Discuss
Whirlpool dryer
 in
Dryer Repair
I've replaced the fuse, limit switches, thermostat and had a parts house test the heater could. Has air but still
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool dryer
  #1 (permalink)
Old 06-16-2017, 06:05 PM
Junior Member
Wabasmstr is on a distinguished road
Default Whirlpool dryer
Model Number: LER7646JQ0   Brand: Whirlpool   Age: 1 - 5 years
I've replaced the fuse, limit switches, thermostat and had a parts house test the heater could. Has air but still no heat. Tested continuity on all parts. All are good. Any ideas what to do next?
Related Models
Whirlpool LER7646JQ0 DRYER
Whirlpool LER7646JT0 DRYER
Whirlpool LER7648KQ0 RESIDENTIAL DRYER
Whirlpool LER7648KQ1 RESIDENTIAL DRYER
Whirlpool LER7648KQ2 RESIDENTIAL DRYER
Whirlpool LER7648KQ3 29"ELECTRIC DRYER
Whirlpool LER7648KT0 RESIDENTIAL DRYER
Whirlpool LER7648KT1 RESIDENTIAL DRYER
Whirlpool LER7648KT2 RESIDENTIAL DRYER
Whirlpool LER7648KT3 29"ELECTRIC DRYER
Whirlpool LER7648PQ0 29" ELECTRIC DRYER
Whirlpool LER7648PQ1 29" ELECTRIC DRYER
Whirlpool LER7648PT0 29" ELECTRIC DRYER
Whirlpool LER7648PT1 29" ELECTRIC DRYER
Whirlpool LER7848DQ0 ELECTRIC DRYER
Whirlpool LER7848DQ1 ELECTRIC DRYER
Whirlpool LER7848DZ0 ELECTRIC DRYER
Whirlpool LER7848DZ1 ELECTRIC DRYER
Whirlpool LER7858AN1 ELECTRIC DRYER
Whirlpool LER7858AN2 ELECTRIC DRYER
Whirlpool LER7858AW0 Residential Dryer
Whirlpool LER7858AW1 ELECTRIC DRYER
Whirlpool LER7858AW2 ELECTRIC DRYER
Whirlpool LER8620PG0 29"ELECTRIC DRYER
Whirlpool LER8620PG1 29"ELECTRIC DRYER
Whirlpool LER8620PW0 29"ELECTRIC DRYER
Whirlpool LER8620PW1 29"ELECTRIC DRYER
Whirlpool LER8648LG0 RESIDENTIAL DRYER
Whirlpool LER8648LG1 29"ELECTRIC DRYER
Whirlpool LER8648LQ0 RESIDENTIAL DRYER
Whirlpool LER8648LW0 RESIDENTIAL DRYER
Whirlpool LER8648LW1 29"ELECTRIC DRYER
Whirlpool LER8648PG0 29"ELECTRIC DRYER
Whirlpool LER8648PG1 29"ELECTRIC DRYER
Whirlpool LER8648PQ0 29" ELECTRIC DRYER
Whirlpool LER8648PQ1 29"ELECTRIC DRYER
Whirlpool LER8648PW0 29"ELECTRIC DRYER
Whirlpool LER8648PW1 29"ELECTRIC DRYER
Whirlpool LER8857EQ0 ELECTRIC DRYER
Whirlpool LER8857EQ1 DRYERS
Whirlpool LER8857EQ2 ELECTRIC DRYER
Whirlpool LER8857EZ0 ELECTRIC DRYER
Whirlpool LER8857EZ1 DRYERS
Whirlpool LER8857EZ2 ELECTRIC DRYER
Whirlpool LER8858DQ0 ELECTRIC DRYER
Whirlpool LER8858DQ1 ELECTRIC DRYER
Whirlpool LER8858DZ0 ELECTRIC DRYER
Whirlpool LER8858DZ1 ELECTRIC DRYER
Whirlpool LER8858EQ0 ELECTRIC DRYER
Whirlpool LER8858EQ1 DRYERS
Whirlpool LER8858EQ2 ELECTRIC DRYER
Whirlpool LER8858EZ0 ELECTRIC DRYER
Whirlpool LER8858EZ1 DRYERS
Whirlpool LER8858EZ2 ELECTRIC DRYER
Whirlpool LER8875EQ1 ELECTRIC DRYER
Amana LES10AW WASHER-TOP LOADING
Amana LES19AW DRYER- GAS
Amana LES33AW DRYER- GAS
Amana LES34AW WASHER-TOP LOADING
Frigidaire LES389FEA Frigidaire/electric Range
Frigidaire LESR26EFE0 Frigidaire/refrigerator
Frigidaire LESR26EFE3 REFRIGERATOR
Frigidaire LESR26EFE4 REFRIGERATOR
Frigidaire LESR26EFE5 REFRIGERATOR
Frigidaire LESR26EFE6 REFRIGERATOR
Frigidaire LESR26EFE7 REFRIGERATOR
Whirlpool LET5434AQ0 Residential Dryer
Whirlpool LET5434AW0 Residential Dryer
Whirlpool LET5436AW0 Residential Dryer
Whirlpool LET5624BN0 ELECTRIC DRYER
Whirlpool LET5624BN1 ELECTRIC DRYER
Whirlpool LET5624BN2 ELECTRIC DRYER
Whirlpool LET5624BQ0 ELECTRIC DRYER
Whirlpool LET5624BQ1 ELECTRIC DRYER
Whirlpool LET5624BQ2 ELECTRIC DRYER
Whirlpool LET5624BW0 ELECTRIC DRYER
Whirlpool LET5624BW1 ELECTRIC DRYER
Whirlpool LET5624BW2 ELECTRIC DRYER
Whirlpool LET5624DQ0 ELECTRIC DRYER
Whirlpool LET5624DQ1 DRYER
Whirlpool LET6634AN1 ELECTRIC DRYER
Whirlpool LET6634AN2 ELECTRIC DRYER
Whirlpool LET6634AQ0 ELECTRIC DRYER
Whirlpool LET6634AQ1 ELECTRIC DRYER
Whirlpool LET6634AQ2 ELECTRIC DRYER
Whirlpool LET6634AW0 Residential Dryer
Whirlpool LET6634AW1 ELECTRIC DRYER
Whirlpool LET6634AW2 ELECTRIC DRYER
Whirlpool LET6634DQ0 ELECTRIC DRYER
Whirlpool LET6634DQ1 ELECTRIC DRYER
Whirlpool LET6634DZ0 ELECTRIC DRYER
Whirlpool LET6634DZ1 ELECTRIC DRYER
Whirlpool LET6638AN1 DRYER
Whirlpool LET6638AN2 ELECTRIC DRYER
Whirlpool LET6638AQ2 ELECTRIC DRYER
Whirlpool LET6638AW0 Residential Dryer
Whirlpool LET6638AW1 DRYER
Whirlpool LET6638AW2 ELECTRIC DRYER
Whirlpool LET6638DQ0 ELECTRIC DRYER
Whirlpool LET6638DQ1 ELECTRIC DRYER
Whirlpool LET6638DZ0 ELECTRIC DRYER
Whirlpool LET6638DZ1 ELECTRIC DRYER
Whirlpool LET7646AQ0 Residential Dryer
Whirlpool LET7646AQ1 ELECTRIC DRYER
Whirlpool LET7646AQ2 ELECTRIC DRYER
Whirlpool LET7646AW0 Residential Dryer
Whirlpool LET7646AZ1 ELECTRIC DRYER
Whirlpool LET7646AZ2 ELECTRIC DRYER
Whirlpool LET7646DQ0 ELECTRIC DRYER
Whirlpool LET7646DQ1 ELECTRIC DRYER
Whirlpool LET7646DZ0 ELECTRIC DRYER
Whirlpool LET7646DZ1 ELECTRIC DRYER
Whirlpool LET7646EQ0 ELECTRIC DRYER
Whirlpool LET7646EQ1 DRYERS
Whirlpool LET7646EQ2 ELECTRIC DRYER
Whirlpool LET7646EZ0 ELECTRIC DRYER
Whirlpool LET7646EZ1 DRYERS
Whirlpool LET7646EZ2 ELECTRIC DRYER
Whirlpool LET7848AQ0 Residential Dryer
Whirlpool LET7848AQ1 ELECTRIC DRYER
  #2 (permalink)
Old 06-16-2017, 06:52 PM
Senior Member
brobriffin is on a distinguished road
Default
1. test for actual 240 volts across L1 and L2 at the terminal block
2. check to see if the centrifugal switch on the motor is passing 120 volts to the heating element
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Burned Dryer Plug - Whirlpool Electric Dryer EastCobbSnob Dryer Repair 5 12-09-2013 07:43 PM
Whirlpool Thin Twin Washer Dryer Combo, Dryer won't heat up NVChickey Dryer Repair 1 02-26-2012 12:52 AM
Whirlpool Dryer won't start in dryer mode. hol99 Dryer Repair 4 06-18-2011 07:42 AM
Whirlpool Dryer won't start in dryer mode. hol99 Dryer Repair 7 12-27-2010 04:34 AM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 11:47 AM
