Discuss
Dryer tripping the breaker after 30 seconds
 in
Dryer Repair
I turn on the dryer and it seems to work properly. It spins and is hot inside. After about 30
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer tripping the breaker after 30 seconds
  #1 (permalink)
Old 06-09-2017, 11:26 AM
Junior Member
RPollard is on a distinguished road
Default Dryer tripping the breaker after 30 seconds
Model Number: 86477810   Brand: Kenmore   Age: 5 - 10 years
I turn on the dryer and it seems to work properly. It spins and is hot inside. After about 30 seconds it's tripping the breaker (both breakers are connected with a bar). I pulled off the back of the dryer and cleaned all the connections that had some lint built up on them. All the wires appeared to be connected fine with no loose wires or burn marks. I started the dryer again and the same thing happens. I did not pull off the front of the dryer to see if any electrical connections were dirty with lint. What should I check next?
Related Models
Frigidaire 86557-7A CHEST FREEZER
Magic Chef 8660PB SURFACE UNIT- ELE
Magic Chef 8660PV SURFACE UNIT- ELE
Magic Chef 8670PB SURFACE UNIT- ELE
Magic Chef 8670PV SURFACE UNIT- ELE
Magic Chef 8670RB SURFACE UNIT- ELE
Magic Chef 8670RV SURFACE UNIT- ELE
Jenn-Air 86732 MISC / ACCESSORY
Amana 86851 REF - TOP MOUNT
Frigidaire 86851-0A FREEZER
Frigidaire 86851-0B FREEZER
Frigidaire 86851-0D FREEZER
Amana 86855 REF - TOP MOUNT
Amana 86858 REF - TOP MOUNT
Amana 86861 REF - TOP MOUNT
Amana 86861W REF - TOP MOUNT
Amana 86868 REF - TOP MOUNT
Amana 86868L REF - TOP MOUNT
Amana 86871 REF - TOP MOUNT
Amana 86878 REF - TOP MOUNT
Magic Chef 86HA-1 SURFACE UNIT- ELE
Magic Chef 86HK-1 SURFACE UNIT- ELE
Magic Chef 86HN-1 SURFACE UNIT- ELE
Magic Chef 86HS-1 SURFACE UNIT- ELE
Magic Chef 86HY-1 SURFACE UNIT- ELE
Magic Chef 86LA-1 SURFACE UNIT- ELE
Magic Chef 86LK-1 SURFACE UNIT- ELE
Magic Chef 86LN-1 SURFACE UNIT- ELE
Magic Chef 86LS-1 SURFACE UNIT- ELE
Magic Chef 86LW-1 SURFACE UNIT- ELE
Hoover 87
Amana 8700.A MWAVE - FAMILY SIZE (60 HZ)
Magic Chef 8710PA SURFACE UNIT- ELE
Magic Chef 8710PB SURFACE UNIT- ELE
Magic Chef 8710PS SURFACE UNIT- ELE
Magic Chef 8710PW SURFACE UNIT- ELE
Magic Chef 8710VB SURFACE UNIT- ELE
Magic Chef 8710VD SURFACE UNIT- ELE
Magic Chef 8710VS SURFACE UNIT- ELE
Magic Chef 8710VV SURFACE UNIT- ELE
Magic Chef 8720PA SURFACE UNIT- ELE
Magic Chef 8720PS SURFACE UNIT- ELE
Magic Chef 8720PW SURFACE UNIT- ELE
Magic Chef 8720VB SURFACE UNIT- ELE
Magic Chef 8720VD SURFACE UNIT- ELE
Magic Chef 8720VQ SURFACE UNIT- ELE
Magic Chef 8720VS SURFACE UNIT- ELE
Magic Chef 8720VV SURFACE UNIT- ELE
Amana 874.000 RANGE- S/C S/I DDRAFT GAS
Amana 874.001 RANGE- S/C S/I DDRAFT GAS
Amana 874.301 MWAVE - FAMILY SIZE (60 HZ)
Amana 874.302 MWAVE - FAMILY SIZE (60 HZ)
Amana 874.304 MWAVE - FAMILY SIZE (60 HZ)
Amana 874.305 MWAVE - FAMILY SIZE (60 HZ)
Amana 876.A MWAVE - FAMILY SIZE (60 HZ)
Amana 876.B MWAVE - FAMILY SIZE (60 HZ)
Magic Chef 8770RB SURFACE UNIT- ELE
Magic Chef 8770RV SURFACE UNIT- ELE
Jenn-Air 87848 RANGE- F/S STD DDRAFT ELE
Jenn-Air 87849 RANGE- F/S STD DDRAFT ELE
Jenn-Air 87899 MISC / ACCESSORY
Jenn-Air 87904 ELE CARTRIDGE
Jenn-Air 87914 MISC / ACCESSORY
Jenn-Air 87919 MISC / ACCESSORY
Niagra 8795-0 4000 WATT PORTABLE AC GENERATOR
Magic Chef 87LA-1 SURFACE UNIT- ELE
Magic Chef 87LA-1G SURFACE UNIT- ELE
Magic Chef 87LK-1 SURFACE UNIT- ELE
Magic Chef 87LN-1 SURFACE UNIT- ELE
Magic Chef 87LN-1G SURFACE UNIT- ELE
Magic Chef 87LS-1 SURFACE UNIT- ELE
Magic Chef 87LS-1G SURFACE UNIT- ELE
Hoover 88
Amana 880.000 RANGE- S/C S/I DDRAFT GAS
Amana 880.001 RANGE- S/C S/I DDRAFT GAS
Amana 880.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 880.003 RANGE- S/C S/I DDRAFT GAS
Amana 880.004 RANGE- S/C S/I DDRAFT GAS
Amana 880.110 RANGE- S/C S/I DDRAFT GAS
Amana 880.120 RANGE- S/C S/I DDRAFT GAS
Amana 880.130 RANGE- S/C S/I DDRAFT GAS
Amana 880.130*1 LITTON BUILT-IN WALL OVEN
Amana 880.130x1 RANGE- S/C S/I DDRAFT GAS
Frigidaire 88057-7A CHEST FREEZER
Whirlpool 880652124P0 30" ELECTRIC CERAN FREESTANDING RANGE STANDARD CLEAN OVEN
Frigidaire 88157-7A CHEST FREEZER
Frigidaire 88158-7A CHEST FREEZER
Frigidaire 88158A CHEST FREEZER
Frigidaire 88161-0A FREEZER
Frigidaire 88161-0B FREEZER
Frigidaire 88161-0D FREEZER
Jenn-Air 88168 RANGE- F/S STD DDRAFT ELE
Jenn-Air 88169 RANGE- F/S STD DDRAFT ELE
Jenn-Air 88170 RANGE- F/S STD DDRAFT ELE
Jenn-Air 88186 MISC / ACCESSORY
Frigidaire 88258-7A FREEZER
Frigidaire 88258-7B FREEZER
Frigidaire 88269A CHEST FREEZER
Frigidaire 88269B CHEST FREEZER
Jenn-Air 88353 SURFACE UNIT- ELE
Jenn-Air 88353-8 SURFACE UNIT- ELE
Jenn-Air 88368 RANGE- F/S STD DDRAFT ELE
Jenn-Air 88369 RANGE- F/S STD DDRAFT ELE
Jenn-Air 88370 RANGE- F/S STD DDRAFT ELE
Jenn-Air 88371 RANGE- F/S STD DDRAFT ELE
Jenn-Air 88372 RANGE- F/S STD DDRAFT ELE
Whirlpool 885450 ELECTRIC DRYER
Whirlpool 885453 ELECTRIC DRYER
Whirlpool 885455 ELECTRIC DRYER
Whirlpool 885456 ELECTRIC DRYER
Whirlpool 885457 ELECTRIC DRYER
Whirlpool 885458 ELECTRIC DRYER
Whirlpool 885461 ELECTRIC DRYER
Whirlpool 885462 ELECTRIC DRYER
Whirlpool 885463 ELECTRIC DRYER
Whirlpool 885464 ELECTRIC DRYER
Whirlpool 885465 ELECTRIC DRYER
Whirlpool 885468 ELECTRIC DRYER
  #2 (permalink)
Old 06-10-2017, 06:21 AM
Senior Member
brobriffin is on a distinguished road
Default
Starting with he electric itself.
1. Pull the electric cord from the socket and see if there is evidence of a short circuit. Look at both of the flat prongs to see if they have burn marks.
2. With the electric disconnected remove the cover from the electric terminal block. See if there is any shorted, burnt or loose connections on the incoming power.
Now move on to check for shorts in the system. With the system still unplugged.
1. Check for continuity between the right side connection at the terminal block and any spot on the case of the machine.
2. Do the same for the left side.
If you have continuity between either hot leg and the case then there is an internal short. I would suspect to look first at a short between the heating element and its case. Check for continuity between either heating element connection and its case then the other. If not this may still be the case but the element is not touching the case until it gets hot and sags a little. You can check to see if there is some sagging by pulling of the heating case and look at the gap inside between the wiring and the case.
If not then it might be your motor is going bad and drawing to many amps as it heats up. Do you hear a buzzing or humming sound when you start the machine.
Try these checks and let us know the results.
  #3 (permalink)
Old 06-10-2017, 06:28 AM
Senior Member
Default
One more thought that it may be a weak circuit breaker.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Dryer tripping the breaker Old Peculier Dryer Repair 1 02-25-2015 07:20 AM
roper dryer tripping the breaker Danny F Dryer Repair 0 10-12-2014 09:42 AM
HELP! Dryer keeps tripping circuit breaker. Lloydj Dryer Repair 1 01-29-2014 04:57 PM
Dryer hot - tripping breaker robgreenaway Dryer Repair 0 10-07-2013 05:39 PM
Dryer tripping breaker Solrac45 Dryer Repair 1 08-18-2013 03:56 AM
