Discuss
Vibration Noise In Dryer
 in
Dryer Repair
Looking for some help, my dryer is making a loud vibration noise. i took the dryer completely apart and cant
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Vibration Noise In Dryer
  #1 (permalink)
Old 08-25-2017, 09:17 PM
Junior Member
JJCOOL is on a distinguished road
Default Vibration Noise In Dryer
Model Number: 110.72082101   Brand: Kenmore   Age: 1 - 5 years
Looking for some help, my dryer is making a loud vibration noise. i took the dryer completely apart and cant find a thing, dont seem to be any of the rollers and cleaned the blower wheel, vacuumed all the lint out, need some advice. Seems to be coming near motor area but cant find anything wrong. Thanks
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 08-26-2017, 09:12 AM
Senior Member
PNWDrew is on a distinguished road
Default
Idler pulleys are pretty common on those, it's what keeps the belt tight.
If that spins freely and doesn't have a groove cut into it or other obvious issues there's not much else besides the motor; those are not common but they do develop bearing issues at times and make noise..
Double check that there is nothing on the blower, anything substantial (dryer sheets) stuck to it makes it vibrate loudly.
I usually diagnose by sound, as the different circumference parts spin at different speeds. If you could shoot a video or even audio and post it may be recognizable.
  #3 (permalink)
Old 08-26-2017, 10:00 AM
Junior Member
Default
Its very strange, it only happens when i use a heated cycle, in air dry every thing spins quiet, no noise. I cleaned the whole dryer of lint, had it apart twice and cant find nothing wrong. I put on a new belt on, i cant figure it out , it only happens when the heat comes on.
  #4 (permalink)
Old 08-26-2017, 10:15 AM
Senior Member
Default
Ok, that is useful. Since this has a removable lower panel you can access it while running. Bad gas valve coils will buzz, sometimes loudly. That's my first guess. Is it heating normally still? No increase in dry times?
Otherwise take something nonconductive (nothing should be electrically hot that you can easily touch but caution beats a bad shock) and start pushing or pulling on things down there and see if you find any part that changes the sound. It sounds low tech and it is but often IDs the problem. I've found coins and objects sitting under motor mounts or in the stamped edges of the base; wires, bullets, and any anything else you can imagine making noises that may come and go as the machine heats and cools.
If it is immediately as ignitor is powered you might start in that area, without hearing it myself the options are wide open.
  #5 (permalink)
Old 08-26-2017, 10:37 AM
Junior Member
Default
I have done that, watched everything, took apart again pushed pulled put rubber pads under some things, used a mechanic stethoscope on all the parts. it runs great on air dry, soon as i put on heated cycle, it sounds like it will blow up, so crazy.
  #6 (permalink)
Old 08-26-2017, 10:42 AM
Senior Member
Default
It's gotta be in the burner system then. Can you get an audio or video?
  #7 (permalink)
Old 08-28-2017, 12:46 PM
Junior Member
Default
Replaced blower wheel because only part that would be effected by the heat because its plastic. it must of had a hairline fracture in it, because it corrected the problem. all good
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Noise and vibration on spin cycle pegasusmerch Washer Repair 0 04-17-2014 10:36 AM
Electrolux Dryer EIED55H buzzing noise and vibration Verl Dryer Repair 0 02-10-2014 08:17 PM
Spin Noise and Vibration juanrodman Washer Repair 2 01-27-2014 07:05 PM
Vibration Noise britinva Oven Repair (including Ranges and Cooktops) 0 02-17-2013 01:24 PM
noise & vibration finalalarm Dishwasher Repair 1 08-10-2007 03:29 PM
