Discuss
Kenmore dryer stops after few minutes with wet light blinking
 in
Dryer Repair
Our dryer stopped working earlier this week with a part that arc-d (burned) out. Normally, I would diagnose and attempt
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore dryer stops after few minutes with wet light blinking
  #1 (permalink)
Old 08-19-2017, 08:41 AM
Junior Member
mhren is on a distinguished road
Default Kenmore dryer stops after few minutes with wet light blinking
Model Number: 11066002010   Brand: Kenmore   Age: 5 - 10 years
Our dryer stopped working earlier this week with a part that arc-d (burned) out. Normally, I would diagnose and attempt to fix it but I was out of town so my family called a repair man out. He apparently re-soldered a connection and left as he thought it was fixed. Unfortunately, after a few minutes of running, it stops ... my wife tried to get the repair man back out but they are backed-up and he is not returning calls.
I arrived home on Friday to find that the dryer only runs for a few minutes and stops. When it stops, the "wet" light blinks 3 times, then pauses, and blinks 1 more time. It pauses a bit more and then does the same pattern .. 3 fast, pause, 1 more. Turning off the power does seem to reset this condition but again, the dryer runs for a few minutes then stops with this same code.
I'm about to open it up to test for open fuses, etc... but I'm thinking this "3 blink + 1" code might be meaningful to someone on this forum.
Thanks !!
Related Models
Kenmore 11066002010 ELECTRIC DRYER
Kenmore 1106603300 KENMORE PORTABLE AUTOMATIC WASHER
Kenmore 1106603301 KENMORE PORTABLE AUTOMATIC WASHER
Kenmore 1106604400 KENMORE AUTOMATIC WASHERS
Kenmore 1106604401 KENMORE AUTOMATIC WASHERS
Kenmore 1106604450 KENMORE AUTOMATIC WASHERS
Kenmore 1106604451 KENMORE AUTOMATIC WASHERS
Kenmore 1106604500 KENMORE AUTOMATIC WASHERS
Kenmore 1106604550 KENMORE AUTOMATIC WASHERS
Kenmore 1106604600 KENMORE AUTOMATIC WASHER.
Kenmore 1106604601 KENMORE AUTOMATIC WASHERS
Kenmore 1106604650 KENMORE AUTOMATIC WASHER.
Kenmore 1106604651 KENMORE AUTOMATIC WASHERS
Kenmore 1106604700 KENMORE AUTOMATIC WASHERS
Kenmore 1106604702 KENMORE AUTOMATIC WASHERS
Kenmore 1106604703 KENMORE AUTOMATIC WASHERS
Kenmore 1106604704 KENMORE AUTOMATIC WASHERS
Kenmore 1106604750 KENMORE AUTOMATIC WASHERS
Kenmore 1106604752 KENMORE AUTOMATIC WASHERS
Kenmore 1106604753 KENMORE AUTOMATIC WASHERS
Kenmore 1106604754 KENMORE AUTOMATIC WASHERS
Kenmore 1106604800 KENMORE AUTOMATIC WASHERS
Kenmore 1106604850 KENMORE AUTOMATIC WASHERS
Kenmore 1106604900 KENMORE AUTOMATIC WASHER
Kenmore 1106604901 KENMORE AUTOMATIC WASHERS
Kenmore 1106604902 KENMORE AUTOMATIC WASHERS
Kenmore 1106604903 KENMORE AUTOMATIC WASHERS
Kenmore 1106604910 KENMORE AUTOMATIC WASHERS
Kenmore 1106604911 KENMORE AUTOMATIC WASHERS
Kenmore 1106604912 KENMORE AUTOMATIC WASHERS
Kenmore 1106604914 KENMORE AUTOMATIC WASHERS
Kenmore 1106604920 KENMORE AUTOMATIC WASHERS
Kenmore 1106604921 KENMORE AUTOMATIC WASHERS
Kenmore 1106604930 KENMORE AUTOMATIC WASHERS
Kenmore 1106604950 KENMORE AUTOMATIC WASHER
Kenmore 1106604951 KENMORE AUTOMATIC WASHERS
Kenmore 1106604952 KENMORE AUTOMATIC WASHERS
Kenmore 1106604953 KENMORE AUTOMATIC WASHERS
Kenmore 1106604960 KENMORE AUTOMATIC WASHERS
Kenmore 1106604961 KENMORE AUTOMATIC WASHERS
Kenmore 1106604962 KENMORE AUTOMATIC WASHERS
Kenmore 1106604964 KENMORE AUTOMATIC WASHERS
Kenmore 1106604970 KENMORE AUTOMATIC WASHERS
Kenmore 1106604971 KENMORE AUTOMATIC WASHERS
Kenmore 1106604980 KENMORE AUTOMATIC WASHERS
Kenmore 11066051690 COMMERICAL ELECTRIC DRYER
Kenmore 1106605400 KENMORE AUTOMATIC WASHERS
Kenmore 1106605401 KENMORE AUTOMATIC WASHERS
Kenmore 1106605450 KENMORE AUTOMATIC WASHERS
Kenmore 1106605451 KENMORE AUTOMATIC WASHERS
Kenmore 1106605500 KENMORE AUTOMATIC WASHERS
Kenmore 1106605550 KENMORE AUTOMATIC WASHERS
Kenmore 1106605600 KENMORE AUTOMATIC WASHER.
Kenmore 1106605601 KENMORE AUTOMATIC WASHERS
Kenmore 1106605650 KENMORE AUTOMATIC WASHER.
Kenmore 1106605651 KENMORE AUTOMATIC WASHERS
Kenmore 1106605700 KENMORE AUTOMATIC WASHERS
Kenmore 1106605702 KENMORE AUTOMATIC WASHERS
Kenmore 1106605703 KENMORE AUTOMATIC WASHERS
Kenmore 1106605704 KENMORE AUTOMATIC WASHERS
Kenmore 1106605750 KENMORE AUTOMATIC WASHERS
Kenmore 1106605752 KENMORE AUTOMATIC WASHERS
Kenmore 1106605753 KENMORE AUTOMATIC WASHERS
Kenmore 1106605754 KENMORE AUTOMATIC WASHERS
Kenmore 1106605800 KENMORE AUTOMATIC WASHERS
Kenmore 1106605850 KENMORE AUTOMATIC WASHERS
Kenmore 11066058690 COMMERICAL ELECTRIC DRYER
Kenmore 1106605900 KENMORE AUTOMATIC WASHER
Kenmore 1106605901 KENMORE AUTOMATIC WASHERS
Kenmore 1106605902 KENMORE AUTOMATIC WASHERS
Kenmore 1106605903 KENMORE AUTOMATIC WASHERS
Kenmore 1106605910 KENMORE AUTOMATIC WASHERS
Kenmore 1106605911 KENMORE AUTOMATIC WASHERS
Kenmore 1106605912 KENMORE AUTOMATIC WASHERS
Kenmore 1106605914 KENMORE AUTOMATIC WASHERS
Kenmore 1106605920 KENMORE AUTOMATIC WASHERS
Kenmore 1106605921 KENMORE AUTOMATIC WASHERS
Kenmore 1106605930 KENMORE AUTOMATIC WASHERS
Kenmore 1106605950 KENMORE AUTOMATIC WASHER
Kenmore 1106605951 KENMORE AUTOMATIC WASHERS
Kenmore 1106605952 KENMORE AUTOMATIC WASHERS
Kenmore 1106605953 KENMORE AUTOMATIC WASHERS
Kenmore 1106605960 KENMORE AUTOMATIC WASHERS
Kenmore 1106605961 KENMORE AUTOMATIC WASHERS
Kenmore 1106605962 KENMORE AUTOMATIC WASHERS
Kenmore 1106605964 KENMORE AUTOMATIC WASHERS
Kenmore 1106605970 KENMORE AUTOMATIC WASHERS
Kenmore 1106605971 KENMORE AUTOMATIC WASHERS
Kenmore 1106605980 KENMORE AUTOMATIC WASHERS
Kenmore 11066071690 COMMERCIAL DRYER
Kenmore 1106607400 KENMORE GAS DRYER
Kenmore 1106607401 KENMORE GAS DRYER
Kenmore 1106607410 KENMORE GAS DRYER
Kenmore 1106607500 KENMORE GAS DRYER
Kenmore 1106607501 KENMORE GAS DRYER
Kenmore 1106607600 KENMORE GAS DRYER
Kenmore 1106607601 KENMORE GAS DRYER
Kenmore 1106607700 KENMORE GAS DRYER
Kenmore 1106607701 KENMORE GAS DRYER
Kenmore 1106607710 KENMORE GAS DRYER
Kenmore 1106607711 KENMORE GAS DRYER
Kenmore 1106607800 KENMORE GAS DRYER
Kenmore 1106607801 KENMORE GAS DRYER
Kenmore 1106607802 KENMORE GAS DRYER
Kenmore 1106607810 KENMORE GAS DRYER
Kenmore 1106607900 KENMORE GAS DRYER
Kenmore 1106607910 KENMORE GAS DRYER
Kenmore 1106607911 KENMORE GAS DRYER
Kenmore 1106607920 KENMORE GAS DRYER
Kenmore 1106607921 KENMORE GAS DRYER
Kenmore 1106607930 KENMORE GAS DRYER
Kenmore 1106607931 KENMORE GAS DRYER
Kenmore 1106607940 KENMORE GAS DRYER
Kenmore 1106608400 KENMORE ELECTRIC DRYER
Kenmore 1106608401 KENMORE ELECTRIC DRYER
Kenmore 1106608410 KENMORE ELECTRIC DRYER
Kenmore 1106608411 KENMORE ELECTRIC DRYER
Kenmore 1106608500 KENMORE ELECTRIC DRYER
Kenmore 1106608501 KENMORE ELECTRIC DRYER
Kenmore 1106608600 KENMORE ELECTRIC DRYER
  #2 (permalink)
Old 08-20-2017, 03:45 PM
Senior Member
PNWDrew is on a distinguished road
Default
From my memory (not necessarily a good one) I think that's F3E1 - exhaust thermistor shorted or open. If it is F1E3 that is wrong control board which seems much less likely. I may be totally wrong - all codes tend to blend together after a while. SO you should go to tech sheet first.
The tech sheet on that machine is under console. It'll have the correct code list in it, if it contradicts me trust it. You'd use a putty knife or paint scraper and slide under the front corners of the console to compress those clips and release front edge, but 1st you'll need to pull a few 1/4" screws out of back edge where plastic meets metal panel to fully free it. There are live wires inside so take care and unplug it before you stick any part of you or a tool in there.
The exhaust thermistor is a white diamond shaped sensor about 2"x1" located behind the duct where the filter lives, you can see it looking in from the right side. That lower panel easily comes off with similar clips as the top console, just slide the tool in from edges until you locate them. You push them downward from the front with the tool.
The thermistor is part # WP8577274. If bad the machine control cannot see exhaust temps and will run and probably heat for a few before it realizes it's not seeing heat in exhaust.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer stops after 20 minutes Mr.Ford Dryer Repair 1 02-28-2017 09:27 PM
Dryer stops after 20 minutes. donnieu Dryer Repair 0 01-15-2017 05:18 AM
Kenmore runs but stops after 15 minutes grebma Dryer Repair 6 02-13-2014 04:12 AM
Kenmore gas dryer stops heating after few minutes shorty313 Dryer Repair 0 09-19-2011 07:34 PM
Kenmore dryer starts to heat, makes odd cycle noise and stops heating 2 minutes in pitcher09 Dryer Repair 0 08-21-2009 05:46 PM
