Discuss
Maytag Dryer doesnt work
 in
Dryer Repair
The dryer stopped working.Power is ok,240 V ,reaching the dryer.The timer is working when plugged in.the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Dryer doesnt work
  #1 (permalink)
Old 11-04-2009, 10:46 AM
zfisch zfisch is offline
Junior Member
zfisch is on a distinguished road
Default Maytag Dryer doesnt work
Model Number: PYE4500AYW   Brand: Maytag   Age: 5 - 10 years
The dryer stopped working.Power is ok,240 V ,reaching the dryer.The timer is working when plugged in.the light will not come on when door opened nothing else works eather.
Can it be the door/light switch?
Related Models
Maytag PYE4500AYW Dryer - Ele
Maytag PYE4500AZW Dryer - Ele
Maytag PYE4557AYW Dryer - Ele
Maytag PYE4558AYW Dryer - Ele
Maytag PYET244AYW Dryer - Ele
Maytag PYET244AZW Dryer - Ele
Maytag PYET344AYQ Dryer - Ele
Maytag PYET344AYW Dryer - Ele
Maytag PYET344AZW Dryer - Ele
Maytag PYET444AYQ Dryer - Ele
Maytag PYET444AYW Dryer - Ele
Maytag PYET444AZW Dryer - Ele
Maytag PYG1000AWW Dryer - Gas
Maytag PYG2000AWW Dryer - Gas
Maytag PYG2200AWW Dryer - Gas
International PYG2300AGW Dryer - Gas
Maytag PYG2300AWW Dryer - Gas
Maytag PYG3200AWW Dryer - Gas
Maytag PYG3250AWW Dryer - Gas
Maytag PYG3300AWW Dryer - Gas
Maytag PYG3360AWW Dryer - Gas
Maytag PYG4500AWQ Dryer - Gas
Maytag PYG4500AWW Dryer - Gas
Maytag PYG4557AWW Dryer - Gas
Maytag PYG4558AWW Dryer - Gas
International PYGS244AWW Dryer - Gas
Maytag PYGT244AWW Dryer - Gas
Maytag PYGT344AWW Dryer - Gas
Maytag PYGT444AWQ Dryer - Gas
Maytag PYGT444AWW Dryer - Gas
Amana QDO-695 Range - S/c S/i Ddraft Gas
Amana QDO-695D Range - S/c S/i Ddraft Gas
Amana QDO-695E Range - S/c S/i Ddraft Gas
Amana QDO-695F Range - S/c S/i Ddraft Gas
Amana QDO-695G Range - S/c S/i Ddraft Gas
Amana QDO-695H Range - S/c S/i Ddraft Gas
Amana QDU-838 Range - S/c S/i Ddraft Gas
Amana QDU-838A Range - S/c S/i Ddraft Gas
Amana QDU-838B Range - S/c S/i Ddraft Gas
Amana QDU-838C Range - S/c S/i Ddraft Gas
Amana QDU-838D Range - S/c S/i Ddraft Gas
Amana QDU-838G Range - S/c S/i Ddraft Gas
Amana QDU-858 Range - S/c S/i Ddraft Gas
Amana QDU-858A Range - S/c S/i Ddraft Gas
Amana QDU-858B Range - S/c S/i Ddraft Gas
Amana QDU-858C Range - S/c S/i Ddraft Gas
Amana QDU-858D Range - S/c S/i Ddraft Gas
Amana QDU-858E Range - S/c S/i Ddraft Gas
Amana QDU-858G Range - S/c S/i Ddraft Gas
Amana QDU-878 Range - S/c S/i Ddraft Gas
Amana QDU-878A Range - S/c S/i Ddraft Gas
Amana QDU-878B Range - S/c S/i Ddraft Gas
Amana QDU-966 Range - S/c S/i Ddraft Gas
Amana QDU-976 Range - S/c S/i Ddraft Gas
Amana QDU-976A Range - S/c S/i Ddraft Gas
Amana QKO-661 Range - S/c S/i Ddraft Gas
Amana QKO-661B Range - S/c S/i Ddraft Gas
Amana QKO-661C Range - S/c S/i Ddraft Gas
Amana QKO-661D Range - S/c S/i Ddraft Gas
Amana QKO-661E Range - S/c S/i Ddraft Gas
Amana QKO-751 Range - S/c S/i Ddraft Gas
Amana QKO-751A Range - S/c S/i Ddraft Gas
Amana QKU-647 Range - S/c S/i Ddraft Gas
Amana QKU-647A Range - S/c S/i Ddraft Gas
Amana QMC811 Walloven - Std Mwave Ele
Amana QMD-800 Mwave - Family Size (60 Hz)
Amana QMD-800A Mwave - Family Size (60 Hz)
Amana QMD-800B Mwave - Family Size (60 Hz)
Amana QMD-800C Mwave - Family Size (60 Hz)
Amana QMD-800D Mwave - Family Size (60 Hz)
Amana QMD-800E Mwave - Family Size (60 Hz)
Amana QMD-800G Mwave - Family Size (60 Hz)
Amana QMD-810 Mwave - Family Size (60 Hz)
Amana QMD-810A Mwave - Family Size (60 Hz)
Amana QMD800 Walloven - Std Mwave Ele
Amana QMD800D Mwave - Family Size (60 Hz)
Amana QMD810 Walloven - Std Mwave Ele
Amana R-1 Range - S/c S/i Ddraft Gas
Amana R-1H Range - S/c S/i Ddraft Gas
Amana R-1J Mwave - Family Size (60 Hz)
Amana R-2 Range - S/c S/i Ddraft Gas
Amana R-3 Mwave - Family Size (60 Hz)
Amana R0-24-8 Mwave - Mounted Over Range/wo
Whirlpool R101
Whirlpool R1011
Whirlpool R1012
Whirlpool R1013
Whirlpool R1014
Whirlpool R121
Whirlpool R1211
Whirlpool R1212
Whirlpool R1213
Whirlpool R1231
Whirlpool R141A
Whirlpool R141A1
Whirlpool R141F0
Whirlpool R141G0
Amana R15 Misc / Accessory
Whirlpool R153
Amana R15A Misc / Accessory
Amana R15L Misc / Accessory
Amana R15LA Misc / Accessory
Whirlpool R183
Whirlpool R183A
Whirlpool R183A1
Whirlpool R183A2
Whirlpool R183A3
Whirlpool R183F0
Whirlpool R183G0
Whirlpool R183G1
Amana R1E Mwave - Family Size (60 Hz)
Jenn-Air R200 Surface Unit - Ddraft Ele
Frigidaire R2000DL0 Frg(v1) / Electric Range
  #2 (permalink)
Old 11-05-2009, 04:27 AM
denman denman is online now
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
Replacement parts for MAYTAG PYE4500AYW | AppliancePartsPros.com
Looks like it is all screwed up as it shows a wiring diagram for a gas unit and yet your Model Number indicates you have a electric. So here is a parts breakdown for a PYE4558. The wiring diagram should be close to yours.
Replacement parts for MAYTAG PYE4558AYW | AppliancePartsPros.com
Could be the door switch but more likely the thermal fuse is blown.
It is mounted on the heater assembly. See Item 5 in Section 5 Heater.
Note it comes with a new hi-limit thermostat. The reason is that the hi-limit should have regulated the temperature so that the fuse did not blow, therefore you replace them as a matched set.
If it is blown make sure your blower is clean and attached to the motor OK.
Also clean/check your vent system.
__________________
  #3 (permalink)
Old 11-06-2009, 12:16 PM
Junior Member
Default
I followed DENMAN'S advise.
I replaced the Thermal and High limit fuses.Cleaned the lint from the blower and filter areas and it works like new.
Thank you
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Profile gas oven doesnt work broiler and top work fine repondtomehere Oven Repair (including Ranges and Cooktops) 1 09-17-2009 06:49 AM
Kenmore dryer timer doesnt work treed Dryer Repair 1 05-25-2009 07:48 AM
Dryer Works, Doesnt Work, Works Again timber284 Dryer Repair 0 08-01-2008 10:56 AM
Dishwasher doesnt work berg Dishwasher Repair 0 06-09-2008 05:24 PM
bake doesnt work johnkh1949 Oven Repair (including Ranges and Cooktops) 1 05-29-2008 11:26 PM
