Discuss
On startup Frigidaire Affinity Dryer Whirs, clunks, and then is fine
 in
Dryer Repair
My Frigidaire Affinity Dryer, FASE7370LW0, on startup, began to make what I believed to be a belt slipping sound. It
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » On startup Frigidaire Affinity Dryer Whirs, clunks, and then is fine
  #1 (permalink)
Old 04-24-2017, 07:15 PM
Junior Member
RPD15 is on a distinguished road
Default On startup Frigidaire Affinity Dryer Whirs, clunks, and then is fine
Brand: Frigidaire   Age: 1 - 5 years
My Frigidaire Affinity Dryer, FASE7370LW0, on startup, began to make what I believed to be a belt slipping sound. It would "Whir" for about 2 seconds, as if the belt was slipping, and then "catch" and work normally.
I changed out the belt, idler pulley and idler spring.
Now I get Whir/clunk and then the dryer works normally.
It only lasts seconds before it begins to function normally.
I rotated the drum manually and it sounds fine. Of course the torque that I can manually apply is nowhere near what the motor does.
Any ideas?
  #2 (permalink)
Old 04-25-2017, 07:39 PM
Junior Member
Default
Well, in listening more closely, it sounds like a drum roller.
I never would have guessed that.
I ordered one and when it comes in, I'll update this to let you all know if that was the problem.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
frigidaire affinity gas dryer tpoxpress Dryer Repair 2 10-25-2013 04:34 PM
frigidaire affinity dryer weezy62 Dryer Repair 0 12-11-2012 11:09 AM
Frigidaire Affinity Gas dryer Suresh Sikka Dryer Repair 0 03-10-2012 08:13 AM
frigidaire affinity dryer dbrown1@ctc.net Dryer Repair 2 12-26-2011 02:13 PM
frigidaire affinity washer barrel will not spin out, drains fine prissy1000 Washer Repair 1 03-06-2011 04:26 AM
