Discuss
Gas Dryer cuts off after 5 mins
 in
Dryer Repair
Hello - My Gas Dryer will Ignite and run hot for approx 5 mins, then after it turns off, presumably
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Gas Dryer cuts off after 5 mins
  #1 (permalink)
Old 09-29-2017, 01:53 PM
Junior Member
opeter is on a distinguished road
Default Gas Dryer cuts off after 5 mins
Model Number: MDG8000BWQ   Brand: Maytag   Age: 5 - 10 years
Hello -
My Gas Dryer will Ignite and run hot for approx 5 mins, then after it turns off, presumably to maintain temp it will not re-ignite. The Ignitor illuminates bright orange, but will not again ignite. The gas valve will make a small grumbling sound, but will only make this noise on the attempted restart. It does Not make this noise on initial startup. I checked the coils for continuity and they are OK. Can it be the valve itself? The fact that it is making this noise makes me think so. I have a pair of mechanic stethescope and the noise is definitely coming from the valve. I also checked the Thermal fuse, Ignitor, flame sensor, Hi-limit thermostat and cycling thermostat and they all have continuity. I also made sure they cut off at the correct temp using a hot plate and circuit tester. And, yes I also cleaned out the vent.
If I wait 10 minutes or so, I can repeat the whole process over.
Starts initially, but then no restart.
Thoughts?
Thanks!!
Related Models
Maytag MDG8000BWQ DRYER- GAS
Maytag MDG8000BWW DRYER- GAS
Maytag MDG8057AWQ DRYER- GAS
Maytag MDG8057AWW DRYER- GAS
Maytag MDG8057BWQ DRYER- GAS
Maytag MDG8057BWW DRYER- GAS
Maytag MDG8058BWQ DRYER- GAS
Maytag MDG8058BWW DRYER- GAS
Maytag MDG8400AWQ DRYER- GAS
Maytag MDG8400AWW DRYER- GAS
Maytag MDG8416AWA DRYER- GAS
Maytag MDG8416AWW DRYER- GAS
Admiral MDG8426AAW DRYER- GAS
Admiral MDG8426AEW DRYER- GAS
Admiral MDG8426AGW DRYER- GAS
Maytag MDG8500BWW DRYER- GAS
Maytag MDG8506AWA DRYER- GAS
Maytag MDG8506AWW DRYER- GAS
Admiral MDG8550AGW DRYER- GAS
Admiral MDG8550BGW DRYER- GAS
Maytag MDG8600AWQ DRYER- GAS
Maytag MDG8600AWW DRYER
Maytag MDG8757AWQ DRYER- GAS
Maytag MDG8757AWW DRYER- GAS
Maytag MDG9206AWA DRYER- GAS
Maytag MDG9206AWW DRYER- GAS
Maytag MDG9206AXW DRYER- GAS
Maytag MDG9206BWW DRYER- GAS
Maytag MDG9306AWA DRYER- GAS
Maytag MDG9306AWW DRYER- GAS
Maytag MDG9306AXA DRYER- GAS
Maytag MDG9306AXW DRYER- GAS
Maytag MDG9316AWA DRYER- GAS
Maytag MDG9316AWQ DRYER- GAS
Maytag MDG9316AWW DRYER- GAS
Maytag MDG9316AXW DRYER- GAS
Maytag MDG9316BWQ DRYER- GAS
Maytag MDG9316BWW DRYER- GAS
Maytag MDG9357AWA DRYER- GAS
Maytag MDG9357AWW DRYER- GAS
Maytag MDG9360BWW DRYER- GAS
Maytag MDG9390AWW DRYER- GAS
Maytag MDG9390AXW DRYER- GAS
Maytag MDG9390BWW DRYER- GAS
Maytag MDG9420BWW DRYER- GAS
Maytag MDG9520BWQ DRYER- GAS
Maytag MDG9520BWW DRYER- GAS
Maytag MDG9557AWA DRYER- GAS
Maytag MDG9557AWQ DRYER- GAS
Maytag MDG9557AWW DRYER- GAS
Maytag MDG9557AXQ DRYER- GAS
Maytag MDG9557AXW DRYER- GAS
Maytag MDG9557BWQ DRYER- GAS
Maytag MDG9557BWW DRYER- GAS
Maytag MDG9606AWA DRYER- GAS
Maytag MDG9606AWQ DRYER- GAS
Maytag MDG9606AWW DRYER- GAS
Maytag MDG9606AXW DRYER- GAS
Maytag MDG9606BWQ DRYER- GAS
Maytag MDG9606BWW DRYER- GAS
Maytag MDG9700AWM DRYER- GAS
Maytag MDG9700AWW DRYER- GAS
Maytag MDG9706AWA DRYER- GAS
Maytag MDG9706AWW DRYER- GAS
Maytag MDG9766AWW DRYER- GAS
Maytag MDG9766AXW DRYER- GAS
Maytag MDG9800AWQ DRYER- GAS
Maytag MDG9800AWW DRYER- GAS
Maytag MDG9806AWA DRYER- GAS
Maytag MDG9806AWW DRYER- GAS
Maytag MDG9876AWW DRYER- GAS
Maytag MDGT236AWW DRYER- GAS
Maytag MDGT336AWW DRYER- GAS
Maytag MDGT446AWW DRYER- GAS
Frigidaire MDH13TN2
Frigidaire MDH13TN3
Frigidaire MDH15FN1
Frigidaire MDH15TF1 Frg(v1) / Dehumidifier
Frigidaire MDH15TF2 Frg(v1) / Dehumidifier
Frigidaire MDH15TF3 Frg(v1) / Dehumidifier
Frigidaire MDH15WG1 Gib(v0) / Dehumidifier
Frigidaire MDH15WW1 Wwh(v1) / Dehumidifier
 MDH24 DISHWASHER
Frigidaire MDH25TF1 Frg(v1) / Dehumidifier
Frigidaire MDH25TF2 Frg(v2) / Dehumidifier
Frigidaire MDH25TF3 Frg(v0) / Dehumidifier
Frigidaire MDH25TF4 Frg(v0) / Dehumidifier
Frigidaire MDH25TN1
Frigidaire MDH25WW1 Wwh(v2) / Dehumidifier
Frigidaire MDH25WW2 Wwh(v0) / Dehumidifier
Frigidaire MDH25YF1 Frg(v1) / Dehumidifier
Frigidaire MDH25YG2 Gib(v0) / Dehumidifier
Frigidaire MDH25YG3 Gib(v0) / Dehumidifier
Frigidaire MDH25YW1 Wwh(v0) / Dehumidifier
Frigidaire MDH25YW2 Wwh(v0) / Dehumidifier
Frigidaire MDH25YW3 Wwh(v0) / Dehumidifier
Frigidaire MDH25YW4 Wwh(v0) / Dehumidifier
Frigidaire MDH30GG1 Gib(v0) / Dehumidifier
Frigidaire MDH30TF1 Frg(v1) / Dehumidifier
Frigidaire MDH30TF2 Frg(v2) / Dehumidifier
Frigidaire MDH30TF3 Frg(v2) / Dehumidifier
Frigidaire MDH30TN1
Frigidaire MDH30WW1 Wwh(v3) / Dehumidifier
Frigidaire MDH30YF1 Frg(v2) / Dehumidifier
Frigidaire MDH30YW2 Wwh(v0) / Dehumidifier
Frigidaire MDH40TF1 Frg(v1) / Dehumidifier
Frigidaire MDH40TF3 Frg(v2) / Dehumidifier
Frigidaire MDH40TF8 Frg(v3) / Dehumidifier
Frigidaire MDH40TN1
Frigidaire MDH40WW1 Wwh(v4) / Dehumidifier
Frigidaire MDH40WW2 Wwh(v4) / Dehumidifier
Frigidaire MDH40WW3 Wwh(v5) / Dehumidifier
Frigidaire MDH40WW4 Wwh(v5) / Dehumidifier
Frigidaire MDH40YF1 Frg(v0) / Dehumidifier
Frigidaire MDH40YG1 Gib(v0) / Dehumidifier
Frigidaire MDH40YG2 Gib(v0) / Dehumidifier
Frigidaire MDH40YW1 Wwh(v0) / Dehumidifier
Frigidaire MDH40YW3 Wwh(v0) / Dehumidifier
Frigidaire MDH50TF1 Frg(v3) / Dehumidifier
Frigidaire MDH50TF2 Frg(v4) / Dehumidifier
  #2 (permalink)
Old 10-03-2017, 07:30 PM
Junior Member
Default
Just an update if anyone is interested.
I changed the Gas Valve Coils and that did the trick!
Well worth the $16.00
Working again
  #3 (permalink)
Old 10-03-2017, 07:31 PM
Junior Member
Default
Working again
  #4 (permalink)
Old 10-03-2017, 10:14 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Good job! Nothing quite like doing it yourself.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
WP dryer runs 20 mins and stops, wait 15 min and it goes another 20 mins jtrox Dryer Repair 3 10-30-2016 02:06 PM
After 20 mins. dryer vibrates and stops bigcrash29 Dryer Repair 0 02-27-2012 05:22 PM
GE Dryer Shuts off within 5 mins! haloboyvash Dryer Repair 5 08-02-2011 07:47 AM
Dryer runs for only 10 mins. garylcarico Dryer Repair 1 05-07-2009 04:51 AM
Gas Dryer Overheats & Shits Off after 10 mins crs2007 Dryer Repair 2 05-01-2008 05:29 AM
