Discuss
Coin operated Gas Dryer doesn't heat on 2nd cycle
 in
Dryer Repair
We have a coin operated Maytag LDG19CS (Series 02) dryer that is set to a 20 min timer cycle. It
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Coin operated Gas Dryer doesn't heat on 2nd cycle
  #1 (permalink)
Old 07-13-2017, 10:44 AM
sup sup is offline
Junior Member
sup is on a distinguished road
Default Coin operated Gas Dryer doesn't heat on 2nd cycle
Model Number: LDG19CS   Brand: Maytag   Age: 5 - 10 years
We have a coin operated Maytag LDG19CS (Series 02) dryer that is set to a 20 min timer cycle. It heats for the 1st 15 min and then cools for the last 5 min of the 1st cycle, and the clothes are not dry at the end. When we run a 2nd cycle, there is no heat.
What would be the likely causes of no heat on a second cycle?
Thanks,
Sup
Related Models
Maytag LDG19CS MANUAL, PARTS (DRYER GAS)
Maytag LDG19CT MANUAL, PARTS (DRYER GAS)
Maytag LDG210 DRYER- GAS
Maytag LDG212 DRYER- GAS
Maytag LDG21CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG22CS MANUAL, PARTS (DRYER GAS)
Maytag LDG22CT MANUAL, PARTS (DRYER GAS)
Maytag LDG23CD MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG24CA MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG24CM MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG24CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG24CT MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG25CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG26CA MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag LDG26CD MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag LDG26CS MANUAL, PARTS (DRYER GAS)
Maytag LDG26CT MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag LDG27CA MANUAL, PARTS (DRYER GAS)
Maytag LDG27CD MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag LDG27CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG27CT MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG303 DRYER- GAS
Maytag LDG30CMD MANUAL, PARTS (DRYER GAS)
Maytag LDG312 DRYER- GAS
Maytag LDG313 DRYER- GAS
Maytag LDG31CA MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG31CM MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG31CT MAYTAG LAUNDRY (DRYER GAS)
Frigidaire LDG333PEW0 Frg(v0) / Gas Dryer
Maytag LDG33CA MANUAL, PARTS (DRYER GAS)
Maytag LDG33CM MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG34CD MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG34CQ MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG382 DRYER- GAS
Maytag LDG4000 DRYER- GAS
Maytag LDG4000AAL DRYER- GAS
Maytag LDG4000AAW DRYER- GAS
Maytag LDG4000ABL DRYER- GAS
Maytag LDG4000ABW DRYER- GAS
Maytag LDG410 DRYER- GAS
Maytag LDG412 DRYER- GAS
Maytag LDG482 DRYER- GAS
Maytag LDG490 DRYER- GAS
Maytag LDG4910 DRYER- GAS
Maytag LDG4910AAL DRYER- GAS
Maytag LDG4910AAW DRYER- GAS
Maytag LDG4914AAE DRYER- GAS
Maytag LDG4914AAL DRYER- GAS
Maytag LDG4914AAM DRYER- GAS
Maytag LDG4916AAE DRYER- GAS
Maytag LDG4916AAM DRYER- GAS
Maytag LDG5004AAW DRYER- GAS
Maytag LDG5004ABW DRYER- GAS
Maytag LDG5005AAE DRYER- GAS
Maytag LDG5005ABE DRYER- GAS
Maytag LDG510 DRYER- GAS
Maytag LDG512 DRYER- GAS
Maytag LDG590 DRYER- GAS
Maytag LDG5910 DRYER- GAS
Maytag LDG5910AAL DRYER- GAS
Maytag LDG5910AAW DRYER- GAS
Maytag LDG5914AAE DRYER- GAS
Maytag LDG5914AAL DRYER- GAS
Maytag LDG5914AAM DRYER- GAS
Maytag LDG5916AAE DRYER- GAS
Maytag LDG5916AAM DRYER- GAS
Maytag LDG6004AAW DRYER- GAS
Maytag LDG610 DRYER- GAS
Maytag LDG612 DRYER- GAS
Maytag LDG6914AAE DRYER- GAS
Maytag LDG6914AAL DRYER- GAS
Maytag LDG6914AAM DRYER- GAS
Maytag LDG710 DRYER- GAS
Maytag LDG712 DRYER- GAS
Maytag LDG713 DRYER- GAS
Maytag LDG7304AAE DRYER- GAS
Maytag LDG7304AAL DRYER- GAS
Maytag LDG7304AAM DRYER- GAS
Maytag LDG7304ABE DRYER- GAS
Maytag LDG7304ABL DRYER- GAS
Maytag LDG7304ABM DRYER- GAS
Maytag LDG7304AGE DRYER- GAS
Maytag LDG7304AGL DRYER- GAS
Maytag LDG7304AGM DRYER- GAS
Maytag LDG7304EGE DRYER- GAS
Maytag LDG7304EGL DRYER- GAS
Maytag LDG7304EGM DRYER- GAS
Maytag LDG7314AAE DRYER- GAS
Maytag LDG7314AAL DRYER- GAS
Maytag LDG7314AAM DRYER- GAS
Maytag LDG7334AAE DRYER- GAS
Maytag LDG7334AAL DRYER- GAS
Maytag LDG7334AAM DRYER- GAS
Maytag LDG7400 DRYER- GAS
Maytag LDG7400AAL DRYER- GAS
Maytag LDG7400AAW DRYER- GAS
Maytag LDG7400ABL DRYER- GAS
Maytag LDG7400ABW DRYER- GAS
Maytag LDG7480AAL DRYER- GAS
Maytag LDG7480AAW DRYER- GAS
Maytag LDG7480ABL DRYER- GAS
Maytag LDG7480ABW DRYER- GAS
Maytag LDG7500 DRYER- GAS
Maytag LDG7500AAE DRYER- GAS
Maytag LDG7500AAL DRYER- GAS
Maytag LDG7500AAM DRYER- GAS
Maytag LDG7500AAW DRYER- GAS
Maytag LDG7500ABE DRYER- GAS
Maytag LDG7500ABL DRYER- GAS
Maytag LDG7500ABM DRYER- GAS
Maytag LDG7500ABW DRYER- GAS
Maytag LDG7600 DRYER- GAS
Maytag LDG7600AAG DRYER- GAS
Maytag LDG7600AAL DRYER- GAS
Maytag LDG7600AAW DRYER- GAS
Maytag LDG7600ABL DRYER- GAS
Maytag LDG7600ABW DRYER- GAS
Maytag LDG7600AGG DRYER- GAS
Maytag LDG7600AGL DRYER- GAS
Maytag LDG7600AGW DRYER- GAS
  #2 (permalink)
Old 07-18-2017, 06:19 PM
Senior Member
brobriffin is on a distinguished road
Default
Sorry I don't have an answer however (no experience with coin op's)
you don't know how bad I just want to say add 50 cents....
Again sorry I just had to........................
Hoping this will put your thread back to the top and someone else may answer.
  #3 (permalink)
Old 07-19-2017, 03:43 PM
sup sup is offline
Junior Member
Default
I've confirmed that the gas ignites and provides heat during most of the 1st 20 minute timer cycle, but if we start a 2nd 20 minute cycle immediately, the igniter glows but there is no ignition and the igniter glow fades. If I wait a little while to start the 2nd cycle, it ignites and heats again. This dryer is probably about 20 yrs old. (P.S. Thanks for the bump brobriffin.)
  #4 (permalink)
Old 07-19-2017, 05:42 PM
Senior Member
Default
With that bit of info it sounds like the coils might be going bad..
Try this, set it to run and at about 8 to 10 minutes open the door or whatever to interrupt the cycle then in a few seconds or so shut the door and restart the cycle.
Does the gas ignite right away?
  #5 (permalink)
Old 07-19-2017, 08:53 PM
sup sup is offline
Junior Member
Default
I did that today at around 5 min into the 1st cycle and the gas did ignite.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
maytag coin operated dryer doppilas Dryer Repair 1 02-15-2013 03:29 PM
Maytag Coin Operated Electric Dryer Timer MMoore1953 Dryer Repair 0 02-07-2012 06:30 AM
Coin operated gas dryer will not stop by timer robert yang Dryer Repair 2 12-29-2010 02:17 PM
Maytag coin operated gas dryer not heating larry510 Dryer Repair 0 05-03-2010 03:40 PM
GE coin operated washer adamweb Washer Repair 0 04-08-2010 02:32 PM
