Discuss
Kenmore Dryer Overheating and weak
 in
Dryer Repair
My Kenmore dryer started getting hot where it seemed ti was too hot and finally got where it would completely
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore Dryer Overheating and weak
  #1 (permalink)
Old 09-03-2017, 10:25 AM
Junior Member
Cardiaccat is on a distinguished road
Default Kenmore Dryer Overheating and weak
Model Number: 417-83042201   Brand: Kenmore   Age: More than 10 years
My Kenmore dryer started getting hot where it seemed ti was too hot and finally got where it would completely shut down. After it cooled off it would start working for awhile.
I took it apart and used a voltmeter to check the thermal fuse and he thermometer. Both checked out good.
I checked the outer vent pipe and it was clear. However, there was a build up of lint all inside the dryer. The motor had lint all over it and there were large balls of lint all inside the guts of the dryer. The area underneath the lint filter had a lot of lint in it. I cleaned all of that out. I put it back together thinking that all the lint that had built up was what caused the overheating condition so I thought i had it fixed.
I turned it on, but with a load in the dryer it would barely turn. I took some of the clothes out and it would then turn but it seemed kind of slow. After running about 5 minutes I started having an intermittent hum. It will hum for about 15 seconds and then stop. I am not sure if it would overheat again as I turned it off in fear it may damage the motor (assuming it is not already damaged and has been the problem all along).
I took it back apart and the belt seems fine. The pulley system seems to be working fine and is not stiff. The ball on the back of the drum that sits in the back of the dryer seems to be fine. One other thing is the felt on the front assembly that the drum sits on came off in a small area. I glued it back on, but it is a little higher than the rest of it that did not come off.
So, any suggestions? I am thinking maybe the motor is going bad, but I would like to try to be sure before I spend the money for it.
Thanks in advance for any help.
Related Models
Kenmore 41715644 OUTDOOR GRILL
Kenmore 41724182300 WASHER
Kenmore 41724182301 WASHER
Kenmore 41727182700 WASHER
Kenmore 41727182701 WASHER
Kenmore 41727182702 WASHER
Kenmore 41727182703 WASHER
Kenmore 41727182704 WASHER
Kenmore 41729022890 FREESTANDING WASHER
Kenmore 41729042990 FRONTLOAD WASHER
Kenmore 41729042991 KENMORE WASHER
Kenmore 41729042992 FRONT LOAD WASHER
Kenmore 41729052990 KENMORE WASHER
Kenmore 41729052991 WASHER
Frigidaire 41739012890 Frg(v0) / Washer
Kenmore 41739012890 STACK WASHER
Kenmore 41739012891 WASHER
Frigidaire 41739012891 WASHER
Frigidaire 41739022890 Frg(v0) / Washer
Kenmore 41739022891 WASHER
Frigidaire 41739022891 Frg/washer
Kenmore 41740032990 WASHER
Kenmore 41740042990 WASHER
Kenmore 41740052990 WASHER
Kenmore 41740142000 WASHER
Kenmore 41740412700 WASHER
Kenmore 41740412701 WASHER
Kenmore 41740412702 SEARS/FRONT LOAD WASHER -0582
Kenmore 41740412703 WASHER
Kenmore 41741042000 WASHER
Kenmore 41741052000 FRONTLOAD WASHER
Kenmore 41741100000 WASHER
Kenmore 41741101000 WASHER
Kenmore 41741102000 WASHER
Kenmore 41741142000 RESIDENTIAL WASHER
Kenmore 41742042100 WASHER
Kenmore 41742052100 WASHER
Kenmore 41742142100 WASHER
Kenmore 41743042200 SEARS/FRONTLOAD WASHER
Kenmore 41743042300 WASHER
Kenmore 41743052200 SEARS/FRONTLOAD WASHER
Kenmore 41743142200 SEARS/FRONTLOAD WASHER
Kenmore 41743142300 WASHER
Kenmore 41744042400 WASHER
Kenmore 41744052400 WASHER
Kenmore 41744052401 WASHER
Kenmore 41744052500 WASHER
Kenmore 41744072300 WASHER
Kenmore 41744082400 WASHER
Kenmore 41744082500 WASHER
Kenmore 41744092500 WASHER
Kenmore 41744102300 WASHER
Kenmore 41744102301 WASHER
Kenmore 41744130000 WASHER
Kenmore 41744131000 WASHER
Kenmore 41744132000 WASHER
Kenmore 41744142400 WASHER
Kenmore 41744152400 WASHER
Kenmore 41744152401 WASHER
Kenmore 41744152500 WASHER
Kenmore 41744252500 WASHER
Kenmore 41744252501 WASHER
Kenmore 41747102700 WASHER
Kenmore 41747102701 WASHER
Kenmore 41748102700 WASHER
Kenmore 41748102701 WASHER
Kenmore 41748106700 WASHER
Kenmore 41748112700 WASHER
Kenmore 41748112701 WASHER
Kenmore 41748116700 WASHER
Frigidaire 41749012890 Frg(v0) / Dryer
Frigidaire 41749022890 Frg(v0) / Dryer
Frigidaire 41759012890 Frg(v0) / Dryer
Kenmore 41759012890 GAS DRYER
Frigidaire 41759022890 Frg(v0) / Dryer
Kenmore 41759022890 GAS DRYER
Kenmore 41764182300 ELECTRIC DRYER
Kenmore 41769042990 KENMORE DRYER
Kenmore 41769042991 DRYER
Kenmore 41769052990 DRYER
Kenmore 41769052991 ELECTRIC DRYER
Kenmore 41774182300 GAS DRYER
Kenmore 41774182301 GAS DRYER
Kenmore 41779042990 DRYER
Kenmore 41779042991 DRYER
Kenmore 41779052990 DRYER
Kenmore 41779052991 DRYER
Kenmore 41780032990 DRYER
Kenmore 41780042990 DRYER
Kenmore 41780042991 DRYER
Kenmore 41780052990 DRYER
Kenmore 41780052991 DRYER
Kenmore 41780142000 DRYER
Kenmore 41780412700 DRYER
Kenmore 41781042000 DRYER
Kenmore 41781042001 DRYER
Kenmore 41781052000 ELECTRIC DRYER
Kenmore 41781052001 DRYER
Kenmore 41781100000 DRYER
Kenmore 41781101000 DRYER
Kenmore 41781102000 DRYER
Kenmore 41781142000 DRYER
Kenmore 41781142001 DRYER
Kenmore 41782042100 DRYER
Kenmore 41782042101 DRYER
Kenmore 41782042102 SEARS/DRYER
Kenmore 41782052100 DRYER
Kenmore 41782052101 DRYER
Kenmore 41782052102 DRYER
Kenmore 41782052103 SEARS/ELECTRIC DRYER
Kenmore 41782142100 DRYER
Kenmore 41782142101 DRYER
Kenmore 41782142102 SEARS/ELECTRIC DRYER
Kenmore 41783042200 SEARS/DRYER
Kenmore 41783042201 SEARS/ELECTRIC DRYER
Kenmore 41783042300 DRYER
Kenmore 41783052200 SEARS/DRYER
Kenmore 41783052201 SEARS/DRYER
Kenmore 41783142200 SEARS/DRYER
Kenmore 41783142201 SEARS/ELECTRIC DRYER
  #2 (permalink)
Old 09-06-2017, 05:55 PM
Senior Member
brobriffin is on a distinguished road
Default
It does sound as if the motor is bad.
The cool thing is when you purchase a motor here if that is not the problem we have a 365 day return policy.
Here is your part.
Frigidaire 131560100 Motor - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Dryer Overheating atem2144 Dryer Repair 2 08-22-2016 12:25 PM
Kenmore elite dryer overheating kk62 Dryer Repair 0 06-21-2015 01:17 PM
Kenmore dryer overheating trwilley@wreawildblue.org Dryer Repair 1 02-18-2011 03:37 AM
kenmore elite electric dryer overheating at times cindykkk Dryer Repair 1 02-04-2011 10:22 AM
kenmore evenheat dryer overheating crankharder Dryer Repair 2 04-27-2009 02:22 AM
