Related Models
Maytag MGDC400VW0 29" GAS DRYER
Maytag MGDC500VW0 29" GAS DRYER
Maytag MGDC500VW1 29" GAS DRYER
Maytag MGDC700VJ0 27" GAS DRYER
Maytag MGDC700VJ1 27" GAS DRYER
Maytag MGDC700VW0 27" GAS DRYER
Maytag MGDC700VW1 27" GAS DRYER
Maytag MGDE200XW0 27" GAS DRYER
Maytag MGDE300VF0 29" GAS DRYER
Maytag MGDE300VF1 29" GAS DRYER
Maytag MGDE300VF2 29" GAS DRYER
Maytag MGDE300VF3 29" GAS DRYER
Maytag MGDE300VW0 29" GAS DRYER
Maytag MGDE300VW1 29" GAS DRYER
Maytag MGDE300VW3 29" GAS DRYER
Maytag MGDE400XR0 29" GAS DRYER
Maytag MGDE400XW0 29" GAS DRYER
Maytag MGDE500VF0 29" GAS DRYER
Maytag MGDE500VF1 29" GAS DRYER
Maytag MGDE500VP0 29" GAS DRYER
Maytag MGDE500VP1 29" GAS DRYER
Maytag MGDE500VW0 29" GAS DRYER
Maytag MGDE500VW1 29" GAS DRYER
Maytag MGDE500VW2 29" GAS DRYER
Maytag MGDE500WJ0 29" GAS DRYER
Maytag MGDE500WJ1 29" GAS DRYER
Maytag MGDE500WR0 29" GAS DRYER
Maytag MGDE500WR1 29" GAS DRYER
Maytag MGDE900VJ0 29" GAS DRYER
Maytag MGDE900VJ1 29" GAS DRYER
Maytag MGDE900VJ2 29" GAS DRYER
Maytag MGDE900VW0 29" GAS DRYER
Maytag MGDE900VW1 29" GAS DRYER
Maytag MGDE900VW2 29" GAS DRYER
Maytag MGDX500XL0 27" GAS DRYER
Maytag MGDX500XW0 27" GAS DRYER
Maytag MGDX550XW0 27" GAS DRYER
Maytag MGDX600XW0 27" GAS DRYER
Maytag MGDZ400TQ1 27" GAS DRYER
Maytag MGDZ400TQ2 27" GAS DRYER
Maytag MGDZ600TB1 27" GAS DRYER
Maytag MGDZ600TB2 27" GAS DRYER
Maytag MGDZ600TE2 27" GAS DRYER
Maytag MGDZ600TK1 27" GAS DRYER
Maytag MGDZ600TK2 27" GAS DRYER
Maytag MGDZ600TW1 27" GAS DRYER
Maytag MGDZ600TW2 27" GAS DRYER
Maytag MGDZ600WR0 27" GAS DRYER
Frigidaire MGF200PBDA Frg(v2) / Gas Range
Frigidaire MGF200PBDB Frg(v1) / Gas Range
Frigidaire MGF200PBWA Frg(v1) / Gas Range
Frigidaire MGF200PBWB Frg(v2) / Gas Range
Frigidaire MGF240GSA GAS RANGE
Frigidaire MGF300PBDA Frg(v1) / Gas Range
Frigidaire MGF300PBDB Wwh(v17) / Gas Range
Frigidaire MGF300PBDC Kel(v1) / Gas Range
Frigidaire MGF300PBDD Frg(v1) / Gas Range
Frigidaire MGF300PBDE Frg(v1) / Gas Range
Frigidaire MGF300PBDF Frg(v1) / Gas Range
Frigidaire MGF300PBDG Frg(v2) / Gas Range
Frigidaire MGF300PBDH
Frigidaire MGF300PBWA Frg(v2) / Gas Range
Frigidaire MGF300PBWB Wwh(v18) / Gas Range
Frigidaire MGF300PBWC Kel(v2) / Gas Range
Frigidaire MGF300PBWD Frg(v2) / Gas Range
Frigidaire MGF300PBWE Frg(v2) / Gas Range
Frigidaire MGF300PBWF Frg(v3) / Gas Range
Frigidaire MGF300PBWG Frg(v4) / Gas Range
Frigidaire MGF300PBWH
Frigidaire MGF301SBDA Frg(v1) / Gas Range
Frigidaire MGF301SBWA Frg(v2) / Gas Range
Frigidaire MGF303PGDA Frg(v1) / Gas Range
Frigidaire MGF303PGDC Frg(v1) / Gas Range
Frigidaire MGF303PGDD Frg(v2) / Gas Range
Frigidaire MGF303PGDE Frg(v3) / Gas Range
Frigidaire MGF303PGDG Universal/gas Range
Frigidaire MGF303PGDH Universal/gas Range
Frigidaire MGF303PGDJ Universal/gas Range
Frigidaire MGF303PGDK Universal/gas Range
Frigidaire MGF303PGDL Universal/gas Range
Frigidaire MGF303PGWA Frg(v2) / Gas Range
Frigidaire MGF303PGWC Frg(v4) / Gas Range
Frigidaire MGF303PGWD Frg(v5) / Gas Range
Frigidaire MGF303PGWE Frg(v6) / Gas Range
Frigidaire MGF303PGWG Universal/gas Range
Frigidaire MGF303PGWH Universal/gas Range
Frigidaire MGF303PGWJ Universal/gas Range
Frigidaire MGF303PGWK Universal/gas Range
Frigidaire MGF303PGWL Universal/gas Range
Frigidaire MGF311SBDA Frg(v3) / Gas Range
Frigidaire MGF311SBDB Wwh(v19) / Gas Range
Frigidaire MGF311SBDC Frg(v1) / Gas Range
Frigidaire MGF311SBDD Frg(v1) / Gas Range
Frigidaire MGF311SBDE Frg(v1) / Gas Range
Frigidaire MGF311SBDF Frg(v1) / Gas Range
Frigidaire MGF311SBWA Frg(v4) / Gas Range
Frigidaire MGF311SBWB Wwh(v20) / Gas Range
Frigidaire MGF311SBWC Frg(v2) / Gas Range
Frigidaire MGF311SBWD Frg(v2) / Gas Range
Frigidaire MGF311SBWE Frg(v2) / Gas Range
Frigidaire MGF311SBWF Frg(v2) / Gas Range
Frigidaire MGF312SBDA Frg(v1) / Gas Range
Frigidaire MGF312SBDC Frg(v1) / Gas Range
Frigidaire MGF312SBWA Frg(v2) / Gas Range
Frigidaire MGF312SBWB
Frigidaire MGF312SBWC Frg(v2) / Gas Range
Frigidaire MGF313SCDB Frg(v1) / Gas Range
Frigidaire MGF313SCDC Frg(v1) / Gas Range
Frigidaire MGF313SCWB Frg(v2) / Gas Range
Frigidaire MGF313SCWC Frg(v2) / Gas Range
Frigidaire MGF316WFSA Frg(v0) / Gas Range
Frigidaire MGF316WFSB Frg(v0) / Gas Range
Frigidaire MGF316WFSC Frg(v1) / Gas Range
Frigidaire MGF316WFTC Frg(v2) / Gas Range
Frigidaire MGF316WGSA Frg(v0) / Gas Range
Frigidaire MGF316WGSC Frg(v1) / Gas Range
Frigidaire MGF316WGSD Frg(v1) / Gas Range
Frigidaire MGF316WGSE Frg(v2) / Gas Range
Frigidaire MGF316WGSF Frg(v3) / Gas Range
Frigidaire MGF316WGSG Universal/gas Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Centennial - sudden stops, motor burn up loganpriz Washer Repair 0 01-12-2017 12:57 PM
Maytag centennial kristenhector Washer Repair 0 09-05-2016 09:53 PM
Maytag Centennial tpalibra Washer Repair 0 05-24-2016 09:43 PM
Burning/hot smell from Maytag Centennial motor cbova Washer Repair 0 05-13-2015 02:29 PM
Maytag centennial Cobra0516 Washer Repair 1 02-10-2014 07:50 AM
