Discuss
Maytag gas dryer console
 in
Dryer Repair
I recently bought a Maytag gas dryer sight unseen that will not turn on. It displays 8.8 and nothing works
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag gas dryer console
  #1 (permalink)
Old 05-05-2017, 05:32 AM
Senior Member
thorning is on a distinguished road
Default Maytag gas dryer console
Model Number: MDG5500   Brand: Maytag   Age: More than 10 years
I recently bought a Maytag gas dryer sight unseen that will not turn on. It displays 8.8 and nothing works . I could not find any obvious problem so decided to take the dryer apart and look for a problem. The console was dismantled and the PCB opened to observe it. The upper RH corner of the PCB has 4 resistors R53,54,55,56 that are burnt as is the panel under them. Can these be replaced easily, what are the values of these resistors , and what function do they control on the dryer. Any help would be appreciated.
Related Models
Maytag MDG5500AWQ DRYER- GAS
Maytag MDG5500AWW DRYER- GAS
Maytag MDG5806AWK DRYER- GAS
Maytag MDG5806AWW DRYER- GAS
Maytag MDG5960BWW DRYER- GAS
Maytag MDG6000AWQ DRYER- GAS
Maytag MDG6000AWW DRYER- GAS
Maytag MDG6000AXW DRYER- GAS
Maytag MDG6000BWQ DRYER- GAS
Maytag MDG6000BWW DRYER- GAS
Maytag MDG6200AWQ DRYER- GAS
Maytag MDG6200AWW DRYER- GAS
Maytag MDG6400AWQ DRYER- GAS
Maytag MDG6400AWW DRYER- GAS
Maytag MDG6460AWW DRYER- GAS
Maytag MDG6657BWQ DRYER- GAS
Maytag MDG6657BWW DRYER- GAS
Maytag MDG6700AWM DRYER- GAS
Maytag MDG6700AWW DRYER- GAS
Maytag MDG6800AWQ DRYER- GAS
Maytag MDG6800AWW DRYER- GAS
Maytag MDG7057AWQ DRYER- GAS
Maytag MDG7057AWW DRYER- GAS
Maytag MDG7057BWQ DRYER- GAS
Maytag MDG7057BWW DRYER- GAS
Maytag MDG7400AWQ DRYER- GAS
Maytag MDG7400AWW DRYER- GAS
Maytag MDG7460AWQ DRYER- GAS
Maytag MDG7460AWW DRYER- GAS
Maytag MDG7500AWQ DRYER- GAS
Maytag MDG7500AWW DRYER- GAS
Maytag MDG75MNAWW MANUAL, PARTS (DRYER GAS)
Maytag MDG75MNVWQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75MNVWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PN1AW MANUAL, PARTS (DRYER GAS)
Maytag MDG75PN2VW MANUAL, PARTS (DRYER GAS)
Maytag MDG75PNAVW MANUAL, PARTS (DRYER GAS)
Maytag MDG75PNHWQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNHWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVVQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVVW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVWQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG7600AWQ DRYER- GAS
Maytag MDG7600AWW DRYER- GAS
Maytag MDG7657AWQ DRYER- GAS
Maytag MDG7657AWW DRYER- GAS
Maytag MDG7657BWQ DRYER- GAS
Maytag MDG7657BWW DRYER- GAS
Maytag MDG7658AWQ DRYER- GAS
Maytag MDG7658AWW DRYER- GAS
Maytag MDG7658BWQ DRYER- GAS
Maytag MDG7658BWW DRYER- GAS
Maytag MDG76PCBWS MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG76PCBWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG7757AWQ DRYER- GAS
Maytag MDG7757AWW DRYER- GAS
Maytag MDG7758AWQ DRYER- GAS
Maytag MDG7758AWW DRYER- GAS
Maytag MDG77PNAWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG77PNSWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG8000AWQ DRYER- GAS
Maytag MDG8000AWW DRYER- GAS
Maytag MDG8000BWQ DRYER- GAS
Maytag MDG8000BWW DRYER- GAS
Maytag MDG8057AWQ DRYER- GAS
Maytag MDG8057AWW DRYER- GAS
Maytag MDG8057BWQ DRYER- GAS
Maytag MDG8057BWW DRYER- GAS
Maytag MDG8058BWQ DRYER- GAS
Maytag MDG8058BWW DRYER- GAS
Maytag MDG8400AWQ DRYER- GAS
Maytag MDG8400AWW DRYER- GAS
Maytag MDG8416AWA DRYER- GAS
Maytag MDG8416AWW DRYER- GAS
Admiral MDG8426AAW DRYER- GAS
Admiral MDG8426AEW DRYER- GAS
Admiral MDG8426AGW DRYER- GAS
Maytag MDG8500BWW DRYER- GAS
Maytag MDG8506AWA DRYER- GAS
Maytag MDG8506AWW DRYER- GAS
Admiral MDG8550AGW DRYER- GAS
Admiral MDG8550BGW DRYER- GAS
Maytag MDG8600AWQ DRYER- GAS
Maytag MDG8600AWW DRYER
Maytag MDG8757AWQ DRYER- GAS
Maytag MDG8757AWW DRYER- GAS
Maytag MDG9206AWA DRYER- GAS
Maytag MDG9206AWW DRYER- GAS
Maytag MDG9206AXW DRYER- GAS
Maytag MDG9206BWW DRYER- GAS
Maytag MDG9306AWA DRYER- GAS
Maytag MDG9306AWW DRYER- GAS
Maytag MDG9306AXA DRYER- GAS
Maytag MDG9306AXW DRYER- GAS
Maytag MDG9316AWA DRYER- GAS
Maytag MDG9316AWQ DRYER- GAS
Maytag MDG9316AWW DRYER- GAS
Maytag MDG9316AXW DRYER- GAS
Maytag MDG9316BWQ DRYER- GAS
Maytag MDG9316BWW DRYER- GAS
Maytag MDG9357AWA DRYER- GAS
Maytag MDG9357AWW DRYER- GAS
Maytag MDG9360BWW DRYER- GAS
Maytag MDG9390AWW DRYER- GAS
Maytag MDG9390AXW DRYER- GAS
Maytag MDG9390BWW DRYER- GAS
Maytag MDG9420BWW DRYER- GAS
Maytag MDG9520BWQ DRYER- GAS
Maytag MDG9520BWW DRYER- GAS
Maytag MDG9557AWA DRYER- GAS
Maytag MDG9557AWQ DRYER- GAS
Maytag MDG9557AWW DRYER- GAS
Maytag MDG9557AXQ DRYER- GAS
Maytag MDG9557AXW DRYER- GAS
Maytag MDG9557BWQ DRYER- GAS
Maytag MDG9557BWW DRYER- GAS
Maytag MDG9606AWA DRYER- GAS
Maytag MDG9606AWQ DRYER- GAS
Maytag MDG9606AWW DRYER- GAS
  #2 (permalink)
Old 05-05-2017, 09:31 PM
Senior Member
PNWDrew is on a distinguished road
Default
Resistor values are coded by the colors of the bands on them, if those colors are burnt away you'll need to find a pic of the board to reference. If they are burnt it is likely that the traces they attach to are also damaged so you may need to wire around the damage. If you are a skilled elec tech you can do this but soldering very small components is not fun. In the old days we would replace them but I haven't done it in years.
Resistors do not control a function per say they are there for reasons of controlling and modifying the flow of electricity in a circuit. Actual control is handled by a logic chip or other cpu.
You may be able to find a used PCB on ******** or other source that saves you the work. Or maybe you like a challenge? Edit: forum won't let me mention e bay , although this site shows it unavailable
If you are set on trying to repair this here is a resistor color code chart to help ID them:
http://www.resistorguide.com/resistor-color-code/
Once you know what you need you can buy them easily through any number of sources.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag MAH7500 AWQ Console buttons stuck bobbyg57 Washer Repair 1 10-01-2015 05:08 PM
How to remove the console panel on Calypso dryer karendd Dryer Repair 0 04-16-2012 05:59 AM
console lights up by itself glebri Dryer Repair 0 09-19-2011 10:16 AM
How To Remove Kenmore Elite Dryer Console??? jonzo Dryer Repair 5 10-04-2010 06:11 AM
control console pete washo Dishwasher Repair 0 01-21-2008 02:21 PM
