Discuss
Dryer motor alignment?
 in
Dryer Repair
In replacing the blower fan that was worn around the motor shaft, I noticed the fan had been rubbing against
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer motor alignment?
  #1 (permalink)
Old 08-09-2017, 09:57 AM
Junior Member
gvbill is on a distinguished road
Post Dryer motor alignment?
Model Number: MGD9606AWW   Brand: Maytag   Age: 5 - 10 years
In replacing the blower fan that was worn around the motor shaft, I noticed the fan had been rubbing against the left side of the rear (motor side) blower housing. The new fan does not rub the rear housing. However, when attaching the front blower cover, the fan rubs against the right side of it. Removing the fan and looking straight down at the motor and shaft, I see that it is not quite perpendicular to the motor assembly bracket to which the blower housing attaches. The bracket is secured to the bottom of the dryer at the front by two screws and, at the rear, by just a tab that slides into the bottom panel. There is slight play both vertically and horizontally at the rear of the bracket (perhaps from some not quite so gentle handling when recently moving of the unit ). I've found that securing two washers (about 1/8" total) beneath the right rear corner of the bracket that the motor and shaft are pretty close to perpendicular when the tension of the idler arm pulley is also attached via the belt.
I haven't tested it yet, but I wanted to ask the community whether 1) this sounds like a lasting fix or 2) I should try something else. Oh yeah, if I stick with the wedging solution, how should I prevent potential squeaking from the washers? I was planning on securing them with a screw into the bottom panel. There's already a hole for such in the bracket.
Thank you very much!
Related Models
Maytag MGD9700SB0 Gas Dryer
Maytag MGD9700SQ0 Gas Dryer
Maytag MGD9800TB0 Gas Dryer
Maytag MGD9800TK0 GAS DRYER
Maytag MGD9800TQ0 GAS DRYER
Maytag MGDB200VQ0 GAS DRYER
Maytag MGDB400VQ0 GAS DRYER
Maytag MGDB700VQ0 GAS DRYER
Maytag MGDB800VB0 GAS DRYER
Maytag MGDB800VQ0 GAS DRYER
Maytag MGDB800VU0 GAS DRYER
Maytag MGDB850WB0 GAS DRYER
Maytag MGDB850WL0 GAS DRYER
Maytag MGDB850WQ0 GAS DRYER
Maytag MGDB850WR0 GAS DRYER
Maytag MGDC100WQ0 29" GAS DRYER
Maytag MGDC400VW0 29" GAS DRYER
Maytag MGDC500VW0 29" GAS DRYER
Maytag MGDC500VW1 29" GAS DRYER
Maytag MGDC700VJ0 27" GAS DRYER
Maytag MGDC700VJ1 27" GAS DRYER
Maytag MGDC700VW0 27" GAS DRYER
Maytag MGDC700VW1 27" GAS DRYER
Maytag MGDE200XW0 27" GAS DRYER
Maytag MGDE300VF0 29" GAS DRYER
Maytag MGDE300VF1 29" GAS DRYER
Maytag MGDE300VF2 29" GAS DRYER
Maytag MGDE300VF3 29" GAS DRYER
Maytag MGDE300VW0 29" GAS DRYER
Maytag MGDE300VW1 29" GAS DRYER
Maytag MGDE300VW3 29" GAS DRYER
Maytag MGDE400XR0 29" GAS DRYER
Maytag MGDE400XW0 29" GAS DRYER
Maytag MGDE500VF0 29" GAS DRYER
Maytag MGDE500VF1 29" GAS DRYER
Maytag MGDE500VP0 29" GAS DRYER
Maytag MGDE500VP1 29" GAS DRYER
Maytag MGDE500VW0 29" GAS DRYER
Maytag MGDE500VW1 29" GAS DRYER
Maytag MGDE500VW2 29" GAS DRYER
Maytag MGDE500WJ0 29" GAS DRYER
Maytag MGDE500WJ1 29" GAS DRYER
Maytag MGDE500WR0 29" GAS DRYER
Maytag MGDE500WR1 29" GAS DRYER
Maytag MGDE900VJ0 29" GAS DRYER
Maytag MGDE900VJ1 29" GAS DRYER
Maytag MGDE900VJ2 29" GAS DRYER
Maytag MGDE900VW0 29" GAS DRYER
Maytag MGDE900VW1 29" GAS DRYER
Maytag MGDE900VW2 29" GAS DRYER
Maytag MGDX500XL0 27" GAS DRYER
Maytag MGDX500XW0 27" GAS DRYER
Maytag MGDX550XW0 27" GAS DRYER
Maytag MGDX600XW0 27" GAS DRYER
Maytag MGDZ400TQ1 27" GAS DRYER
Maytag MGDZ400TQ2 27" GAS DRYER
Maytag MGDZ600TB1 27" GAS DRYER
Maytag MGDZ600TB2 27" GAS DRYER
Maytag MGDZ600TE2 27" GAS DRYER
Maytag MGDZ600TK1 27" GAS DRYER
Maytag MGDZ600TK2 27" GAS DRYER
Maytag MGDZ600TW1 27" GAS DRYER
Maytag MGDZ600TW2 27" GAS DRYER
Maytag MGDZ600WR0 27" GAS DRYER
Frigidaire MGF200PBDA Frg(v2) / Gas Range
Frigidaire MGF200PBDB Frg(v1) / Gas Range
Frigidaire MGF200PBWA Frg(v1) / Gas Range
Frigidaire MGF200PBWB Frg(v2) / Gas Range
Frigidaire MGF240GSA GAS RANGE
Frigidaire MGF300PBDA Frg(v1) / Gas Range
Frigidaire MGF300PBDB Wwh(v17) / Gas Range
Frigidaire MGF300PBDC Kel(v1) / Gas Range
Frigidaire MGF300PBDD Frg(v1) / Gas Range
Frigidaire MGF300PBDE Frg(v1) / Gas Range
Frigidaire MGF300PBDF Frg(v1) / Gas Range
Frigidaire MGF300PBDG Frg(v2) / Gas Range
Frigidaire MGF300PBDH
Frigidaire MGF300PBWA Frg(v2) / Gas Range
Frigidaire MGF300PBWB Wwh(v18) / Gas Range
Frigidaire MGF300PBWC Kel(v2) / Gas Range
Frigidaire MGF300PBWD Frg(v2) / Gas Range
Frigidaire MGF300PBWE Frg(v2) / Gas Range
Frigidaire MGF300PBWF Frg(v3) / Gas Range
Frigidaire MGF300PBWG Frg(v4) / Gas Range
Frigidaire MGF300PBWH
Frigidaire MGF301SBDA Frg(v1) / Gas Range
Frigidaire MGF301SBWA Frg(v2) / Gas Range
Frigidaire MGF303PGDA Frg(v1) / Gas Range
Frigidaire MGF303PGDC Frg(v1) / Gas Range
Frigidaire MGF303PGDD Frg(v2) / Gas Range
Frigidaire MGF303PGDE Frg(v3) / Gas Range
Frigidaire MGF303PGDG Universal/gas Range
Frigidaire MGF303PGDH Universal/gas Range
Frigidaire MGF303PGDJ Universal/gas Range
Frigidaire MGF303PGDK Universal/gas Range
Frigidaire MGF303PGDL Universal/gas Range
Frigidaire MGF303PGWA Frg(v2) / Gas Range
Frigidaire MGF303PGWC Frg(v4) / Gas Range
Frigidaire MGF303PGWD Frg(v5) / Gas Range
Frigidaire MGF303PGWE Frg(v6) / Gas Range
Frigidaire MGF303PGWG Universal/gas Range
Frigidaire MGF303PGWH Universal/gas Range
Frigidaire MGF303PGWJ Universal/gas Range
Frigidaire MGF303PGWK Universal/gas Range
Frigidaire MGF303PGWL Universal/gas Range
Frigidaire MGF311SBDA Frg(v3) / Gas Range
Frigidaire MGF311SBDB Wwh(v19) / Gas Range
Frigidaire MGF311SBDC Frg(v1) / Gas Range
Frigidaire MGF311SBDD Frg(v1) / Gas Range
Frigidaire MGF311SBDE Frg(v1) / Gas Range
Frigidaire MGF311SBDF Frg(v1) / Gas Range
Frigidaire MGF311SBWA Frg(v4) / Gas Range
Frigidaire MGF311SBWB Wwh(v20) / Gas Range
Frigidaire MGF311SBWC Frg(v2) / Gas Range
Frigidaire MGF311SBWD Frg(v2) / Gas Range
Frigidaire MGF311SBWE Frg(v2) / Gas Range
Frigidaire MGF311SBWF Frg(v2) / Gas Range
Frigidaire MGF312SBDA Frg(v1) / Gas Range
Frigidaire MGF312SBDC Frg(v1) / Gas Range
Frigidaire MGF312SBWA Frg(v2) / Gas Range
  #2 (permalink)
Old 08-10-2017, 02:45 AM
Senior Member
thorning is on a distinguished road
Default
I have seen this a few times when working on the older Maytag units. I also shimmed the blower in terms of its alignment . sometimes the whole motor blower housing has to be shimmed. The blower wheel is not too precise either.
Some of them seem to wobble slightly due to poor quality of the moulding process even with a new wheel. Another area to look at when you have this unit apart is if the drum has been rubbing on the blower housing due to wear of the slipper strips that support the front of the drum. As to how the material got out of whack you might check the floor to see if it as been bent up or down somewhat.
Shim things up so no rubbing or wobble is present and put it back together. Secure the parts with screws as needed. Been there and done that.
  #3 (permalink)
Old 09-04-2017, 08:46 AM
Junior Member
Default
Update: Instead of shimming the motor bracket, I took it off with motor attached and bent it back in shape. Reassembled everything and working great for a few weeks now. I was getting a faint whistling sound that may have been from the vent or maybe the slippers settling in (?). Yesterday the heater suddenly wasn't igniting again! Turns out the electrical connector to one of the solenoids is very loose fitting and popped off from vibration of unit. A little electrical tape to adhere the connector to the solenoid bracket is working for now.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer door alignment digger47 Refrigerator & Freezer Repair 0 05-31-2014 07:43 AM
Drum alignment on gas dryer herotakesafall Dryer Repair 3 04-30-2010 04:14 PM
Tumbler Alignment aclark Washer Repair 3 06-16-2009 06:39 PM
Roper Washer Tub Out of alignment JerryR Dishwasher Repair 0 03-05-2009 06:28 AM
Refrigerator Door Alignment Julie Riggleman Refrigerator & Freezer Repair 1 10-06-2008 04:13 PM
