Hi All,
Hoping someone can shed some light on a heating issue on my dryer. The symptoms were originally that the burner never came on. It would start up and just run and run with no heat. Had a tech come out and diagnose it who recommended replacing the control board and thermistor on the back side. I felt like I could do the work myself so I ordered the parts and replaced them both. Now the flame comes on for 10 seconds and then goes out. The board doesn't seem to be the problem because the old and new one have the same result. There's not blockage issues as we just had the vents cleaned not long ago. I've replaced the coils twice in the last couple years so I didn't think that was the issue. Do they go back that quickly? I even bought a new flame sensor and tried that with the same result. Any other ideas? Thanks. Doug
