Discuss
Out of Ideas on dryer Troubleshooting
 in
Dryer Repair
Hi guys ans gals, Thanking you in advance for thinking about my sad tale. This dryer does not heat consistently.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Out of Ideas on dryer Troubleshooting
  #1 (permalink)
Old 08-14-2017, 08:39 AM
Junior Member
guiljones is on a distinguished road
Unhappy Out of Ideas on dryer Troubleshooting
Model Number: ned5100tq1   Brand: Amana   Age: More than 10 years
Hi guys ans gals,
This dryer does not heat consistently. Playing with the control dial will sometimes result in heat by going backwards. Seems to work less and less.
I have checked continuity on all thermostats and resistors and found good. The element does have 10 ohms resistance.
Any ideas would be greatly appreciated!
Cheers.
Related Models
Maytag NED5100TQ1 29" ELECTRIC DRYER
Maytag NED5200TQ0 29" ELECTRIC DRYER
Maytag NED5240TQ0 29" ELECTRIC DRYER
Maytag NED5400TQ0 29" ELECTRIC DRYER
Maytag NED5500TQ0 29" ELECTRIC DRYER
Maytag NED5800TQ0 29"ELECTRIC DRYER
Maytag NED7200TW10 29" ELECTRIC DRYER
Maytag NED7300WW0 27" ELECTRIC DRYER
Maytag NED7300WW1 27" ELECTRIC DRYER
Maytag NED7500VM0 ELECTRIC DRYER
Maytag NED7500VM1 ELECTRIC DRYER
Maytag NED7500VW0 ELECTRIC DRYER
Maytag NED7500VW1 ELECTRIC DRYER
Maytag NEDNS249F REF - SXS/I&W
Maytag NEDNS249FA REF - SXS/I&W
Maytag NEDNS249FH REF - SXS/I&W
Maytag NEDNS249HA REF - SXS/I&W
Maytag NEDNS249HH REF - SXS/I&W
Norge NEF3G1 RANGE- F/S STD ELE
Norge NEH2H0 RANGE- F/S STD ELE
Norge NEHA86-1 RANGE- S/C F/S ELE
Norge NEHW86-1 RANGE- S/C F/S ELE
Bosch NEM732 UC
Bosch NEM735 UC
Bosch NEM736 UC
Bosch NEM932 UC
Bosch NEM935 UC
Bosch NEM936 UC
Maytag NENS207G REF - SXS/I&W
Maytag NENS207GA REF - SXS/I&W
Maytag NENS207GH REF - SXS/I&W
Maytag NENS208GZA REF - SXS
Maytag NENS208GZH REF - SXS
Maytag NENS208GZW REF - SXS
Maytag NENS227F REF - SXS
Maytag NENS227FH REF - SXS
Maytag NENS227G REF - SXS
Maytag NENS227GA REF - SXS
Maytag NENS227GH REF - SXS
Maytag NENS228GZA REF - SXS
Maytag NENS228GZH REF - SXS
Maytag NENS228GZW REF - SXS
Maytag NENS248GZA REF - SXS
Maytag NENS248GZH REF - SXS
Maytag NENS248GZW REF - SXS
Maytag NENT156E REF - TOP MOUNT
Maytag NENT156EA REF - TOP MOUNT
Maytag NENT156EH REF - TOP MOUNT
Maytag NENT156G REF - TOP MOUNT
Maytag NENT156GA REF - TOP MOUNT
Maytag NENT156GH REF - TOP MOUNT
Maytag NENT156HA REF - TOP MOUNT
Maytag NENT156HH REF - TOP MOUNT
Maytag NENT156HW REF - TOP MOUNT
Maytag NENT176H REF - TOP MOUNT
Maytag NENT176HA REF - TOP MOUNT
Maytag NENT176HH REF - TOP MOUNT
Maytag NENT196H REF - TOP MOUNT
Maytag NENT196HA REF - TOP MOUNT
Maytag NENT196HH REF - TOP MOUNT
Maytag NENT198H REF - TOP MOUNT
Maytag NENT198HA REF - TOP MOUNT
Maytag NENT198HH REF - TOP MOUNT
Maytag NENT198K REF - TOP MOUNT
Maytag NENT198KA REF - TOP MOUNT
Maytag NENT217F REF - TOP MOUNT
Maytag NENT217FA REF - TOP MOUNT
Maytag NENT217FH REF - TOP MOUNT
Maytag NENT238H REF - TOP MOUNT
Maytag NENT238HA REF - TOP MOUNT
Maytag NENT238HH REF - TOP MOUNT
Norge NER1360ACW RANGE- F/S STD ELE
Admiral NER1360AGH RANGE- F/S STD ELE
Norge NER3540ACW RANGE- S/C F/S ELE
Norge NER3760ACW RANGE- S/C F/S ELE
Bosch NES732 UC
Bosch NES735 UC
Bosch NES736 UC
Bosch NES932 UC
Bosch NES935 UC
Bosch NES936 UC
Norge NEW2G1 RANGE- F/S STD ELE
Norge NEW2H0 RANGE- F/S STD ELE
Norge NEW2H1 RANGE- F/S STD ELE
Norge NEW3G1 RANGE- F/S STD ELE
Norge NEW3G8AC RANGE- S/C F/S ELE
Norge NEW3G8CV RANGE- S/C F/S ELE
Norge NEW3G8CX RANGE- S/C F/S ELE
Norge NEW3G8DEV RANGE- S/C F/S ELE
Norge NEW3G8DX RANGE- S/C F/S ELE
Norge NEW3G8EV RANGE- S/C F/S ELE
Norge NEW3G8EVW RANGE- S/C F/S ELE
Norge NEW3H2EX RANGE- F/S STD ELE
Norge NEW3H8CVW RANGE- S/C F/S ELE
Norge NEW3H8CX RANGE- S/C F/S ELE
Norge NEW3H8STVW-EV RANGE- S/C F/S ELE
Norge NEW3J8EV RANGE- S/C F/S ELE
Norge NEW6G6CLW RANGE- F/S CONT CLEAN ELE
Norge NEW6H6CLW RANGE- F/S CONT CLEAN ELE
Bosch NEZ1000
Bosch NEZ1010
Bosch NEZ1020
Bosch NEZ1050
Bosch NEZ1055
Bosch NEZ1070
Bosch NEZ1075
Bosch NEZ1100
Frigidaire NFTR18X4LB0 REFRIGERATOR
Frigidaire NFTR18X4LB1 REFRIGERATOR
Frigidaire NFTR18X4LB2 REFRIGERATOR
Frigidaire NFTR18X4LB4 FRIGIDAIRE/REFRIGERATOR
Frigidaire NFTR18X4LB6 REFRIGERATOR
Frigidaire NFTR18X4LS2 REFRIGERATOR
Frigidaire NFTR18X4LS3 FRIGIDAIRE/REFRIGERATOR
Frigidaire NFTR18X4LS4 REFRIGERATOR
Frigidaire NFTR18X4LS5 REFRIGERATOR
Frigidaire NFTR18X4LS6 REFRIGERATOR
Frigidaire NFTR18X4LW0 REFRIGERATOR
Frigidaire NFTR18X4LW1 REFRIGERATOR
Frigidaire NFTR18X4LW2 REFRIGERATOR
  #2 (permalink)
Old 08-20-2017, 02:52 PM
Senior Member
PNWDrew is on a distinguished road
Default
Whirlpool WPW10185972 Timer - AppliancePartsPros.com
Timer - if it heats and runs at all, it's probably the timer. Heating means the entire element system is OK. Running means motor and drive belt are ok.
You could have a loose or broken wire but I doubt it, if messing with the timer affects the issue that's probably the problem part.
  #3 (permalink)
Old 08-21-2017, 07:31 AM
Junior Member
Default
Many thanks for the response! I'll play with that angle.
Cheers.
  #4 (permalink)
Old 08-21-2017, 07:43 AM
Senior Member
Default
I skipped the most basic check - the incoming voltage. Look at prongs of plug for evidence of arcing like burnt or discolored spots that might indicate a poor connection in the outlet. Also check for 220-240v at the terminal block as you wiggle the plug and cord around.
If it was losing one of the 120v lines it would also behave as you describe. Still probably the timer but it's worth being sure that it's getting what it needs.
Sometimes the simple things are easy to overlook.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Help with dryer troubleshooting mreves Dryer Repair 3 06-12-2013 11:28 AM
Troubleshooting Gas Dryer 213030520 Dryer Repair 1 07-19-2010 03:50 PM
Troubleshooting ideas noop71 Refrigerator & Freezer Repair 0 02-10-2009 09:55 AM
Gas Dryer Troubleshooting RICK 3 Dryer Repair 3 04-30-2008 03:18 AM
