thorning
#1 Posted : Saturday, May 20, 2017 4:02:54 AM(UTC)
thorning
I am currently in possession of an AMANA electric dryer that I bought knowing it needed a new motor due to worn out bearings. I ordered a replacement motor from a supplier on flea bay. The motor removed has the following markings-p/n 40099801 and model S 58NXMZD6910 and the shaft turns CCW as viewed from the blower wheel end. The motor I rec'd has the following markings p/n W10396029 and model S58VMZK6925. The main problem is the newer motor turns the opposite rotation which is CW and will not work. Has any reader tried successfully to rewire the direction of rotation one of these motors ? Is it practical to do this ?
brobriffin
#2 Posted : Saturday, May 20, 2017 5:39:46 AM(UTC)
brobriffin
Man
United States
I do not think this would be practical. Unlike a washer motor that uses a capacitor to start and run allowing for bidirectional use, dryer motors work from a high and low set of windings. When the motor gets up to rpm the centrifugal switch disconnects the low side. These motors in my opinion are designed to run only one direction.
If you were to try and reverse the power flow you would have to rewire both high and low windings, then hope the centrifugal switch would transfer to the proper side.
Thats my 2 cents
thorning
#3 Posted : Saturday, May 20, 2017 6:13:22 AM(UTC)
thorning
Thanks.
It sounds like it would be very difficult and not worth the effort.
Amana electric dryer model NED4800VQ1 (Dryer Repair)
by thorning 9/22/2022 8:05:59 AM(UTC)
Amana Electric Dryer Buzzing Sound (Dryer Repair)
by amanabert 5/12/2012 11:48:31 AM(UTC)
Amana Electric Dryer Miswired? (Dryer Repair)
by lacer8 10/26/2011 10:01:30 PM(UTC)
Amana Electric Dryer runs for a while. (Dryer Repair)
by Pyro 9/19/2011 6:43:49 PM(UTC)
Amana Electric Dryer Won't Heat (Dryer Repair)
by RandyMarthaKatieNutmeg 6/13/2011 11:44:46 AM(UTC)
Amana electric dryer not heating up (Dryer Repair)
by Ultraman50 1/6/2011 6:58:54 PM(UTC)
Amana electric dryer (Dryer Repair)
by james oteri 12/20/2010 1:50:22 PM(UTC)
Amana electric dryer won't heat (Dryer Repair)
by johnbharvey 7/2/2010 2:31:46 PM(UTC)
Amana electric dryer - no heat (Dryer Repair)
by TimInOhio 10/15/2009 12:05:13 AM(UTC)
need instructions for replacing the rollers and beltfor a amana electric dryer (Dryer Repair)
by bigun 9/9/2009 6:59:42 AM(UTC)
Amana Electric Dryer makes noise (Dryer Repair)
by SVCtech 7/16/2009 12:59:30 PM(UTC)
Amana Electric Dryer (Dryer Repair)
by ctmalone 4/18/2009 8:02:03 AM(UTC)
Amana electric dryer with no heat (Dryer Repair)
by toth559 9/16/2008 3:48:24 AM(UTC)
Amana Electric Dryer - No heat (Dryer Repair)
by jxg8171 5/22/2008 7:04:08 AM(UTC)
Amana Electric Dryer- No Heat (Dryer Repair)
by didier 10/24/2007 2:01:14 PM(UTC)
