Discuss
Blowing Main Breaker
 in
Dryer Repair
Hi All, I am having an issue where my electric dryer will run for about 20-30mins like it should but
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Blowing Main Breaker
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 08-23-2017, 12:32 PM
Junior Member
JBull1011 is on a distinguished road
Default Blowing Main Breaker
Brand: Frigidaire   Age: Less than 1 year
Hi All,
I am having an issue where my electric dryer will run for about 20-30mins like it should but without fail, will blow the main breaker. The 30 amp fuse has never blown which is the reason I am so confused. This also happens when nothing else in the apartment is being used so I am confident it is not an overload.
Is this an issue with the main breaker itself or is this a mechanical issue with the dryer itself?
I am using a Frigidaire stack able unit, relatively new (within the last 4 years.
Does anyone know what is happening here?
JB
  #2 (permalink)
Old 08-26-2017, 08:37 AM
Senior Member
PNWDrew is on a distinguished road
Default
When it runs it does heat and run normally? That would generally mean it is OK internally, if there was an internal short that would usually happen very shortly or immediately after starting. It should also be caught by the 30A dryer breaker (which is 2 120v 30a tied together or one double breaker)not the main, which is probably closer to 200A depending on your service.
In 10+ years of this I've never come across a dryer tripping the main as that handles a larger load and could be a safety issue since a ~180A or greater draw somewhere is a significant amount, you may want an electrician involved here.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
LG Washer keeps blowing PCB main assy alavertu1 Washer Repair 0 01-25-2015 12:36 PM
Breaker keeps blowing Atarby Refrigerator & Freezer Repair 4 08-18-2013 05:37 AM
ptac keeps blowing breaker wepewife Heating, Ventilation, and Air Conditioning (HVAC) 0 09-29-2011 08:50 PM
Blowing main Fuse Yanz Dryer Repair 0 05-26-2011 05:04 AM
dry blowing circut breaker every 15 min AK12 Dryer Repair 3 09-27-2010 04:28 AM
