Discuss
Dryer taking too long to dry
 in
Dryer Repair
Original owner of Kenmore 90 series; is taking way too long to dry even on high heat. I have replaced
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer taking too long to dry
  #1 (permalink)
Old 05-04-2017, 08:28 AM
Junior Member
Safetyguy is on a distinguished road
Default Dryer taking too long to dry
Model Number: 110.76912690   Brand: Kenmore   Age: More than 10 years
Original owner of Kenmore 90 series; is taking way too long to dry even on high heat. I have replaced the fixed thermostat (3387134), the thermal fuse (3390710), and both valve coils (279834). Also replaced drum seals a few years ago. The flame comes on and stays on and looks OK. Vent is solid line and very short, only about 3 feet and totally clear of lint. Blower push air through vent fine. Just not hot enough and takes 2 times longer to dry with half loads only. What would the next step be? Thanks!
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 05-04-2017, 07:13 PM
Senior Member
PNWDrew is on a distinguished road
Default
This is a very simple device. It only needs airflow and heat to dry, without having a temp probe in there you can't judge the heat. You can get a probe for many multimeters for $10. What temp is it shutting the burner down at? I just put the probe in the drum from experience but to be more accurate it should be in exhaust. I'll assume that you are correctly judging adequate airflow from here on so I'll focus on heat as your issue.
Your thermal fuse would either be open and not powering the burner or closed and powering it. It has no temp control function. You can ignore it if you get any ignitor or burner action.
There's not many options, only 2 thermostats operate this machine.
I've seen the "spoon" AKA flame spreader allow a jet of flame to escape and hit on or near the hi limit thermostat mounted on the burner cone, this shuts the burner off prematurely. You can see the burn marks on the inside of the cone near the thermostat if this is happening. You can carefully remove the spoon/air shutter assembly and bend the spoon up a little and often solve that issue. It's not elegant but it works. Since you have a lower panel you can run it with the lights off and see the flame spread, if a jet is hitting the hi-limit therm that is probably your issue.
The operating thermostat on the exhaust duct next to blower is the primary means of temp control. If it does not shut the burner off and airflow is good the thermal fuse will shut the burner down permanently at about 195F, or the hi-limit will open and kill the burner, however the hi-limit resets.
You need to determine what thermostat is actually opening to stop it from heating if temps are low. This means live testing with a multimeter. Are you ok with that?
  #3 (permalink)
Old 05-07-2017, 05:48 AM
Junior Member
Default
Thanks for the insight PNWDrew.
I used an Infrared Thermometer to check the temps. With the drum spinning and the dryer on High I got a reading of 158 degrees at the heat inlet to the drum and 122 degrees at the exhaust vent with good airflow out. That being said I'm not too sure where to go from here. Don't really want to buy a new dryer just yet!
  #4 (permalink)
Old 05-07-2017, 06:36 AM
Senior Member
Default
That's low temps. On that dryer you should easily exceed 200 during burn. I use a wire probe in the drum and get temps peaking at 250 sometimes.
Watch it burn in the dark and see if it is allowing flame to hit or even get close to the high limit thermostat right above the burner. Or jump past the high limit and see if it helps.
I assume you've found the wiring diagram, worst case you end up tracking the power back to whatever is turning the burner off prematurely. There's only a few parts that would reset and allow it to begin ignition again.
I know it's a dead horse but just to be 100% on airflow pull the vent off the back and let it vent into free air. Open a few windows and see if temps at exhaust change.
  #5 (permalink)
Old 05-07-2017, 11:49 AM
Junior Member
Default
I tried a digital thermometer with probe in the drum...it stops reading at about 157-159. I used duct tape on the safety switch and watch the fame at the same time. Good flame, hitting the spoon you mentioned, not near the high limit thermostat above it. Used the infrared again and it got to 161 and the flame shut off. It came on again in a few minutes but shuts off at 161 degrees. Does this mean that thermostat is bad? thanks again!
  #6 (permalink)
Old 05-07-2017, 11:52 AM
Junior Member
Default
Also my wiring diagram shows it as part# 3403140 Thermostat High-Limit
205 degrees. Do you hink that is the culprit?
  #7 (permalink)
Old 05-07-2017, 01:30 PM
Senior Member
Default
If you've jumped the hi limit and it still shut off at low temps all that's left is the operating thermo and you've changed it. I wouldn't expect the timer to be so consistent so I think that can be ruled out.
At this point I'd have to start looking for which component is opening. Each thermostat should have 120v to groundbon both sides if closed. If you don't mind working on live devices I would do it by checking for potential across the thermostat. When a thermostat is closed and allowing voltage to pass there should be 0 potential between the two terminals. when it opens that should go to line voltage of about 120 volts. So there's a potential difference between the two due to the open circuit inside the thermostat.
That's all well and good for me to say because I have become comfortable working on these things live but there is of course significant risk doing that when there is a spinning drum inches from your hand and lots of live terminals.
If you want to throw another 10 to $15 at it you could try changing the high-limit and see if that restores higher temperatures but you can also test for that as I just described and access to that one at least it is pretty easy. The operating thermostat located on the blower housing is less accessible.
That level of risk is up to you if you want to proceed with testing on alive dryer. I was very nervous for many months while I learned to work on live machines and 20 years later I still avoid doing it unless I absolutely have to.
I'm on a surprise all day road trip right now so I don't have easy access to look at a wiring diagram on a bigger screen but as far as I know the only thing that controls your temperature is the operating thermostat and the high limit thermostat. I should be back home tomorrow evening so I'll look again then.
  #8 (permalink)
Old 05-07-2017, 02:45 PM
Junior Member
Default
Thanks! I think I'll just get a new high limit thermostat and try that for now.
  #9 (permalink)
Old 05-15-2017, 05:39 AM
Junior Member
I replaced the high-limit thermostat yesterday with Genuine Whirlpool Part:
WPW10423382. Was fairly hard to reach with big forearms, but got it mounted and did a load of laundry. The dryer worked just as it used to for years. Clothes dried in 50-60 minutes on Normal/Permanent Press (Med/High).
Thank you for your assistance. Much appreciative!
  #10 (permalink)
Old 05-15-2017, 06:58 PM
Senior Member
Default
That's good. Sorry I spaced on coming back to this.
For background info: It will tend to cycle on the high limit early in the run, since the op thermostat is in the exhaust and only seeing air that is cooled by the moisture in the load. As the load heats up the op thermostat will begin to see those temps and take over. If the hi-limit is opening early then it takes longer to reach operating temps in the exhaust and you get what you describe. That said thermostats in general on Whirlpools are not prone to failure often so this was a little odd, forced me think; which is good.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer taking too long to dry Rockets33 Dryer Repair 1 01-25-2011 01:00 PM
Dryer taking too long to dry nahahn Dryer Repair 1 05-02-2010 11:09 AM
Dryer taking long to dry delstvn Dryer Repair 1 08-28-2009 05:31 PM
Dryer taking too long to dry Christine Sullivan Dryer Repair 2 10-12-2008 06:03 PM
dryer taking to long to dry pjjj5859 Dryer Repair 1 09-28-2007 01:54 AM
