Discuss
Amana Dryer won't start, but still gets hot
 in
Dryer Repair
I went to dry a load of clothes and when I pushed the start button nothing happened. I noticed that
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Amana Dryer won't start, but still gets hot
  #1 (permalink)
Old 03-15-2017, 10:38 AM
Junior Member
halfmoonranch is on a distinguished road
Default Amana Dryer won't start, but still gets hot
Model Number: HED5240TQ0   Brand: Amana   Age: 5 - 10 years
I noticed that the timer was ticking and was doing so even in the off position, then I noticed the dryer was still getting hot, so I kicked the breaker off to avoid a fire.
When I looked behind the dryer, I noticed that the vent pipe had gotten crushed over time (my fault).
So, I'm guessing the thermal fuse went due to the high heat, resulting in the non-start, but I'm not sure what would cause the dryer to continue to heat even in the off position.
I do have a multi meter, but I wasn't sure what to test or in what order.
Related Models
Amana HET-480 RANGE- S/C S/I DDRAFT GAS
Amana HEU-516 RANGE- S/C S/I DDRAFT GAS
Magic Chef HF309-2 HOOD
Magic Chef HF309-3 HOOD
Magic Chef HF309-4 HOOD
Frigidaire HF30M Frg(v3) / Range Vent Hood
Magic Chef HF30R-1 HOOD
Magic Chef HF30R-1A HOOD
Magic Chef HF369-2 HOOD
Magic Chef HF369-3 HOOD
Magic Chef HF369-4 HOOD
Frigidaire HFA180FM1D Kel(v1) / Chest Freezer
Frigidaire HFA180FM2D Kel(v2) / Chest Freezer
Frigidaire HFP158DM1W Kel(v2) / Chest Freezer
Frigidaire HFP158DMOW Kel(v1) / Chest Freezer
Frigidaire HFS156AM3W Kel(v1) / Chest Freezer
Frigidaire HFS156SM2W Kel(v2) / Chest Freezer
Frigidaire HFS156SM4W Kel(v3) / Chest Freezer
Frigidaire HFS156SM5W Kel(v1) / Chest Freezer
Frigidaire HFS158DM1W Kel(v1) / Chest Freezer
Frigidaire HFS158DMOW Kel(v2) / Chest Freezer
Frigidaire HFS158FM1W Kel(v1) / Chest Freezer
Frigidaire HFS158FM2W Kel(v2) / Chest Freezer
Frigidaire HFS158FM3W Kel(v3) / Chest Freezer
Frigidaire HFS158FM7W Kel(v1) / Chest Freezer
Frigidaire HFS158FM8W Kel(v1) / Chest Freezer
Frigidaire HFS180EM1W Kel(v1) / Freezer
Frigidaire HFS180EM2W Kel(v2) / Freezer
Frigidaire HFS204DM1W Kel(v3) / Chest Freezer
Frigidaire HFS204DMOW Kel(v3) / Chest Freezer
Frigidaire HFS204FM1W Kel(v1) / Chest Freezer
Frigidaire HFS204FM2W Kel(v1) / Chest Freezer
Frigidaire HFS204FM3W Kel(v2) / Chest Freezer
Frigidaire HFS204FM4W Kel(v3) / Chest Freezer
Frigidaire HFS204FM5W Kel(v1) / Chest Freezer
Frigidaire HFS208SM4W Kel(v1) / Chest Freezer
Frigidaire HFS230DM0W Kel(v4) / Chest Freezer
Frigidaire HFS230DM1W Kel(v5) / Chest Freezer
Frigidaire HFS230DMOW Kel(v4) / Chest Freezer
Frigidaire HFS260SM4W Kel(v2) / Chest Freezer
Frigidaire HFS262DM1W Kel(v1) / Freezer
Frigidaire HFS262FM1W Kel(v1) / Chest Freezer
Frigidaire HFS262FM5W Kel(v1) / Chest Freezer
Amana HG2090 DRYER- GAS
Amana HG2260 WASHER-TOP LOADING
Amana HG2490 WASHER-TOP LOADING
Amana HG2980 WASHER-TOP LOADING
Amana HG3009 WASHER-TOP LOADING
Amana HG4009 WASHER-TOP LOADING
Amana HG4080 DRYER- GAS
Amana HG4109 WASHER-TOP LOADING
Amana HG4209 WASHER-TOP LOADING
Amana HG4280 DRYER- GAS
Amana HG4360 WASHER-TOP LOADING
Amana HG4390 DRYER- GAS
Amana HG4490 DRYER- GAS
Amana HG4509 WASHER-TOP LOADING
Amana HG5009 DRYER- GAS
Amana HG5390 WASHER-TOP LOADING
Amana HG6009 DRYER- GAS
Amana HG6360 WASHER-TOP LOADING
Amana HG6380 DRYER- GAS
Amana HG6490 WASHER-TOP LOADING
Amana HG6494 WASHER-TOP LOADING
Amana HG6660 WASHER-TOP LOADING
Amana HG7009 DRYER- GAS
Amana HG7290 WASHER-TOP LOADING
Amana HG9260 WASHER-TOP LOADING
Amana HG9280 WASHER-TOP LOADING
Maytag HGD4300TQ0 29" GAS DRYER
Maytag HGD4400TQ0 29" GAS DRYER
Thermador HGSI42TS
Thermador HGSW36TS
Maytag HJ61201JRT ELECTRIC WATER HEATER
Maytag HJ61202JRT ELECTRIC WATER HEATER
Maytag HJ6301JLS ELECTRIC WATER HEATER
Maytag HJ6301JLSCSA ELECTRIC WATER HEATER
Maytag HJ6301JRT2 ELECTRIC WATER HEATER
Maytag HJ6301JRT2CSA ELECTRIC WATER HEATER
Maytag HJ6302JLS ELECTRIC WATER HEATER
Maytag HJ6302JLSCSA ELECTRIC WATER HEATER
Maytag HJ6302JRT2 ELECTRIC WATER HEATER
Maytag HJ6302JRT2CSA ELECTRIC WATER HEATER
Maytag HJ630NORT GAS WATER HEATER
Maytag HJ630NORT2 GAS WATER HEATER
Maytag HJ630NORT2CGA GAS WATER HEATER
Maytag HJ630NORTCGA GAS WATER HEATER
Maytag HJ630PORT GAS WATER HEATER
Maytag HJ630PORT2 GAS WATER HEATER
Maytag HJ630PORT2CGA GAS WATER HEATER
Maytag HJ630PORTCGA GAS WATER HEATER
Maytag HJ6401JLS ELECTRIC WATER HEATER
Maytag HJ6401JLSCSA ELECTRIC WATER HEATER
Maytag HJ6401JRS ELECTRIC WATER HEATER
Maytag HJ6401JRSCSA ELECTRIC WATER HEATER
Maytag HJ6401JRT2 ELECTRIC WATER HEATER
Maytag HJ6401JRT2CSA ELECTRIC WATER HEATER
Maytag HJ6401JRT2CSAF ELECTRIC WATER HEATER
Maytag HJ6401JRT2F ELECTRIC WATER HEATER
Maytag HJ6401JT4W ELECTRIC WATER HEATER
Maytag HJ6401JT4WCSA GAS WATER HEATER
Maytag HJ6402JLS ELECTRIC WATER HEATER
Maytag HJ6402JLSCSA ELECTRIC WATER HEATER
Maytag HJ6402JRS ELECTRIC WATER HEATER
Maytag HJ6402JRSCSA ELECTRIC WATER HEATER
Maytag HJ6402JRT2 ELECTRIC WATER HEATER
Maytag HJ6402JRT2CSA ELECTRIC WATER HEATER
Maytag HJ6402JRT2CSAF ELECTRIC WATER HEATER
Maytag HJ6402JRT2F ELECTRIC WATER HEATER
Maytag HJ6402JT4W ELECTRIC WATER HEATER
Maytag HJ6402JT4WCSA GAS WATER HEATER
Maytag HJ640NBDS GAS WATER HEATER
Maytag HJ640NBDSCGA GAS WATER HEATER
Maytag HJ640NBDVT GAS WATER HEATER
Maytag HJ640NBDVTCGA GAS WATER HEATER
Maytag HJ640NBPDT GAS WATER HEATER
Maytag HJ640NBPDTCGA GAS WATER HEATER
Maytag HJ640NBRS GAS WATER HEATER
Maytag HJ640NBRSCGA GAS WATER HEATER
Maytag HJ640NBRT GAS WATER HEATER
  #2 (permalink)
Old 03-16-2017, 11:05 AM
Senior Member
thorning is on a distinguished road
Default
The dryer blower motor runs on 110 volt and it will normally not run if the thermal fuse is open. You will need to replace the thermal fuse or temporarily use a jumper wire to see if that is the only problem. The timer is made to run using a small pancake motor using 110 volts and it will keep running. Be careful not to run it very long unless you get the vent tube problem corrected .
  #3 (permalink)
Old 03-16-2017, 05:47 PM
Senior Member
brobriffin is on a distinguished road
Default
halfmoon--- you also may have another problem that your heating element is shorting out against the heater can. The heat should not be on unless the motor is turning the drum and fan. There is a centrifugal switch that closes a set of contacts completing the 240v heating circuit. So if this is true It may also be the cause of the thermal fuse blowing out.
Unplug your machine remove the back cover. Watch Matt in the video associated with this link how to access the heating element.
Whirlpool 279838 Whirlpool Dryer Heating Element - AppliancePartsPros.com
He is showing how to replace (which I suspect you will have to do) but when you gain access then take your multi meter and test for continuity from one of the heating element connections and the heating can (case). Then do the same for the other connection. If you have a dead short (continuity form either lead and the metal case) then you need to replace your element. That video is associated with the part you may need.
Also check for continuity across the thermal fuse as thorning suggested.
Here is a link for that part and a video of its location.
Whirlpool WP3392519 Dryer Thermal Fuse - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana dryer start issue ericn222 Dryer Repair 0 09-30-2012 06:11 AM
Amana Dryer Start Button Buzzing and won't start rebeccahotsun154 Dryer Repair 1 12-16-2011 04:36 PM
Dryer does not start - Amana Gas timjgtr Dryer Repair 1 01-10-2011 08:09 AM
Amana dryer must hold start button tomatofarmer1 Dryer Repair 7 06-30-2010 05:05 AM
Amana dryer does not start Barjensen Dryer Repair 1 08-07-2009 07:29 AM
