Discuss
Roper/Whirlpool dryer gas leak
 in
Dryer Repair
The gas company tested the line pressure in my house and found that my dryer, a Rooer RGX5634KQ2, is not
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Roper/Whirlpool dryer gas leak
  #1 (permalink)
Old 07-20-2017, 01:47 PM
Junior Member
STLDIYer is on a distinguished road
Default Roper/Whirlpool dryer gas leak
Model Number: RGX5634KQ2   Brand: Roper   Age: More than 10 years
The gas company tested the line pressure in my house and found that my dryer, a Rooer RGX5634KQ2, is not holding pressure.
I did a direct test on the dryer which confirms the leak. I replaced the valve assembly but the leak is still there.
By process of elimination, it seems like the timer must be the problem.
Does anyone know how I can test that, or know of any other possible cause? The connections up to the dryer don't leak, so it must be within the dryer.
Related Models
Roper RGX5634KQ2 DRYER
Roper RGX5634KQ3 29" GAS DRYER
Roper RGX5634PQ0 29" GAS DRYER
Roper RGX5635EN0 GAS DRYER
Roper RGX5635EN1 DRYERS
Roper RGX5635EN2 GAS DRYER
Roper RGX5635EN3 GAS DRYER
Roper RGX5635EQ0 GAS DRYER
Roper RGX5635EQ1 DRYERS
Roper RGX5635EQ2 GAS DRYER
Roper RGX5635EQ3 GAS DRYER
Roper RGX5635EW0 GAS DRYER
Roper RGX5635EW1 DRYERS
Roper RGX5635EW2 GAS DRYER
Roper RGX5635EW3 GAS DRYER
Roper RGX5636AL1 GAS DRYER
Roper RGX5636AL2 GAS DRYER
Roper RGX5636AW0 Residential Dryer
Roper RGX5636AW1 GAS DRYER
Roper RGX5636AW2 GAS DRYER
Roper RGX6634PQ0 29" GAS DRYER
Roper RGX6634RQ0 29" GAS DRYER
Roper RGX6634RQ1 29" GAS DRYER
Roper RGX6646AL1 GAS DRYER
Roper RGX6646AL2 GAS DRYER
Roper RGX6646AL3 GAS DRYER
Roper RGX6646AQ2 GAS DRYER
Roper RGX6646AQ3 GAS DRYER
Roper RGX6646AW0 Residential Dryer
Roper RGX6646AW1 GAS DRYER
Roper RGX6646AW2 GAS DRYER
Roper RGX6646AW3 GAS DRYER
Roper RH0500RAW00 CHEST FREEZER
Roper RH0500RDW00 CHEST FREEZER
Roper RH0500REW00 CHEST FREEZER
Roper RH0500REW01 CHEST FREEZER
Roper RH0500REW02 CHEST FREEZER
Roper RH0500RWW00 Freezers*
Roper RH0588RBW00 CHEST FREEZER
Roper RH0588REW00 CHEST FREEZER
Roper RH0588REW01 CHEST FREEZER
Roper RH0588REW02 CHEST FREEZER
Roper RH0599RBW00 CHEST FREEZER
Roper RH0599REW00 CHEST FREEZER
Roper RH0599REW01 CHEST FREEZER
Roper RH0599REW02 CHEST FREEZER
Roper RH0799RBW00 CHEST FREEZER
Roper RH0799REW00 CHEST FREEZER
Roper RH0799REW01 CHEST FREEZER
Roper RH0799REW06 FREEZERS
Jenn-Air RH100 HOOD
Roper RH1000RAW00 Freezers*
Roper RH1000RDW00 CHEST FREEZER
Roper RH1000REW00 CHEST FREEZER
Roper RH1000REW01 CHEST FREEZER
Roper RH1000REW05 CHEST FREEZER
Roper RH1000REW06 FREEZERS
Roper RH1000RYW00 Freezers*
Jenn-Air RH101 HOOD
Roper RH1099RBW00 CHEST FREEZER
Roper RH1099REW00 CHEST FREEZER
Roper RH1099REW06 FREEZERS
Roper RH1200RWW00 Freezers*
Roper RH1200RXW00 Freezers*
Whirlpool RH123 Air-conditioner/heat pump
Whirlpool RH123A1 AIR CONDITIONER
Whirlpool RH123A2 AIR CONDITIONERS
Jenn-Air RH130 HOOD
Roper RH1500RAW00 CHEST FREEZER
Roper RH1500RDW00 CHEST FREEZER
Roper RH1500REW00 CHEST FREEZER
Roper RH1500REW01 FREEZERS
Roper RH1500REW02 CHEST FREEZER
Roper RH1500REW03 FREEZERS
Roper RH1500REW04 FREEZER
Roper RH1500REW05 CHEST FREEZER
Roper RH1500REW06 FREEZERS
Roper RH1500RWW00 Freezers*
Roper RH1500RXW00 Freezers*
Roper RH1599RBW00 CHEST FREEZER
Roper RH1599REW00 CHEST FREEZER
Roper RH1599REW03 FREEZERS
Roper RH1599REW04 FREEZERS
Roper RH1599REW06 FREEZERS
Jenn-Air RH170 HOOD
Jenn-Air RH180B HOOD
Jenn-Air RH180W HOOD
Whirlpool RH183 Air-conditioner/heat pump
Jenn-Air RH186B HOOD
Jenn-Air RH186W HOOD
Jenn-Air RH200 HOOD
Whirlpool RH2024XLW0 Range Hood
Whirlpool RH2024XLW1 Range Hood
Whirlpool RH2030WXW0 Range Hood
Whirlpool RH2030XDB0 30" RANGE HOOD
Whirlpool RH2030XDB1 RANGE HOOD
Whirlpool RH2030XDQ0 30" RANGE HOOD
Whirlpool RH2030XDQ1 RANGE HOOD
Whirlpool RH2030XDS0 30" RANGE HOOD
Whirlpool RH2030XDS1 RANGE HOOD
Whirlpool RH2030XDZ0 30" RANGE HOOD
Whirlpool RH2030XDZ1 RANGE HOOD
Whirlpool RH2030XJB0 30" RANGE HOOD
Whirlpool RH2030XJB1 HOODS
Whirlpool RH2030XJB2 RANGE HOOD
Whirlpool RH2030XJB3 30" RANGE HOOD
Whirlpool RH2030XJQ0 30" RANGE HOOD
Whirlpool RH2030XJQ1 HOODS
Whirlpool RH2030XJQ2 RANGE HOOD
Whirlpool RH2030XJQ3 30" RANGE HOOD
Whirlpool RH2030XJT0 30" RANGE HOOD
Whirlpool RH2030XJT1 HOODS
Whirlpool RH2030XJT2 RANGE HOOD
Whirlpool RH2030XJT3 30" RANGE HOOD
Whirlpool RH2030XJZ1 HOODS
Whirlpool RH2030XJZ2 RANGE HOOD
Whirlpool RH2030XLW0 Range Hood
Whirlpool RH2030XLW1 Range Hood
Whirlpool RH2030XXW0 Range Hood
Whirlpool RH2036XLW1 Range Hood
  #2 (permalink)
Old 07-20-2017, 04:48 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by STLDIYer View Post
...I did a direct test on the dryer which confirms the leak...
...it seems like the timer must be the problem...
How did you do the test and what exactly did you find?
No one timer can cause a gas leak.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Roper dryer timer kparker1028 Dryer Repair 4 01-04-2017 07:55 PM
Roper (Whirlpool) dryer won't start Quasimodo1234 Dryer Repair 7 10-22-2012 08:32 AM
Roper by Whirlpool Dryer Wont Start cjduke Dryer Repair 1 07-31-2011 03:34 AM
Roper / Whirlpool Gas Dryer No Heat - what next vw412fan Dryer Repair 0 04-16-2011 03:56 PM
Roper Leak Rayh Washer Repair 1 11-17-2007 09:08 AM
