Register | FAQ's | New Posts | Today's Posts | Extras |
» GE Dryer motor overheats and smells like burnt electrical |
![]() Model Number: GFDN110EL0WW Brand: GE Age: 5 - 10 years
![]() When dryer gets turned on will run for a few seconds and then stop after a 10 second or so will restart without touching it will continue doing this until it is shut off mannually, all the while the increasing smell of burnt electrical. At first I thought the drum was binding causing the motor to overheat. I removed the top of dryer and drum rotates smoothly and belt was ok, then proceeded to remove control panel, front door assembly, and drum. checked drum glides for wear, this point at a loss, so I proceeded to reinstall door assembly, reconnected control panel and restarted the dryer with out the drum, and received the same result, motor ran a few second then cut out, then restarted after a few seconds. So I concluded the motor was shot. My question is whether there could be some other issue I'm not considering before I go out and spend $157 for a new motor assembly? Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Gas Dryer Still Hot/Functioning But Smells Like Burnt Rubber | pspirrotta | Dryer Repair | 0 | 02-13-2015 07:32 AM |
Overheats then electrical crackle | MightyCanuck | Microwave Repair | 0 | 03-01-2010 08:40 PM |
Motor hot smells like electrical short | TomCin01 | Washer Repair | 3 | 09-20-2009 12:21 PM |
Dryer sometimes doesn't dry and smells burnt | wasabismom | Dryer Repair | 2 | 03-13-2009 10:41 AM |
Dryer Smells Like Partially Burnt Fuel | jmnardo | Dryer Repair | 2 | 02-24-2009 07:43 PM |
