Discuss
Whirlpool Imperial 70 gas dryer
 in
Dryer Repair
The dryer tumbles, but does not dry. Well, it dries a little, but not much. My wife can, however, feel
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Imperial 70 gas dryer
  #1 (permalink)
Old 05-11-2017, 12:43 PM
Junior Member
Paddycnc is on a distinguished road
Default Whirlpool Imperial 70 gas dryer
Brand: Whirlpool   Age: More than 10 years
The dryer tumbles, but does not dry. Well, it dries a little, but not much. My wife can, however, feel warm air coming from the outlet vent.
  #2 (permalink)
Old 05-15-2017, 07:44 PM
Senior Member
PNWDrew is on a distinguished road
Default
You didn't include a actual model # but I'll give you the general rules of gas dryer diagnosis.
1) If it heats at all your thermal fuse is fine.
2) Verify a strong blast of air from vent to outside.
3) If 1 and 2 are ok it's probably your valve coils, as they fail they begin to allow the valve to close prematurely and you get low temps. Usually this happens progressively as the load runs; the first few times you get a good burn but subsequent burns are shorter and shorter. If it is older than 10 years they are a likely suspect.
Coils are a very easy DIY fix. Another sign of failure is a distinct buzzing during the burn.
This is an older machine, if there a little plastic cover down low on front panel? It pops out to view the burner in action. If not you can open the top and see it light up below. I'd need you model number (inside door probably) to be more specific as to how to do these steps.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Imperial Gas Dryer No Power No Light harleyd87 Dryer Repair 0 01-17-2015 11:45 AM
Whirlpool Dryer Imperial 6cycle jtbusiness Dryer Repair 0 07-11-2013 03:57 PM
Whirlpool Imperial dryer timer clicking Frago Dryer Repair 1 05-14-2008 02:42 PM
Whirlpool Imperial 6 cycle gas dryer ghanyon Dryer Repair 1 12-25-2007 02:15 PM
whirlpool imperial dryer got wet won't run bobh4444 Dryer Repair 1 12-12-2007 03:40 AM
