Discuss
Dryer Overheating When Not Running
 in
Dryer Repair
My dryer flipped the circuit breaker in the garage a few days ago. I flipped the circuit breaker back on
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Overheating When Not Running
  #1 (permalink)
Old 04-05-2017, 09:06 AM
Junior Member
Chris McCain is on a distinguished road
Default Dryer Overheating When Not Running
Model Number: LER4434AQO   Brand: Whirlpool   Age: More than 10 years
My dryer flipped the circuit breaker in the garage a few days ago. I flipped the circuit breaker back on and plugged the dryer back into the wall outlet. I pushed the start button on the dryer and this flipped the master breaker to the entire house. I checked the dryer and found that the two wires coming off of the heating element had fused together. I replaced these wires and found that the dryer was getting very hot when it was not even running. I have since replaced the heating element, cycling thermostat, thermal fuse, hi limit thermostat & thermal cut off. I had already ordered these parts before I purchased a multimeter. I tested all of the old parts for continuity and couldn't find any issues. There are no venting issues as everything has been recently checked and cleaned.
The top & sides of the dryer still get very hot when it is plugged in and not turned on. I carefully monitored a load of clothes on the delicate & the high heat settings and the clothes dried fine. The outside of the dryer is not hot when the dryer is running. This only happens when you plug it in. Something is causing the heating element to heat up right after the unit is plugged in. Could something inside of the timer be bad?
Related Models
Whirlpool LER4434AW0 Residential Dryer
Whirlpool LER4434AW1 ELECTRIC DRYER
Whirlpool LER4436AW0 Residential Dryer
Whirlpool LER4600PQ0 29" ELECTRIC DRYER
Whirlpool LER4600PQ1 29" ELECTRIC DRYER
Whirlpool LER4624BN0 ELECTRIC DRYER
Whirlpool LER4624BN1 ELECTRIC DRYER
Whirlpool LER4624BN2 ELECTRIC DRYER
Whirlpool LER4624BQ0 ELECTRIC DRYER
Whirlpool LER4624BQ1 ELECTRIC DRYER
Whirlpool LER4624BQ2 ELECTRIC DRYER
Whirlpool LER4624BW0 ELECTRIC DRYER
Whirlpool LER4624BW1 ELECTRIC DRYER
Whirlpool LER4624BW2 ELECTRIC DRYER
Whirlpool LER4624DQ0 ELECTRIC DRYER
Whirlpool LER4624DQ1 ELECTRIC DRYER
Whirlpool LER4624DZ0 ELECTRIC DRYER
Whirlpool LER4624DZ1 ELECTRIC DRYER
Whirlpool LER4634BQ0 ELECTRIC DRYER
Whirlpool LER4634BQ1 ELECTRIC DRYER
Whirlpool LER4634BQ2 ELECTRIC DRYER
Whirlpool LER4634DQ0 DRYERS
Whirlpool LER4634DQ1 ELECTRIC DRYER
Whirlpool LER4634DZ0 DRYERS
Whirlpool LER4634DZ1 ELECTRIC DRYER
Whirlpool LER4634EQ0 ELECTRIC DRYER
Whirlpool LER4634EQ1 DRYERS
Whirlpool LER4634EQ2 ELECTRIC DRYER
Whirlpool LER4634EW0 ELECTRIC DRYER
Whirlpool LER4634EZ0 ELECTRIC DRYER
Whirlpool LER4634EZ1 DRYERS
Whirlpool LER4634EZ2 ELECTRIC DRYER
Whirlpool LER4634JQ0 ELECTRIC DRYER
Whirlpool LER4634JQ1 RESIDENTIAL DRYER
Whirlpool LER4634JQ2 29" ELECTRIC DRYER
Whirlpool LER4634JT0 ELECTRIC DRYER
Whirlpool LER4634JT1 RESIDENTIAL DRYER
Whirlpool LER4634JT2 29" ELECTRIC DRYER
Whirlpool LER4634JZ0 ELECTRIC DRYER
Whirlpool LER4634PQ0 29" ELECTRIC DRYER
Whirlpool LER4634PQ1 29" ELECTRIC DRYER
Whirlpool LER4634PT0 29" ELECTRIC DRYER
Whirlpool LER4634PT1 29" ELECTRIC DRYER
Whirlpool LER5434AW0 Residential Dryer
Whirlpool LER5600HQ0 ELECTRIC DRYER
Whirlpool LER5600HZ0 ELECTRIC DRYER
Whirlpool LER5600JQ0 ELECTRIC DRYER
Whirlpool LER5600JT0 ELECTRIC DRYER
Whirlpool LER5620KQ0 RESIDENTIAL DRYER
Whirlpool LER5620KQ1 ELECTRIC DRYER
Whirlpool LER5620KQ2 29"ELECTRIC DRYER
Whirlpool LER5624BN0 ELECTRIC DRYER
Whirlpool LER5624BN1 ELECTRIC DRYER
Whirlpool LER5624BN2 ELECTRIC DRYER
Whirlpool LER5624BW0 ELECTRIC DRYER
Whirlpool LER5624BW1 ELECTRIC DRYER
Whirlpool LER5624BW2 ELECTRIC DRYER
Whirlpool LER5624DQ0 DRYERS
Whirlpool LER5624DQ1 ELECTRIC DRYER
Whirlpool LER5624DW1 ELECTRIC DRYER
Whirlpool LER5624DZ0 DRYERS
Whirlpool LER5624DZ1 ELECTRIC DRYER
Whirlpool LER5634AN0 ELECTRIC DRYERS
Whirlpool LER5634AQ0 ELECTRIC DRYER
Whirlpool LER5634AQ1 ELECTRIC DRYER
Whirlpool LER5634AQ2 ELECTRIC DRYER
Whirlpool LER5634AW0 ELECTRIC DRYERS
Whirlpool LER5634DQ1 DRYER
Whirlpool LER5634EQ0 ELECTRIC DRYER
Whirlpool LER5634EZ0 ELECTRIC DRYER
Whirlpool LER5634LG0 RESIDENTIAL DRYER
Whirlpool LER5634LQ0 29" ELECTRIC DRYER
Whirlpool LER5634LT0 RESIDENTIAL DRYER
Whirlpool LER5634LW0 RESIDENTIAL DRYER
Whirlpool LER5635LQ0 29"ELECTRIC DRYER
Whirlpool LER5635LQ1 29"ELECTRIC DRYER
Whirlpool LER5636DW0 ELECTRIC DRYER
Whirlpool LER5636DW1 ELECTRIC DRYER
Whirlpool LER5636EQ0 ELECTRIC DRYER
Whirlpool LER5636EQ1 ELECTRIC DRYER
Whirlpool LER5636EQ2 ELECTRIC DRYER
Whirlpool LER5636EQ3 ELECTRIC DRYER
Whirlpool LER5636EZ0 ELECTRIC DRYER
Whirlpool LER5636EZ01 ELECTRIC DRYER
Whirlpool LER5636EZ1 DRYER
Whirlpool LER5636EZ2 ELECTRIC DRYER
Whirlpool LER5636EZ3 ELECTRIC DRYER
Whirlpool LER5636JQ0 ELECTRIC DRYER
Whirlpool LER5636JT0 ELECTRIC DRYER
Whirlpool LER5636KQ0 RESIDENTIAL DRYER
Whirlpool LER5636KQ1 RESIDENTIAL DRYER
Whirlpool LER5636KT0 RESIDENTIAL DRYER
Whirlpool LER5636KT1 RESIDENTIAL DRYER
Whirlpool LER5636LG0
Whirlpool LER5636LQ0
Whirlpool LER5636LQ1 29"ELECTRIC DRYER
Whirlpool LER5636LT0
Whirlpool LER5636LT1 29"ELECTRIC DRYER
Whirlpool LER5636LW0
Whirlpool LER5636PQ0 29"ELECTRIC DRYER
Whirlpool LER5636PQ1 29"ELECTRIC DRYER
Whirlpool LER5636PT0 29"ELECTRIC DRYER
Whirlpool LER5636PT1 29"ELECTRIC DRYER
Whirlpool LER5638AN1 ELECTRIC DRYER
Whirlpool LER5638AN2 ELECTRIC DRYER
Whirlpool LER5638AN3 ELECTRIC DRYER
Whirlpool LER5638AW0 Residential Dryer
Whirlpool LER5638AW1 ELECTRIC DRYER
Whirlpool LER5638AW2 ELECTRIC DRYER
Whirlpool LER5638AW3 ELECTRIC DRYER
Whirlpool LER5644AN1
Whirlpool LER5644AN2 ELECTRIC DRYER
Whirlpool LER5644AW0 Residential Dryer
Whirlpool LER5644AW1
Whirlpool LER5644AW2 ELECTRIC DRYER
Whirlpool LER5644EQ0 ELECTRIC DRYER
Whirlpool LER5644EQ1 ELECTRIC DRYER
Whirlpool LER5644EQ2 ELECTRIC DRYER
Whirlpool LER5644EZ0 ELECTRIC DRYER
Whirlpool LER5644EZ1 ELECTRIC DRYER
  #2 (permalink)
Old 04-06-2017, 11:15 AM
Junior Member
manfred63 is on a distinguished road
Default
The dryer uses 220 volts to make the element heat up. 110 volts comes to the element from the timer, and another 110 volts comes from the motor switch on the motor. You should only get 110 volts when motor is not running. So unless you missed a short in the wiring somewhere, it sounds like the switch on the motor is bad and is sending power to the element when not running. If that is the case, then you will need to replace the motor. It would require some live voltage testing to verify this, and I do not recommend you do any live voltage testing. Very dangerous. Instead, you can unplug the machine, and then unplug the wires from the motor switch, after you have marked them to make sure they go back to correct terminals, and then use the wiring diagram in the control panel to test for continuity based on the hot wire that supplies power when running to the element. You will need to throw the centrifugal switch for it to have continuity, like when it is running. Without the centrifugal switch thrown, it should NOT have continuity to the element. Hope that all makes sense and helps you out!
Ken's Appliance Repair
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer overheating jltuttl Dryer Repair 1 08-30-2013 04:18 PM
Overheating Dryer dsylwester Dryer Repair 1 03-18-2011 06:37 PM
Dryer Overheating dgholmes03 Dryer Repair 3 05-29-2009 06:47 AM
FisherPaykel Dryer Overheating (even hot when not running) DRF Dryer Repair 1 09-09-2008 06:08 PM
Dryer Overheating? RogerB Dryer Repair 18 07-07-2008 12:20 PM
