Discuss
Auto Dry not functioning Maytag
 in
Dryer Repair
I have a maytag dryer that works great except for auto dry function on timer, timed dry works great. The
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Auto Dry not functioning Maytag
  #1 (permalink)
Old 07-01-2017, 10:52 AM
Junior Member
Daddeo is on a distinguished road
Default Auto Dry not functioning Maytag
Model Number: SDE305DAYW   Brand: Maytag   Age: More than 10 years
I have a maytag dryer that works great except for auto dry function on timer, timed dry works great. The auto dry never moves and just runs and doesn't shut off. Everything is very clean, air flow is clear and dries great on timed dry. I also see that the heater coils cycle on and off. Is this a timer issue or cycling thermostat. The unit works great but i think dangerous if someone uses timed dry since it will keep running.
Related Models
Maytag SDE305DAYW DRYER- ELE
Maytag SDE305DAZW DRYER- ELE
Maytag SDE3606AYQ DRYER- ELE
Maytag SDE3606AYW DRYER- ELE
Maytag SDE3606AZW DRYER- ELE
Maytag SDE4000AYW DRYER- ELE
Maytag SDE4000AZW DRYER- ELE
Maytag SDE405DAYW DRYER- ELE
Maytag SDE4606AYW DRYER- ELE
Maytag SDE4606AZW DRYER- ELE
Maytag SDE505DAYQ DRYER- ELE
Maytag SDE505DAYW DRYER- ELE
Maytag SDE505DAZW DRYER- ELE
Maytag SDE515DAYW DRYER- ELE
Maytag SDE515DAZW DRYER- ELE
Maytag SDE5401AYW DRYER- ELE
Maytag SDE5401AZW DRYER- ELE
Maytag SDE5701AYQ DRYER- ELE
Maytag SDE5701AYW DRYER- ELE
Maytag SDE5701AZW DRYER- ELE
Maytag SDG2606AWW DRYER- GAS
Maytag SDG305DAWW DRYER- GAS
Maytag SDG3606AWQ DRYER- GAS
Maytag SDG3606AWW DRYER- GAS
Maytag SDG4000AWW DRYER- GAS
Maytag SDG405DAWW DRYER- GAS
Maytag SDG4606AWW DRYER- GAS
Maytag SDG505DAWQ DRYER- GAS
Maytag SDG505DAWW DRYER- GAS
Maytag SDG505DAXW DRYER- GAS
Maytag SDG515DAWW DRYER- GAS
Maytag SDG5401AWW DRYER- GAS
Maytag SDG5401AXW DRYER- GAS
Maytag SDG5701AWQ DRYER- GAS
Maytag SDG5701AWW DRYER- GAS
Maytag SDG5701AXW DRYER- GAS
Whirlpool SDH481B0 DEHUMIDIFIER
Whirlpool SDH501B20 DEHUMIDIFIER
Amana SDI22A REF - SXS/I&W
Amana SDI22A-A REF - SXS/I&W
Amana SDI22A-AG REF - SXS/I&W
Amana SDI22A-C REF - SXS/I&W
Amana SDI22B REF - SXS/I&W
Amana SDI22B-A REF - SXS/I&W
Amana SDI22B-C REF - SXS/I&W
Amana SDI22B-G REF - SXS/I&W
Amana SDI22B-L REF - SXS/I&W
Amana SDI22C REF - SXS/I&W
Amana SDI22C-A REF - SXS/I&W
Amana SDI22C-C REF - SXS/I&W
Amana SDI22C-G REF - SXS/I&W
Amana SDI22C-L REF - SXS/I&W
Amana SDI22D REF - SXS/I&W
Amana SDI22E REF - SXS/I&W
Amana SDI22E-1-A REF - SXS/I&W
Amana SDI22E-1-C REF - SXS/I&W
Amana SDI22E-A REF - SXS/I&W
Amana SDI22E-C REF - SXS/I&W
Amana SDI22E-G REF - SXS/I&W
Amana SDI22E-L REF - SXS/I&W
Amana SDI22E1 REF - SXS/I&W
Amana SDI22E1G REF - SXS/I&W
Amana SDI22E1L REF - SXS/I&W
Amana SDI22F Ref - SXS/I&W
Amana SDI22F-1 REF - SXS/I&W
Amana SDI22F-1-G REF - SXS/I&W
Amana SDI22F-1-L REF - SXS/I&W
Amana SDI22F-G Ref - SXS/I&W
Amana SDI22F-L Ref - SXS/I&W
Amana SDI22FA REF - SXS/I&W
Amana SDI22FC REF - SXS/I&W
Amana SDI22FG Ref - SXS/I&W
Amana SDI22FL Ref - SXS/I&W
Amana SDI22G Ref - SXS/I&W
Amana SDI22GG Ref - SXS/I&W
Amana SDI22GL REF - SXS/I&W
Amana SDI22N REF - SXS/I&W
Amana SDI22N-1 REF - SXS/I&W
Amana SDI22N-1-A REF - SXS/I&W
Amana SDI22N-1-AG REF - SXS/I&W
Amana SDI22N-1-C REF - SXS/I&W
Amana SDI22N-A REF - SXS/I&W
Amana SDI22N-AG REF - SXS/I&W
Amana SDI22N-C REF - SXS/I&W
Amana SDI22W REF - SXS/I&W
Amana SDI22W-A REF - SXS/I&W
  #2 (permalink)
Old 07-05-2017, 01:50 PM
Junior Member
LC in MI is on a distinguished road
Smile Auto Dry Not working - never shuts dryer off.
Quote:
Dadeo, I think you meant the dryer might be dangerous in Auto Dry mode, since is does stop in timed mode. Correct me if I misunderstood your post.
I'm having same issue on a Maytag MDG69206AWW gas dryer. I checked the temp cycle switch with ohm meter, reads zero ohms when cold, put it in temp of about 180, heard it click, then ohms >1000, so it is not the temp cycle switch.
Any ideas on how to proceed?
  #3 (permalink)
Old 07-06-2017, 10:52 PM
Senior Member
PNWDrew is on a distinguished road
Default
Quick guess it's the cycling thermostat or the thermostat heater attached to it.
  #4 (permalink)
Old 07-08-2017, 03:07 PM
Junior Member
Default
To PNWDrew, thanks, I will try replacing it and post if this fixes it.
  #5 (permalink)
Old 07-08-2017, 06:45 PM
Junior Member
Default
Others have suggested it may be the following part, but it is no longer available from the Manufacturer.
Is there another source for it?
Switch, Temperature
Part Number: AP4042477
Made by: Whirlpool
  #6 (permalink)
Old 07-09-2017, 10:26 AM
Senior Member
Default
It's possible that it's that switch but not what I'd expect.
Use the actual manufacturer # 33001640 to look for it. The AP #s are for this site. It's available if you Google that #.
If you look at the wiring diagram you're looking for where power to the timer motor comes from. It does pass through that switch so with out testing contacts in the switch it's impossible to rule out.
I don't recall having ever changed one but in 20yrs of doing this I've learned to forget quickly and just diagnose on the spot. I know I haven't done very many at least.
Do you have a multi meter to do electrical checks? What you'd be looking for is if the timer motor is being powered when it is empty and running on an Auto Dry setting. It may take 15-20 min before the machine asks the timer to advance when it's empty but at some point the timer motor should be powered and begin advancing the knob. During time dry that motor should be powered and advancing the knob for the entire time.
  #7 (permalink)
Old 07-13-2017, 07:08 PM
Junior Member
Default
Quote:
Replacing the Temp Switch fixed the problem. Apparently the old Temp switch was failing intermittenltly, so when checked it would sometimes work.
Thanks to folks at APPros for the excellent video on how to install this temp switch.
  #8 (permalink)
Old 07-13-2017, 11:03 PM
Senior Member
Default
Awesome, I'll remember to consider that switch if I see one with similar issues. Glad you got it.
  #9 (permalink)
Senior Member
Default
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Control Dial Not Functioning mahtz2 Dryer Repair 3 07-16-2015 02:33 PM
Maytag water/ice dispenser and light stopped functioning Tater Salad Refrigerator & Freezer Repair 1 02-19-2013 06:05 PM
maytag auto dry not working wcnesta Dryer Repair 1 08-18-2011 03:36 AM
Maytag Performa not functioning properly gbflynn Dryer Repair 1 05-24-2011 02:47 PM
Maytag range. Cooktop functioning, but oven just says OFF watkinsnc Oven Repair (including Ranges and Cooktops) 1 11-21-2010 11:23 AM
