Discuss
Matag Dryer not drying in Intellidry Mode
 in
Dryer Repair
My Matag Dryer will not dry/heat in Intellidry Mode and timer will not advance. Put in Time Dry Mode and
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Matag Dryer not drying in Intellidry Mode
  #1 (permalink)
Old 08-23-2017, 06:43 AM
Junior Member
themooser98 is on a distinguished road
Default Matag Dryer not drying in Intellidry Mode
Model Number: MDE6000AYW   Brand: Maytag   Age: More than 10 years
My Matag Dryer will not dry/heat in Intellidry Mode and timer will not advance. Put in Time Dry Mode and it dries and heats as it should. Any ideas or fixes?
Related Models
Maytag MDE6000AYW DRYER- ELE
Maytag MDE6000AZQ DRYER- ELE
Maytag MDE6000AZW DRYER- ELE
Maytag MDE6200AYQ DRYER- ELE
Maytag MDE6200AYW DRYER- ELE
Maytag MDE6200AZQ DRYER- ELE
Maytag MDE6200AZW DRYER- ELE
Maytag MDE6400AGW DRYER- ELE
Maytag MDE6400AYQ DRYER- ELE
Maytag MDE6400AYW DRYER- ELE
Maytag MDE6400AZW DRYER- ELE
Maytag MDE6460AYW DRYER- ELE
Maytag MDE6460AZW DRYER- ELE
Maytag MDE6657BYQ DRYER- ELE
Maytag MDE6657BYW DRYER- ELE
Maytag MDE6700AYW DRYER- ELE
Maytag MDE6700AZW DRYER- ELE
Maytag MDE6800AYQ DRYER- ELE
Maytag MDE6800AYW DRYER- ELE
Maytag MDE6800AZQ DRYER- ELE
Maytag MDE6800AZW DRYER- ELE
Maytag MDE7057AYQ DRYER- ELE
Maytag MDE7057AYW DRYER- ELE
Maytag MDE7057AZW DRYER- ELE
Maytag MDE7400AYQ DRYER- ELE
Maytag MDE7400AYW DRYER- ELE
Maytag MDE7400AZQ DRYER- ELE
Maytag MDE7400AZW DRYER- ELE
Maytag MDE7460AYQ DRYER- ELE
Maytag MDE7460AYW DRYER- ELE
Maytag MDE7500AYQ DRYER- ELE
Maytag MDE7500AYW DRYER- ELE
Maytag MDE7500AZQ DRYER- ELE
Maytag MDE7500AZW DRYER- ELE
Admiral MDE7550AGW DRYER- ELE
Maytag MDE7600AUW DRYER- ELE
Maytag MDE7600AYQ DRYER- ELE
Maytag MDE7600AYW DRYER- ELE
Maytag MDE7600AZQ DRYER- ELE
Maytag MDE7600AZW DRYER- ELE
Maytag MDE7657AYQ DRYER- ELE
Maytag MDE7657AYW DRYER- ELE
Maytag MDE7657BYQ DRYER- ELE
Maytag MDE7657BYW DRYER- ELE
Maytag MDE7658AYQ DRYER- ELE
Maytag MDE7658AYW DRYER- ELE
Maytag MDE7658BYQ DRYER- ELE
Maytag MDE7658BYW DRYER- ELE
Maytag MDE7757AYQ DRYER- ELE
Maytag MDE7757AYW DRYER- ELE
Maytag MDE7758AYQ DRYER- ELE
Maytag MDE7758AYW DRYER- ELE
Maytag MDE8000AYQ DRYER- ELE
Maytag MDE8000AYW DRYER- ELE
Maytag MDE8000AZW DRYER- ELE
Maytag MDE8057AYQ DRYER- ELE
Maytag MDE8057AYW DRYER- ELE
Maytag MDE8057AZW DRYER- ELE
Maytag MDE8058AYQ DRYER- ELE
Maytag MDE8058AYW DRYER- ELE
Maytag MDE8400AYQ DRYER- ELE
Maytag MDE8400AYW DRYER- ELE
Maytag MDE8400AZW DRYER- ELE
Maytag MDE8416AYA DRYER- ELE
Maytag MDE8416AYW DRYER- ELE
Admiral MDE8426AAW DRYER- ELE
Admiral MDE8426AGW DRYER- ELE
Maytag MDE8500AYW DRYER- ELE
Maytag MDE8506AYA DRYER- ELE
Maytag MDE8506AYW DRYER- ELE
Maytag MDE8506AZW DRYER- ELE
Admiral MDE8550AGW DRYER- ELE
Admiral MDE8550BGW DRYER- ELE
Maytag MDE8600AYQ DRYER- ELE
Maytag MDE8600AYW DRYER- ELE
Maytag MDE8600AZQ DRYER- ELE
Maytag MDE8600AZW DRYER- ELE
Maytag MDE8757AYQ DRYER- ELE
Maytag MDE8757AYW DRYER- ELE
Maytag MDE9206AYA DRYER- ELE
Maytag MDE9206AYW DRYER- ELE
Maytag MDE9206AZW DRYER- ELE
Maytag MDE9306AUW DRYER- ELE
Maytag MDE9306AYA DRYER- ELE
Maytag MDE9306AYW DRYER- ELE
Maytag MDE9306AZA DRYER- ELE
Maytag MDE9306AZW DRYER- ELE
Maytag MDE9316AYA DRYER- ELE
Maytag MDE9316AYQ DRYER- ELE
Maytag MDE9316AYW DRYER- ELE
Maytag MDE9316AZW DRYER- ELE
Maytag MDE9357AYA DRYER- ELE
Maytag MDE9357AYW DRYER- ELE
Maytag MDE9360AYW DRYER- ELE
Maytag MDE9390AYW DRYER- ELE
Maytag MDE9390AZW DRYER- ELE
Maytag MDE9420AYW DRYER- ELE
Maytag MDE9420AZW DRYER- ELE
Maytag MDE9520AYQ DRYER- ELE
Maytag MDE9520AYW DRYER- ELE
Maytag MDE9520AZW DRYER- ELE
Maytag MDE9557AYA DRYER- ELE
Maytag MDE9557AYQ DRYER- ELE
Maytag MDE9557AYW DRYER- ELE
Maytag MDE9557AZA DRYER- ELE
Maytag MDE9557AZQ DRYER- ELE
Maytag MDE9557AZW DRYER- ELE
Maytag MDE9606AUW DRYER- ELE
Maytag MDE9606AYA DRYER- ELE
Maytag MDE9606AYQ DRYER- ELE
Maytag MDE9606AYW DRYER- ELE
Maytag MDE9606AZA DRYER- ELE
Maytag MDE9606AZQ DRYER- ELE
Maytag MDE9606AZW DRYER- ELE
Maytag MDE9700AYM DRYER- ELE
Maytag MDE9700AYW DRYER- ELE
Maytag MDE9700AZM DRYER- ELE
Maytag MDE9700AZW DRYER- ELE
Maytag MDE9706AYA DRYER- ELE
Maytag MDE9706AYW DRYER- ELE
  #2 (permalink)
Old 08-26-2017, 04:47 PM
Senior Member
brobriffin is on a distinguished road
Default
Does your dryness display work? Does it show the correct lights (wet damp dry) when drying in timed mode?
Your Intellidry works from a sensor in the drum, basically two metal strips on the inside right front of the drum. When wet or damp clothes touch these strips it shorts out a circuit in the electronic control (in your case the dryness display) causing it to prevent the timer from advancing. It doesn't however prevent the dryer from heating, which leads me to believe your timer might be bad.
  #3 (permalink)
Old 08-28-2017, 11:09 AM
Junior Member
Default
Thanks Brobriffin, thanks for your response. Here's what I found out today when running the dryer.
In Time Dry Mode there are no lights lit up and the dryer heats up and dries as it should and timer advances.
In Itellidry Mode with nothing in the dryer the Less light is on and the dryer heats up.
In Inellidry Mode with wets clothes in it the Less light is on and the More light is blinking, heats up sometimes and sometimes it doesn't heat up, but the timer does not advance whether it heats up or not.
I'm guessing the timer needs replacing?
Thanks, Don
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer no longer requires start nob to turn back on while in current drying mode Nvious1 Dryer Repair 0 04-11-2012 01:00 PM
Matag Dryer Timer Doesn't Advance on Intellidry. Bob Pierce Dryer Repair 0 12-26-2011 11:51 AM
Dryer won't work in Intellidry MarcDryer Dryer Repair 0 09-10-2011 02:11 PM
dishwasher stays in drying mode franki-d Dishwasher Repair 0 10-18-2010 06:02 PM
Dryer Intellidry Mode Problem danceilike Dryer Repair 0 08-26-2008 10:58 AM
