Discuss
Whirlpool GGW9250PL2 - How do I test control board
 in
Dryer Repair
So the power went out the other night and I turned on my generator for the first time since I
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool GGW9250PL2 - How do I test control board
  #1 (permalink)
Old 05-07-2017, 04:54 PM
Junior Member
lilpig3 is on a distinguished road
Default Whirlpool GGW9250PL2 - How do I test control board
Brand: Whirlpool   Age: 5 - 10 years
So the power went out the other night and I turned on my generator for the first time since I put in a new service panel. Guess what... wired the genny wrong. Sent 220 to parts of the house. Thank God no one was hurt and only 4 light bulbs went out and my dryer. And I had my electrician friend come over and tell me what I needed to do. It's now working correctly.
Now I want to do my best to replace the correct part. I have looked online and found the repair guide yet with my stellar electrical skills I want to make sure I'm doing this correct. Here is a video of my control board with what I think will confirm it's bad.
If one of you could guide me on to to property test out the control board, I would greatly appreciate it.
Lilpig
  #2 (permalink)
Old 05-07-2017, 06:35 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Lilpig,
Unplug the dryer and remove the top panel. The machine electronic control board is located one upper right side of the dryer cabinet. Remove the three screws that hold the machine control bracket in place and remove the assembly. As you remove the assembly from its mounting position, rotate the assembly up to access the machine control circuit board and set it on the side panel. The repair video on the bottom would help you too.
Check the control board for any black marks and/or burned spots. If any, the control board would need to be replaced.
Locate the P1 (five pins) plug on the control board. Remove this plug and make sure no wires are touching each other and/or any metal parts. Reconnect the power to the dryer and check for 120 VAC between the wires connected to the pins P1-2 and P1-5.
If the reading is correct, the control board would need to be replaced.
The machine electronic control board Part number: AP6013143
Here are the break down diagrams for Whirlpool dryer Model GGW9250PL2
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 05-08-2017, 02:08 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Just a little more confirmation. I can see the transformer is blown from the video.
Unless you have a new transformer you can solder on to the board, you will need to replace the board. The transformer is only 120 volts and you fed it 240 volts. Other parts on the board maybe damaged as well.
Its new board time.
  #4 (permalink)
Old 05-08-2017, 08:34 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Thank you ThatGuy. I've missed the video, shame on me
__________________
  #5 (permalink)
Old 10-14-2017, 06:22 PM
Junior Member
tungdoan is on a distinguished road
Default
Hello, my dryer has no power and I check for voltage between the P1-2 and P1-5 but it show zero (0) voyage. Does this mean the control board is bad and need to be replaced?
  #6 (permalink)
Old 10-14-2017, 08:37 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The complete model number of the dryer might help us to better help you.
__________________
  #7 (permalink)
Old 10-14-2017, 08:58 PM
Junior Member
Default
Thank you for your help. The model number of my dryer is YGEW9200LW0
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool French Door how to test control board blair683 Refrigerator & Freezer Repair 20 09-22-2016 09:38 AM
How do you test a defrost control board rhodeo513 Refrigerator & Freezer Repair 0 02-01-2015 05:12 PM
refrigerator control board test howjack Refrigerator & Freezer Repair 8 02-23-2012 12:10 PM
How to test voltage into control board? ekraterf Dishwasher Repair 1 08-07-2010 02:42 PM
How do you test the control board emegee Oven Repair (including Ranges and Cooktops) 1 10-21-2009 09:08 AM
