Discuss
Kenmore 61262 only runs in low heat
 in
Dryer Repair
Please help. If i run my dryer on anything but low or no heat it trips the breaker. I can
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore 61262 only runs in low heat
  #1 (permalink)
Old 05-11-2017, 03:57 PM
Junior Member
Jonas76 is on a distinguished road
Default Kenmore 110.61262312 only runs in low heat
Model Number: 61262 110   Brand: Kenmore   Age: Less than 1 year
Please help. If i run my dryer on anything but low or no heat it trips the breaker. I can start it right back up once flipping breaker, but I need to figure out asap. Not even a year old. Just started this tuesday night
Related Models
Amana 614-2N ROOM AIR CONDITIONER
Amana 614-2P ROOM AIR CONDITIONER
Amana 614-2W ROOM AIR CONDITIONER
Amana 615-2F ROOM AIR CONDITIONER
Amana 615-2G ROOM AIR CONDITIONER
Amana 615-2J ROOM AIR CONDITIONER
Magic Chef 6157WRA RANGE- S/I STD GAS
Magic Chef 6157WRW RANGE- S/I STD GAS
Magic Chef 6157WTA RANGE- S/I STD GAS
Magic Chef 6157WTV RANGE- S/I STD GAS
Magic Chef 6157WTW RANGE- S/I STD GAS
Magic Chef 6157WUA RANGE- S/I STD GAS
Magic Chef 6157WUW RANGE- S/I STD GAS
Magic Chef 6157XRA RANGE- S/I STD GAS
Magic Chef 6157XRW RANGE- S/I STD GAS
Magic Chef 6157XTA RANGE- S/I STD GAS
Magic Chef 6157XTW RANGE- S/I STD GAS
Magic Chef 6157XUA RANGE- S/I STD GAS
Magic Chef 6157XUW RANGE- S/I STD GAS
Amana 619-3P ROOM AIR CONDITIONER
Amana 619-3W ROOM AIR CONDITIONER
Maytag 61C DRYER- GAS
Magic Chef 61HA-1 RANGE- S/I STD GAS
Magic Chef 61HA-3KW RANGE- S/I STD GAS
Magic Chef 61HA-3KX RANGE- S/I STD GAS
Magic Chef 61HN-1 RANGE- S/I STD GAS
Magic Chef 61HN-3KW RANGE- S/I STD GAS
Magic Chef 61HN-3KX RANGE- S/I STD GAS
Magic Chef 61HY-1 RANGE- S/I STD GAS
Magic Chef 61HY-3KW RANGE- S/I STD GAS
Magic Chef 61HY-3KX RANGE- S/I STD GAS
Magic Chef 61S04PAA RANGE- S/I STD GAS
Magic Chef 61S04PAW RANGE- S/I STD GAS
Magic Chef 61S14WAA RANGE- S/I STD GAS
Magic Chef 61S14WAW RANGE- S/I STD GAS
Magic Chef 61S14XAA RANGE- S/I STD GAS
Magic Chef 61S14XAB RANGE- S/I STD GAS
Magic Chef 61S14XAW RANGE- S/I STD GAS
Maytag 61W DRYER- GAS
Hoover 62
Frigidaire 6207B AUTOMATIC WASHER
Frigidaire 6208A WASHER
Amana 621-3F ROOM AIR CONDITIONER
Amana 621-3G ROOM AIR CONDITIONER
Amana 621-3J ROOM AIR CONDITIONER
Amana 621-3J-1 ROOM AIR CONDITIONER
Amana 621-5F ROOM AIR CONDITIONER
Amana 621-5G ROOM AIR CONDITIONER
Amana 621-5G-1 ROOM AIR CONDITIONER
Amana 621-5J ROOM AIR CONDITIONER
Amana 621.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 621.001 MWAVE - FAMILY SIZE (60 HZ)
Kenmore 6221338550 TRASH COMPACTOR
Kenmore 6221358550 TRASH COMPACTOR
Kenmore 6221388550 TRASH COMPACTOR
Kenmore 62260002600 KENMORE COOKING
Kenmore 62260003600 KENMORE COOKING
Kenmore 62260008600 KENMORE COOKING
Kenmore 62260009600 KENMORE COOKING
Kenmore 6228369301NZ KENMORE COMPACTOR
Kenmore 6228415001NO SEARS COMPACTOR
Kenmore 6228416001GO KENMORE COMPACTOR
Kenmore 62284169900 SEARS COMPACTOR
Kenmore 6228419001GO KENMORE COMPACTOR
Kenmore 62284199910 KENMORE COMPACTOR
Kenmore 62284199920 SEARS COMPACTOR
Amana 624-3F ROOM AIR CONDITIONER
Amana 624-3FH ROOM AIR CONDITIONER
Amana 624-3G ROOM AIR CONDITIONER
Amana 624-3GH ROOM AIR CONDITIONER
Amana 624-3HW ROOM AIR CONDITIONER
Amana 624-3J ROOM AIR CONDITIONER
Amana 624-3J-1 ROOM AIR CONDITIONER
Amana 624-3JH ROOM AIR CONDITIONER
Amana 624-3W ROOM AIR CONDITIONER
Amana 624-5F ROOM AIR CONDITIONER
Amana 624-5FH ROOM AIR CONDITIONER
Amana 624-5G ROOM AIR CONDITIONER
Amana 624-5G-1 ROOM AIR CONDITIONER
Amana 624-5GH ROOM AIR CONDITIONER
Amana 624-5GH-1 ROOM AIR CONDITIONER
Amana 624-5J ROOM AIR CONDITIONER
Amana 624-5JH ROOM AIR CONDITIONER
Amana 6243HL ROOM AIR CONDITIONER
Amana 6243L ROOM AIR CONDITIONER
Amana 6243P ROOM AIR CONDITIONER
Amana 6245J ROOM AIR CONDITIONER
Amana 6245JH ROOM AIR CONDITIONER
Magic Chef 6257XRA RANGE- S/I CONT CLEAN GAS
Magic Chef 6257XRS RANGE- S/I CONT CLEAN GAS
Magic Chef 6257XRW RANGE- S/I CONT CLEAN GAS
Magic Chef 6257XTA RANGE- S/I CONT CLEAN GAS
Magic Chef 6257XTS RANGE- S/I CONT CLEAN GAS
Magic Chef 6257XTW RANGE- S/I CONT CLEAN GAS
  #2 (permalink)
Old 05-15-2017, 07:32 PM
Senior Member
PNWDrew is on a distinguished road
Default
Your model # is incorrect, if I make it make sense this is a pretty straight forward machine, get it off the model/serial tag inside the door. it'll be 110.xxxxxxxx
If it's under 1 year call for service. If you attempt it yourself you may void warranty. I wouldn't usually do that unless the customer screwed something up badly and I felt future safety was an issue but it is the rule.
If I guessed your model right it only has a single element so if it was shorted to ground usually any heat would trip breaker.
  #3 (permalink)
Old 05-19-2017, 08:59 PM
Junior Member
Default
110.61262312, what if it has been over a year? I don't think it has, but in case. the heating element?
  #4 (permalink)
Old 05-20-2017, 06:23 AM
Junior Member
Default
Please Help and thank you ahead of time
  #5 (permalink)
Old 05-20-2017, 06:26 AM
Senior Member
brobriffin is on a distinguished road
Default
Give us the serial number and we can tell you how old it is.
  #6 (permalink)
Old 05-20-2017, 10:36 PM
Senior Member
Default
That's an odd one. Quick question:
If you select a high heat setting does it trip the breaker immediately when you start it?
It's a fairly simple unit. Single element. No difference between high and low heat setting from an electrical standpoint.
How old is your house it electrical panel?
  #7 (permalink)
Old 06-04-2017, 02:33 PM
Junior Member
Default
It will run about 5-10 minutes. If the load is really full with like towels it kicks even in low heat to. I look up my receipt, it's exactly 1 year and 45 days.
  #8 (permalink)
Old 06-04-2017, 02:43 PM
Junior Member
Default
I'm not sure the age of the breaker at all. I've had the house for 12 years and it's a converted old log cabin. the breaker the dryer is on runs very warm. It was a $800 dryer so I can't believe it's gone out already.
  #9 (permalink)
Old 06-04-2017, 02:50 PM
Junior Member
Default
Here are pictures of breaker box, serial and dryer. Please help.
  #10 (permalink)
Old 06-04-2017, 04:17 PM
Senior Member
Default
If your breaker is getting hot it probably needs to be changed just for safety. Heat means resistance and the breaker should have little to no internal resistance. They are easily changed if you are comfortable doing it. Otherwise call an electrician.
Any internal short in the dryer should trip breaker as soon as it tries to power the element.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
new kenmore dryer runs but no heat crazyhouse Dryer Repair 1 11-19-2012 06:46 PM
Kenmore dryer runs but no heat hmays Dryer Repair 1 03-23-2011 06:24 PM
Kenmore runs but won't heat kbarr Dryer Repair 3 09-11-2009 09:26 AM
Kenmore Elite He3 runs but no heat wolfpack Dryer Repair 1 07-27-2009 10:49 AM
Kenmore Gas Dryer - Runs without heat lil2spunki Dryer Repair 0 08-29-2008 06:28 AM
