I have a Whirlpool dryer, I went to start it with a load of wet clothes, and nothing. I figured it might be something minor , like a door switch or thermal fuse, being that we just used it less than 2 hours earlier before church. But hears the kicker , it wasn't either one. It will only start when it is set on the cool down setting not any other one and it will run the cool down cycle and stop which is about 10 minutes. The heat is there everything else works it just doesn't run on any other setting????? :confused: is there a way to bypass the timer till I can get a New one. Please help???????????🤔😥😤😤😤😤😵😵😵😱
