Discuss
Whirlpool Gas Dryer heating intermittently, timer not working
 in
Dryer Repair
I have a Whirlpool gas dryer (model LGR6611LQ0) that's having a few issues. I've fixed things on it a few
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Gas Dryer heating intermittently, timer not working
  #1 (permalink)
Old 05-02-2017, 11:50 AM
Junior Member
christyhecht is on a distinguished road
Default Whirlpool Gas Dryer heating intermittently, timer not working
Model Number: LGR6611LQ0   Brand: Whirlpool   Age: More than 10 years
I have a Whirlpool gas dryer (model LGR6611LQ0) that's having a few issues. I've fixed things on it a few times before, and am trying to figure out if I can do it again, or if at this point I should just let it die, because the problems are racking up.
A few problems:
1. The dryer developed 2 new problems at the same time, just a few days ago. I normally use it on one of the auto-dry settings. Suddenly, when I use one of those settings, the timer no longer advances, so the dryer will just run continuously until I stop it. At the same time, the heat stopped working correctly. If I turn it on high heat, it'll heat up a little in the beginning of the cycle, but as far as I can tell, doesn't come on again after that, even when you run it for 6 hours like I accidentally did. My temporary fix has been to turn it to a timed setting. When set for a specific time, the timer does advance, and the dryer shuts off after the time alotted, but the heating issues still occur; heat only runs at the beginning of the cycle.
2. The door switch has been broken for about a month. If we open the door while the dryer is on, it keeps spinning. I've found the part for this, and it looks like an easy repair, but it's another tick on the check list of this dryer moving toward death.
3. About a month ago, we were hearing intermittant thumping noises from the dryer, like it had shoes inside. But it didn't; it was just regular clothes. This has since gone away, weirdly enough.
Any help or advice you can give would be very appreciated! Thank you!
Related Models
Whirlpool LGR6611LQ0 RESIDENTIAL DRYER
Whirlpool LGR6611LQ1 29"GAS DRYER
Whirlpool LGR6611PQ0 29" GAS DRYER
Whirlpool LGR6620PQ0 29"GAS DRYER
Whirlpool LGR6620PQ1 29"GAS DRYER
Whirlpool LGR6620PT0 29"GAS DRYER
Whirlpool LGR6620PT1 29"GAS DRYER
Whirlpool LGR6621PQ0 29" GAS DRYER
Whirlpool LGR6634BN0 GAS DRYER
Whirlpool LGR6634BN1 GAS DRYER
Whirlpool LGR6634BN2 GAS DRYER
Whirlpool LGR6634BQ0 GAS DRYER
Whirlpool LGR6634BQ1 GAS DRYER
Whirlpool LGR6634BQ2 GAS DRYER
Whirlpool LGR6634BW0 GAS DRYER
Whirlpool LGR6634BW1 GAS DRYER
Whirlpool LGR6634BW2 GAS DRYER
Whirlpool LGR6634DQ0 GAS DRYER
Whirlpool LGR6634DQ1 GAS DRYER
Whirlpool LGR6634DW0 GAS DRYER
Whirlpool LGR6634DW1 GAS DRYER
Whirlpool LGR6634DZ0 GAS DRYER
Whirlpool LGR6634DZ1 GAS DRYER
Whirlpool LGR6636PW0 29" GAS DRYER
Whirlpool LGR6636PW1 29" GAS DRYER
Whirlpool LGR6638DQ0 GAS DRYER
Whirlpool LGR6638DQ1 GAS DRYER
Whirlpool LGR6638DW0 GAS DRYER
Whirlpool LGR6638DW1 GAS DRYER
Whirlpool LGR6638DZ0 GAS DRYER
Whirlpool LGR6638DZ1 GAS DRYER
Whirlpool LGR6644DQ0 GAS DRYER
Whirlpool LGR6644DQ1 GAS DRYER
Whirlpool LGR6644DZ0 GAS DRYER
Whirlpool LGR6644DZ1 GAS DRYER
Whirlpool LGR6646BN0 GAS DRYER
Whirlpool LGR6646BN1 GAS DRYER
Whirlpool LGR6646BN2 GAS DRYER
Whirlpool LGR6646BW0 GAS DRYER
Whirlpool LGR6646BW1 GAS DRYER
Whirlpool LGR6646BW2 GAS DRYER
Whirlpool LGR6646DN1 GAS DRYER
Whirlpool LGR6646DW1 GAS DRYER
Whirlpool LGR6646PW0 29" GAS DRYER
Whirlpool LGR6646PW1 29" GAS DRYER
Whirlpool LGR6848AN1 GAS DRYER
Whirlpool LGR6848AN2 GAS DRYER
Whirlpool LGR6848AQ2 GAS DRYER
Whirlpool LGR6848AW0 Residential Dryer
Whirlpool LGR6848AW1 GAS DRYER
Whirlpool LGR6848AW2 GAS DRYER
Whirlpool LGR6848AZ2 GAS DRYER
Whirlpool LGR7620KQ0 RESIDENTIAL DRYER
Whirlpool LGR7620KQ1 RESIDENTIAL DRYER
Whirlpool LGR7620KT0 RESIDENTIAL DRYER
Whirlpool LGR7620KT1 RESIDENTIAL DRYER
Whirlpool LGR7620LG0 RESIDENTIAL DRYER
Whirlpool LGR7620LG1 29"GAS DRYER
Whirlpool LGR7620LQ0 RESIDENTIAL DRYER
Whirlpool LGR7620LW0 RESIDENTIAL DRYER
Whirlpool LGR7620LW1 29"GAS DRYER
Whirlpool LGR7645JQ0 GAS DRYER
Whirlpool LGR7645JQ1 GAS DRYER
Whirlpool LGR7645JQ2 DRYER
Whirlpool LGR7646AN0 GAS DRYER
Whirlpool LGR7646AN1 GAS DRYER
Whirlpool LGR7646AN2 GAS DRYER
Whirlpool LGR7646AQ0 GAS DRYER
Whirlpool LGR7646AQ1 GAS DRYER
Whirlpool LGR7646AQ2 GAS DRYER
Whirlpool LGR7646AW0 Residential Dryer
Whirlpool LGR7646AW1 GAS DRYER
Whirlpool LGR7646AW2 GAS DRYER
Whirlpool LGR7646AZ0 GAS DRYER
Whirlpool LGR7646AZ1 GAS DRYER
Whirlpool LGR7646AZ2 GAS DRYER
Whirlpool LGR7646DQ0 GAS DRYER
Whirlpool LGR7646DQ1 GAS DRYER
Whirlpool LGR7646DW0 GAS DRYER
Whirlpool LGR7646DW1 GAS DRYER
Whirlpool LGR7646DZ0 GAS DRYER
Whirlpool LGR7646DZ1 GAS DRYER
Whirlpool LGR7646EQ0 DRYER
Whirlpool LGR7646EQ1 DRYERS
Whirlpool LGR7646EQ2 GAS DRYER
Whirlpool LGR7646EQ3 GAS DRYER
Whirlpool LGR7646EZ0 DRYER
Whirlpool LGR7646EZ1 DRYERS
Whirlpool LGR7646EZ2 GAS DRYER
Whirlpool LGR7646EZ3 GAS DRYER
Whirlpool LGR7646JQ0 GAS DRYER
Whirlpool LGR7646JQ1 RESIDENTIAL DRYER
Whirlpool LGR7646JT0 GAS DRYER
Whirlpool LGR7646JT1 RESIDENTIAL DRYER
Whirlpool LGR7648KQ0 RESIDENTIAL DRYER
Whirlpool LGR7648KQ1 RESIDENTIAL DRYER
Whirlpool LGR7648KQ2 29"GAS DRYER
Whirlpool LGR7648KT0 RESIDENTIAL DRYER
Whirlpool LGR7648KT1 RESIDENTIAL DRYER
Whirlpool LGR7648KT2 29"GAS DRYER
Whirlpool LGR7648PQ0 29" GAS DRYER
Whirlpool LGR7648PQ1 29" GAS DRYER
Whirlpool LGR7648PT0 29" GAS DRYER
Whirlpool LGR7648PT1 29" GAS DRYER
Whirlpool LGR7848DQ0 GAS DRYER
Whirlpool LGR7848DQ1 GAS DRYER
Whirlpool LGR7848DZ0 GAS DRYER
Whirlpool LGR7848DZ1 GAS DRYER
Whirlpool LGR7858AN1 GAS DRYER
Whirlpool LGR7858AN2 GAS DRYER
Whirlpool LGR7858AW0 Residential Dryer
Whirlpool LGR7858AW1 GAS DRYER
Whirlpool LGR7858AW2 GAS DRYER
Whirlpool LGR8620PG0 29"GAS DRYER
Whirlpool LGR8620PG1 29"GAS DRYER
Whirlpool LGR8620PW0 29"GAS DRYER
Whirlpool LGR8620PW1 29"GAS DRYER
Whirlpool LGR8646LG0 RESIDENTIAL DRYER
Whirlpool LGR8648LG1 29"GAS DRYER
Whirlpool LGR8648LQ0 RESIDENTIAL DRYER
  #2 (permalink)
Old 05-02-2017, 12:57 PM
Junior Member
Default
Update: I have taken the dryer apart to try to test the gas coils, as that seemed a likely cuplrit. I pulled them out and tested their continuity, and both seem acceptable. Using a digital multimeter set to 2k ohms, the 2 terminal coil is measuing 1302. The 3 terminal coil is measuring 1390 on the middle prong (but this number jumps allllll over the place while I try to get a reading) and 580 on the right prong. This seems to be within acceptable tolerances, right? So I'm moving on to something else, I suppose.
  #3 (permalink)
Old 05-02-2017, 02:09 PM
Junior Member
Default
Thermal fuse has continuity
  #4 (permalink)
Old 05-02-2017, 03:48 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
The coils get warm and their winding separates, so the dryer heats once then cools off. You would need to test the coil's continuity after it heats and quits.
Replace the coils and door switch and you should be up and running again.
Whirlpool 279834 Dryer Gas Valve Coil Kit - AppliancePartsPros.com
Whirlpool WP3406107 Dryer Door Switch Assembly - AppliancePartsPros.com
  #5 (permalink)
Old 05-03-2017, 07:58 AM
Junior Member
Default
Oh, so a test for a coil can be totally incorrect if it hasn't been used recently (which it hadn't)? Well, that's good to know. Are you pretty confident it's not the timer or something else?
  #6 (permalink)
Old 05-03-2017, 12:07 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
If it heats up once and doesn't heat again until it cools completely off, its usually one of the coils. (replace as a set).
I've replaced so many over the years that I lost count long ago. It is one of the most common failures on gas dryers. I always kept several sets of the coils in stock. Next to belts and rollers and sometimes a thermal fuse, they are the most replaced parts.
  #7 (permalink)
Old 05-03-2017, 12:18 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
The thumping noise could have been the drum rollers. They are like little rubber car tires and if the dryer is stopped while hot, they can get flat spots. They will thump right along until they warm back up and smooth out.
Usually this doesn't happen, the dryer goes through cool down before turning off.
  #8 (permalink)
Old 05-04-2017, 06:52 AM
Senior Member
thorning is on a distinguished road
Default
In my experience you have described several problems with this dryer. The door switch problem is a fairly common item and easily and usually low priced to fix. Sometimes I squirt a small amount of WD40 in the plunger type and it frees it up. On the lever type you need to replace the switch.
The rollers can take a set and/or develop a flat spot but the bearing and shaft may be beyond repair. This is unusual however and I find the roller surface may be worn badly. Quite often I take the rollers out and switch the left for the right and vice versa after the shafts have been cleaned and lubed. Sometimes it is adequate. Dont neglect the drum support slippers. They support the opposite end of the drum. These are usually replaceable but some are not. If there is a problem with the timer your dryer is too expensive to repair. Gas valve coils are easy to replace and not very expensive. For some reason both do not fail together . When you have the drum out you should check the condition of the belt and the idler roller also.
  #9 (permalink)
Old 05-08-2017, 10:33 PM
Junior Member
Default
I just wanted to thank you both for your help. I replaced the gas coils and the door switch, and voila, I'm back in business! So very excited! Thank you again.
  #10 (permalink)
Old 05-09-2017, 04:36 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
You're welcome.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool dryer not heating nor timer advancing bladrnr Dryer Repair 1 12-26-2013 03:04 PM
Whirlpool dryer not heating timer not advancing mbell418 Dryer Repair 1 07-13-2011 01:41 PM
dryer is not heating and timer is not working Angelsptouch Dryer Repair 0 06-29-2011 08:28 AM
whirlpool dryer heating up, but the timer setting not moving jimmymac2003 Dryer Repair 1 09-25-2009 06:27 AM
Gas dryer intermittently not heating Tristan Dryer Repair 5 06-17-2008 12:59 PM
