Discuss
Dryer heats sometimes but not all times
 in
Dryer Repair
Hello. We have a Whirlpool WGD9600TA0 gas dryer that will heat sometimes but not all times. I had replaced the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer heats sometimes but not all times
  #1 (permalink)
Old 09-16-2017, 03:14 PM
Junior Member
chriskern97 is on a distinguished road
Default Dryer heats sometimes but not all times
Model Number: WGD9600TA0   Brand: Whirlpool   Age: 5 - 10 years
Hello. We have a Whirlpool WGD9600TA0 gas dryer that will heat sometimes but not all times. I had replaced the gas burner assembly about 2 years ago due to a broken heating element. No problems until a few months ago. That is when we noticed that the dryer would take a couple, if not 3 cycles to dry our clothes.
Fast forward to last week. No heat, no dry. I looked on the forums and figured it was most likely 1 of 3 things: the high limit thermostat, the thermal fuse, or the thermistor. I purchased these items online along with a pair of gas valve coils.
When the parts arrived, I didn't bother checking them with my multi-meter. I figured "I had them, they didn't cost much, let's just replace them." (I never replaced the valve coils) Lo and behold, HEAT!
2 cycles later, no heat.
I checked our venting. No kinks and no clogs. At this point, I must mention that our gas dryer does not have an external wall where it can vent. It has to go up through the wall (single-story) into the attic where it meets a dryer vent booster. This particular model has the pressure sensor installed so it knows when to turn on or off. I could feel that the unit was trying to turn, but i had a hunch that it was faulty. I removed the duct tape, and looked inside. It was caked on both sides with lint and would not rotate. I turned off the breaker and went to town cleaning it out. Even with it back on (I blew into the pressure switch), I had to help it start rotating ever so carefully. I don't think the motor is working 100% (I have a new 167 CFM model arriving soon), but it is blowing. I don't think it is blowing the rated 150 CFM, but I have no way to measure this nor do I have anything to compare it to. After the booster, the vent takes a 45-degree turn to the roof where it vents out (another 10 - 12 feet for a total of about 30 feet with the booster approximately halfway through the run). Furthermore, I went to our local hardware store, purchased a duct cleaner, and cleaned out the lower portion of the duct-work. I was sweating too much, so I didn't bother with the upper side (I will get that when I replace the booster).
I then went down and checked my old high limit thermostat, the thermal fuse, and the thermistor; all showed continuity. I then removed the new devices and checked them for continuity; all good. I replaced the backing and tried the unit again, venting through the flex hose into the garage. HEAT! 4 cycles later, no heat.
I put it all back together because my wife was a little surprised at how much space a dryer in pieces can take up in the laundry room... So now, from time to time, it works. It *appears* that if we wait between cycles (instead of running them back-to-back), it works. Furthermore, if we run a particularly long cycle (>= 40 minutes), it stops heating.
This happens if it is either on a timed cycle or a sensing cycle.
What I do know is that the gas valve is not opening to allow gas to flow. When it is heating, I can hear the gas valve opening, burning for a few seconds and then shutting off (and then repeating). When it is not working, I am not hearing the valve open at all. I also know that the heating element is always on (when it is on a drying cycle, not *ALWAYS* on) - I have seen the bright orange glow while peering through the vents on the back cover.
I have tried to do my homework, but I am obviously missing something. Are there other parts I am overlooking? Your expertise and advice is greatly appreciated. Thanks!
Related Models
Whirlpool WGD9600TA0 27" GAS DRYER
Whirlpool WGD9600TA1 27" GAS DRYER
Whirlpool WGD9600TA2 27" GAS DRYER
Whirlpool WGD9600TB0 27" GAS DRYER
Whirlpool WGD9600TB1 27" GAS DRYER
Whirlpool WGD9600TU0 27" GAS DRYER
Whirlpool WGD9600TU1 27" GAS DRYER
Whirlpool WGD9600TW0 27" GAS DRYER
Whirlpool WGD9600TW1 27" GAS DRYER
Whirlpool WGD9600TW2 27" GAS DRYER
Whirlpool WGD9600TZ0 27" GAS DRYER
Whirlpool WGD9610XW0 27" GAS DRYER
Whirlpool WGD9750WL0 27" GAS DRYER
Whirlpool WGD9750WL1 27" GAS DRYER
Whirlpool WGD9750WR0 27" GAS DRYER
Whirlpool WGD9750WR1 27" GAS DRYER
Whirlpool WGD9750WW0 27" GAS DRYER
Whirlpool WGD9750WW1 27" GAS DRYER
Whirlpool WGD97HEXL0 GAS DRYER
Whirlpool WGD97HEXL1 27" GAS DRYER
Whirlpool WGD97HEXL2 27" GAS DRYER
Whirlpool WGD97HEXR0 GAS DRYER
Whirlpool WGD97HEXR1 27" GAS DRYER
Whirlpool WGD97HEXR2 27" GAS DRYER
Whirlpool WGD97HEXW0 GAS DRYER
Whirlpool WGD97HEXW1 27" GAS DRYER
Whirlpool WGD97HEXW2 27" GAS DRYER
Whirlpool WGE30302 30" Electric Range Coil Cooktop
Whirlpool WGE32301 30"Electric Range Coil Cooktop E-Z Clean Oven
Whirlpool WGE33001 30" Electric Range E-Z Clean Oven
Whirlpool WGE33301 30" Electric Range
Whirlpool WGE34303 30" Electric Range E-Z Clean Oven
Whirlpool WGE34304 30" Electric Range E-Z Clean Oven
White Westinghouse WGF317ESA White Westinghouse/range
White Westinghouse WGF317ESB White Westinghouse/range
White Westinghouse WGF317ESC White Westinghouse/range
Frigidaire WGF321WADA Wwh(v1) / Gas Range
Frigidaire WGF321WADB Wwh(v1) / Gas Range
Frigidaire WGF321WAWA Wwh(v2) / Gas Range
Frigidaire WGF321WAWB Wwh(v2) / Gas Range
Frigidaire WGF323BADA Wwh(v3) / Gas Range
Frigidaire WGF323BADB Wwh(v1) / Gas Range
Frigidaire WGF323BADC Wwh(v1) / Gas Range
Frigidaire WGF323BADD Wwh(v1) / Gas Range
Frigidaire WGF323BADE Wwh(v1) / Gas Range
Frigidaire WGF323BAWA Wwh(v4) / Gas Range
Frigidaire WGF323BAWB Wwh(v2) / Gas Range
Frigidaire WGF323BAWC Wwh(v2) / Gas Range
Frigidaire WGF323BAWD Wwh(v2) / Gas Range
Frigidaire WGF323BAWE Wwh(v2) / Gas Range
Frigidaire WGF324BBDB Wwh(v0) / Gas Range
Frigidaire WGF324BBDC Wwh(v1) / Gas Range
Frigidaire WGF324BBWB Wwh(v0) / Gas Range
Frigidaire WGF324BBWC Wwh(v2) / Gas Range
Frigidaire WGF325BADA Wwh(v5) / Gas Range
Frigidaire WGF325BADB Wwh(v1) / Gas Range
Frigidaire WGF325BADC Wwh(v1) / Gas Range
Frigidaire WGF325BADD Wwh(v1) / Gas Range
Frigidaire WGF325BAWA Wwh(v6) / Gas Range
Frigidaire WGF325BAWB Wwh(v2) / Gas Range
Frigidaire WGF325BAWC Wwh(v2) / Gas Range
Frigidaire WGF325BAWD Wwh(v2) / Gas Range
Frigidaire WGF337BBDA Wwh(v1) / Gas Range
Frigidaire WGF337BBDB Wwh(v1) / Gas Range
Frigidaire WGF337BBDC Wwh(v1) / Gas Range
Frigidaire WGF337BBWA Wwh(v2) / Gas Range
Frigidaire WGF337BBWB Wwh(v2) / Gas Range
Frigidaire WGF337BBWC Wwh(v2) / Gas Range
Frigidaire WGF337CBSA Wwh(v3) / Gas Range
Frigidaire WGF337CBSB Wwh(v3) / Gas Range
Frigidaire WGF337CBSC Wwh(v3) / Gas Range
White Westinghouse WGF350ESA White Westinghouse/range
White Westinghouse WGF350ESB White Westinghouse/range
White Westinghouse WGF350ESC White Westinghouse/range
White Westinghouse WGF350ESE White Westinghouse/range
Frigidaire WGF350SADA Wwh(v1) / Gas Range
Frigidaire WGF350SADB Wwh(v2) / Gas Range
Frigidaire WGF350SADD Wwh(v1) / Gas Range
Frigidaire WGF350SADE Wwh(v1) / Gas Range
Frigidaire WGF350SAWA Wwh(v3) / Gas Range
Frigidaire WGF350SAWB Wwh(v4) / Gas Range
Frigidaire WGF350SAWD Wwh(v2) / Gas Range
Frigidaire WGF350SAWE Wwh(v2) / Gas Range
White Westinghouse WGF351ESA White Westinghouse/range
White Westinghouse WGF351ESB White Westinghouse/range
White Westinghouse WGF351ESC White Westinghouse/range
Frigidaire WGF353BADA Wwh(v1) / Gas Range
Frigidaire WGF353BADB Wwh(v2) / Gas Range
Frigidaire WGF353BADE Wwh(v3) / Gas Range
Frigidaire WGF353BAWA Wwh(v3) / Gas Range
Frigidaire WGF353BAWB Wwh(v4) / Gas Range
Frigidaire WGF353BAWE Wwh(v4) / Gas Range
Frigidaire WGF353CASA Wwh(v5) / Gas Range
Frigidaire WGF353CASB Wwh(v6) / Gas Range
Frigidaire WGF353CASC Wwh(v0) / Gas Range
White Westinghouse WGF354BJDA White Westinghouse/gas Range
White Westinghouse WGF354BJWA White Westinghouse/gas Range
Frigidaire WGF355BADA Wwh(v1) / Gas Range
Frigidaire WGF355BADB Wwh(v2) / Gas Range
Frigidaire WGF355BADC Wwh(v1) / Gas Range
Frigidaire WGF355BADD Wwh(v2) / Gas Range
Frigidaire WGF355BADE Wwh(v1) / Gas Range
Frigidaire WGF355BADF Wwh(v1) / Gas Range
Frigidaire WGF355BAWA Wwh(v3) / Gas Range
Frigidaire WGF355BAWB Wwh(v4) / Gas Range
Frigidaire WGF355BAWC Wwh(v3) / Gas Range
Frigidaire WGF355BAWD Wwh(v4) / Gas Range
Frigidaire WGF355BAWE Wwh(v2) / Gas Range
Frigidaire WGF355BAWF Wwh(v2) / Gas Range
Frigidaire WGF357CBSB Wwh(v0) / Gas Range
Frigidaire WGF357CBSC Wwh(v0) / Gas Range
Whirlpool WGP30802 30" Electric Range Coil Cooktop
Whirlpool WGP32801 30" Electric Range Self Clean Oven
Whirlpool WGP34804 30" Electric Range Self Clean Oven
Whirlpool WGP34805 30" Electric Range Self Clean Oven
Whirlpool WGP34904 30" ELECTRIC RANGE COIL COOKTOP Self-Clean Oven
Whirlpool WGP34905 30" ELECTRIC RANGE COIL COOKTOP Self-Clean Oven
White Westinghouse WGQ332HS1 GAS DRYER
White Westinghouse WGR211ES0 White Westinghouse/dryer
White Westinghouse WGR211ES1 DRYER
  #2 (permalink)
Old 09-17-2017, 03:19 AM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Did you ever replace the gas valve coil set? If not, its most likely your problem. That and you need to make sure all of the vent is clear.
  #3 (permalink)
Old 09-26-2017, 03:46 PM
Junior Member
Default
ThatGuy,
Well, after replacing numerous sensors, cleaning my vents/ducts, replacing booster blower, I now a) know alot more about Whirlpool gas dryers and b) have a dryer that seems to work (fingers crossed)!
It seems that:
a) my coils were good, the valve itself was bad,
b) I have alot of spare parts for when something else goes wrong, and
c) the ducting was a HUGE issue. Although there was very little lint buildup along the vent itself, alot of it adds up. After getting the valve to release gas consistently, I noticed that it would shut off after about 7 seconds. I removed the front cover and found that the flame was not travelling as fast as it should down the burner funnel. If I just vented into the laundry room, the flame travels in more of a straight line and it burns for 40 seconds between burning cycles once the drying cycle is in full swing (it starts off at about 60 seconds or so and then levels off at 40 seconds). If I tried to vent up through our long vent path (why did those idiot builders do that to me????) without having the last 10 feet clean, the flame would burn close to one of the two thermal sensors on the funnel, and shut off the gas, acting exactly as it should.
So - short story long - CLEAN YOUR VENTS!!
My question now is: does 40 seconds sound about right for the gas to burn between cycles, or do I need to replace yet another sensor? At this point, I think the only thing I haven't replaced are the electrode sensors and the thermistor.
Thanks to all for your input.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer works properly at times and stops between wash and spin/pump cycles at times sawgrassusa Washer Repair 0 02-26-2011 08:02 AM
Dryer is squeeking at times squeekingmaytag Dryer Repair 3 07-27-2010 03:01 PM
Dryer heating some times. jyouchison Dryer Repair 2 09-10-2009 07:45 AM
Dryer heats one or 2 times pjs6720 Dryer Repair 0 07-11-2008 03:32 PM
gas dryer has to run 3 or more times to dry william attewell Dryer Repair 1 11-29-2007 10:26 AM
